Question about Sony KP-61HS10 61" Rear Projection Television
The lamp bulb is buzzing, there is a wire conector in to the blue light tube. it is buzzing and interrupting the image
2 Suggested Answers
  • 32 Answers
SOURCE: Blue distortion on center of tv
get it demagnetised from the service shop. A simple 2 minute procedure.
Posted on Jan 26, 2010
Locating florescent bulb for sharper image model s1503 lamp
Hello, Sharper Image annoyingly did not carry this anymore. However, I found the replacement bulb at www.interlight.biz. They have any sort of specialty lamp / light bulb /projector lamp you can imagine. Here is the link for the lamp: https://www.interlight.biz/light-bulb/SHARPER-IMAGE-S1503
Dec 23, 2012 | Air Purifiers
TV turns on then cutts off
that buzzing is the high end power trying to turn the lamp on.... the electrical current and shock is what turn your lamp on your tv which is what the buzzing is dont worry thats normal...however your solution is buy a new lamp for your tv but make sure its the right serial number for lamp u cant just buy any lamp. best place to buy one ebay.... as in the lamp still trying to light up its only because the electrical current going into the lamp and then cutting off causing the red light on your tv....so other words all it is is the lamp... CAUTION!!!! those lamps get up to 400 degrees unplug tv to ensure no electrical current.... hope i helped.... JACOB WINKLER
Jul 16, 2012 | Toshiba 46HM95 46" HDTV
RT REAR BRAKE LAMP OUT,THIS HAPPEN AFTER CAR WENT THROUGH CAR WASH,THE BULB IS GOOD,IS THIS A FUSE PROBLEM. 1998 740IL
no 1 fuse both brake light test for power at light socket if power there when pedal depressed
has to be bulb if not check wires or conectors
Apr 02, 2011 | 1998 BMW 7 Series
We have sound and a blue screen with no picture
Your ballast might not be able to light up your lamp. Do you hear a clicking, buzzing? this can be an indicator that your ballast is too weak to light up the lamp. this board will need to be replaced at some point of your tv's life.
Apr 13, 2010 | Mitsubishi WD-65833 65" HDTV
Change light bulb in fog light on 2003 subaru outback wagon
remove lower cover, remove cover on back of lamp and disconnect wire then unhook clip (clip just swings to the side) and remove bulb. dont touch new bulb on the glass part ,will weakin life of lamp. goodluck.
Oct 19, 2009 | 2003 Subaru Outback
How do replace the temperature control knob light bulb in a 2005 nissan sentra 1.8s
Go to Radio Shack and head to the back where they have the drawers with the LEDs and mini lightbulbs. Get the model no. 272-1140, mini lamp 1 3/4 hookup leads, 6V, 25mA. It costs about $1.49-$2. When you take apart the HVaC unit from the center console, there's two blue twist out plugs on the top near center right and left of the unit. Twist out the one on the side that has the light out. You'll need a small screwdriver to turn it loose. Study how the wires come out at one end of the blue tube and use a needle point plier to carefully untwist the wires and pull it out from the bulb end. Now insert the new bulb w/ the two wires throught the 2 small holes until they come out the other end. Your new bulb is not a perfect fit, so just push it as best you can. Carefully strip the plastic from the wire leads and wrap it in the same position and re-insert the blue tube-thingy back into its place. Turn on your lights and it should light up again. Hope that helps.
Oct 16, 2009 | 2005 Nissan Sentra
Replacement lamp/bulb for a Philips 51PW9303
Call Encompass electronics 1-800-638-3328 also part # is on Tube you have a RED/GREEN/Blue each tube has part number on it.UNless you have DLP TV then it would be a Lamp.
Sep 19, 2009 | Philips 51PW9303 51" Rear Projection...
No picture and buzzing sound on Sony XBR Wega
Is the bulb light flashing ? - Sony's bulb light is very accurate in telling you if the bulb is bad. The buzzing sound could be from the balist trying to strike the lamp. You also may want to open the lamp door and see if the bulb is shattered.
Aug 01, 2009 | Sony Grand WEGA KF60XBR800 60" Rear...
Red power light and buzzing sound with red lamp light.
My Sony lost its picture and had a flashing light. Unplugging for 36 hours solved the problem.
Mar 29, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
Not hearing the buzzing
It's a lamp.
The blue blob is an optical block issue. Contact Sony for repair.
Sep 04, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Sony KP-61HS10 61" Rear Projection Television Logo
22 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
