Question about Echo Garden
Engine stalls after acceleration - Start fine, idles fine, but won't run at full speed. Engine dies when throttle is engaged more than half-way. Fuel filter is ok, air filter has been cleaned.
    Scholar:
  • 92 Answers
Sounds like its not "un-choking" it self, that its running like its still choked like you wold at initial start up.
Disassemble it and see if u can pysically see the activation and deactivation of the choke when u apply them.
While u are at it, also make sure:
Gas is fresh?
MIx is right?
Plug is good?
Chain brake mechanism is released.?
Good luck.
Posted on Oct 05, 2009
Engine cuts out when slowing down
Start off by cleaning carbs,sounds like idle jets are blocked
Feb 27, 2014 | Boating
88 isuzu 4x4 Truck 2.6L. Starts then dies in 2 sec on cold start.
I would try cleaning the throttle valve body and also the automatic idle speed control valve mounted to the throttle body, this is a common symptom of a dirty throttle valve and idle speed control valve. Use a product called "CRC" Throttle valve cleaner, run the engine and spray it into the air intake of the engine with the supply hose removed, hold the throttle up while you do this as it will try to stall, use up about half the can and then shut it down and disconnect the battery NEGATIVE cable for 5 min's to reset the system learned strategy, drive it for a few days and see if this corrects the problem.
Apr 14, 2017 | Isuzu Pickup Cars & Trucks
My car will start and idle fine sometime and sometime it dies and dies when put in gear
Engine stalls cold or RPM fluctuates at idle up and down or dies near idle.
This problem is commonly caused by a dirty automatic idle speed control valve and throttle valve but always run a OBD2 fault code as well as the cleaning procedure. Buy a can of throttle valve cleaner (do not use carburetor spray cleaner!) from NAPA or Carquest (made by CRC chemicals) and spray it into the air intake while the engine is running, use up about 1/2 the can, engine will try to stall hold the speed up, shut it down and let it soak for 30 minutes, restart and blow out the remaining fluid, shut it down and disconnect the negative battery cable for 5 Min's to reset the base idle control. If the above cleaning doesn't cure your issues you need to have the computer controlled automatic idle speed control system diagnosed and repaired by a dealer or electronic engine control repair shop.
Nov 06, 2012 | 1986 Ford Mustang
1996 mercedes c280 dies when put in drive
Engine stalls or RPM fluctuates at idle up and down or dies near idle.
Oct 15, 2012 | 1996 Mercedes-Benz C-Class
I have a 96 f150 5.8 4x4. Starts fine and runs fine, but when I start it after a 5-10 minute stop (when its warm), it will start fine but then die after a minute or so. It starts right back up and I hold...
Common issue on this year and engine, Do the cleaning outlined below.
Throttle Body Cleaning
You can in most cases repair this slow speed stall or unstable idle by cleaning the engine throttle valve and the idle speed control valve using a product called CRC Spray Throttle valve cleaner. Spray the cleaner into the air intake of the engine with the hose removed from the throttle body, the engine will try to stall so hold up the idle speed manually. Once you have used up about 1/2 can of the cleaner stall the engine out while spraying and turn the key off, disconnect the negative battery cable for 5 minutes and then reconnect and drive the car for a about 25 miles of varied driving modes. If this doesn't cure the problem you may need the fuel injectors professionally cleaned by the dealer service dept.
Jun 08, 2017 | Ford F-150 Cars & Trucks
Our 1995 Dodge caravan starts fine dies.
Do the following
Here are the most common causes of idle surge, stalls at stops, slow idle speed, erratic idle speed, rough idle and engine hesitation (and other problems), it is in most cases the idle speed control air-bypass valve and or throttle valve and upper intake, these area's get full of gunk and combustion residue over the miles and cause idle issues (stalls, low idle) like yours, Get a can of intake cleaner from any local parts store, not carb spray, intake cleaner, it is made by a company called CRC, remove the air intake hose to the engine, hold the idle high so the engine won't stall, then spray the can of cleaner into the intake while keeping the engine running, use at least 1/2 the can, shut down the engine and disconnect the battery for 5 minutes, then restart and complete a number of mixed driving cycles, town, freeway, stop and go etc., after a few days the problem will go away as the system will relearn to the clean intake
Jul 06, 2017 | 1995 Dodge Caravan
Want to verify reasons why 95 Honda Odyssee engine wants to stall and die at low speed
This is almost always caused by a dirty throttle valve and automatic idle speed control valve which is on the throttle body. Do the following to clean the system up.
To correct this problem Buy a can of throttle valve cleaner (it is made by CRC) from the local auto parts store, NEVER USE CARB CLEANING SPRAY, IT DESTROYS THE ANTI-STICK TEFLON COATING, spray it into the air intake through the throttle body of the engine until you have used about half the can, you will need to hold the idle up while you do this, it will try to stall, after this shut the engine down and disconnect the Negative (-) battery cable for 5 minutes. The intake is now clean, if you continue to have the idle speed control problems you may need to seek the help of a professional.
Feb 12, 2012 | Honda Odyssey Cars & Trucks
Dies when gas pedal is pressed
This engine has automatic idle speed control, the computer controls a "air bypass" valve on the side of the throttle body where the air intake hose from the air cleaner is connected, the valve and the throttle butterfly get "sludged" up and this causes all kinds of idle problems and off idle stall, see full list below and fix for the problems
Here is the common cause of surges, cold stalls, stalls at stops, slow idle speed, erratic idle speed, rough idle and engine hesitation (and other problems), it is in most cases the idle speed control air-bypass valve and or throttle valve and upper intake, these area's get full of gunk and combustion residue over the miles and cause idle issues (stalls, low idle) like yours.
Dec 04, 2011 | 1991 Ford F150
Kohler small engine problem
1989 Kohler 20 backfires through the exhaust. What are the possible causes?
Jun 02, 2009 | Kohler CH25 PA-CH730-0040 Command Gasoline...
99 Grand Marquis won't stay started when engine cold.
Here is the most common cause of this stall, it is the idle speed control air-bypass valve and throttle valve, they get full of gunk over the miles and cause idle issues (stalls) like yours, Get a can of intake cleaner from any local parts store, not carb spray, intake cleaner, it is made by a company called CRC, remove the air intake hose to the engine, hold the idle high so the engine won't stall, then spray the can of cleaner into the intake while keeping the engine running, use at least 1/2 the can, shut down the engine and disconnect the battery for 5 minutes, then restart and complete a number of mixed driving cycles, town, freeway, stop and go etc., after a few days the problem will go away as the system will relearn to the clean intake
Oct 29, 2008 | 1999 Mercury Grand Marquis
Garden Logo
820 people viewed this question
Top Echo Garden Experts
Jim London
Jim London
Roland W VanLue
Roland W VanLue
colesmowers
Are you an Echo Garden Expert? Answer questions, earn points and help others
