Question about Sony Cyber-shot DSC-W130 Digital Camera
DSC-W130 Camera Lens extends and retracts
My Sony DSC-W130 Camera has the same problem - the lens extends and retracts 3 or 4 times and after the last movement, the screen shows "turn off and on camera". If I turn it off and then on again, It'll do the same routine again. Has anyone got a solution for this?
    President:
  • 1,564 Answers
Try cleaning your battery compartment contacts with a Q-Tip "dampened" in rubbing alcohol. The computer is getting a weak signal and is unable to decipher its commands. Also, clean the battery terminals and the charger contacts. I'm certain this will solve your problem. Thanks, Dana
Posted on Oct 04, 2009
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Posted on Sep 29, 2010
Problem with the Sony Cyber-shot DSC-W130 Digital Camera I am facing a problem in my SONY Cyber-Shot DSC-W130.When i m pressing the power button, then the lance continually up & down . After some...
it is just because there is something which is moved from within. . may be due to a fall or a hit. . so that thing is obstructing ur lens and the lens cant close. . so u will have to get it opened by an authorized service man and it will be done. . no other option. .
Mar 31, 2011 | Sony Cyber-shot DSC-W130 Digital Camera
Lens wont retract
Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Thank you!
May 25, 2010 | Sony Cyber-shot DSC-W170 Digital Camera
Lens will not retract completly on sony cyber shot DSC-W55 after being dropped while lens extended
Only try this if your camera is out of warranty. Turn camera on, and extend lens fully, now grab outer most element and pull out. Sometimes you can reseat the lens in the track at the correct point. I used to do this all the time to my older digital cameras.
Nov 28, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
The lens on my Sony W130 goes in and out.
I will forward a link to a page where you can get more information about this issue.
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&docType=kc&externalId=C91134
If the issue still persists then service of the Camera is recommended.
Jun 14, 2009 | Sony Cyber-shot DSC-W130 Digital Camera
Sony dsc-w5 lens not returniing
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
May 17, 2009 | Sony Cyber-Shot DSC-W5 Digital Camera
Wobbly lens
Half mm or so movement is normal in fully extended lens. If camera is not giving any error display during function then every thing is just fine in it.
Feb 04, 2009 | Sony Cyber-shot DSC-W130 Digital Camera
Shutter of camera not opening up .sony camera model no DSC -W130
You may be need to replace lens cover (barriel block) in this camera.
let me know if you have camera repair experience to provide you further info.
Jan 30, 2009 | Sony Cyber-shot DSC-W130 Digital Camera
You don't have to disassemble the lens. My camera would lens extend , pause and then lens retract, pause again, then lens extend, pause and then lens retract. It would do this maybe 4 or 5 times before displaying "ACCESS" on the screen and then shut down completely.
Where the lens extends from the body is the area I am referring to, there is a tiny gap large enough to slide a sheet of paper into. That is the area I shot a tiny drop/burst of wd40 into. Wd40 is sort of electronic safe and most of it WILL evaporate.If you would like, send me your email address I will send a photo file-picture of how i did it. Hopefully it is the same problem.
jgbhornung@hotmail.com
Just put "camera problem" in the subject box
Jim H
Mar 30, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Lens cover stays open
Try blowing lots of compressed air around the open lens shutter to clean the mechanism. Or use a hair dryer for a few seconds (don't want to heat up the camera). Also with the lens barrel extended and pointed downward, tap the lens barrel with a pencil while you extend and retract the lens by powering the camera on and off. A grain of sand in the mechanism is usually the culprit, and you want to try to dislodge it.
You can open it up, but only as a very last resort. The above procedures usually work if you try them enough. But for those particularly nasty stuck mechanisms, here's an example repair on a Canon Powershot A400 (do this at your own risk, and it will void your warranty):
http://camerarepair.blogspot.com/2007/11/repair-of-stuck-lens-covers.html
Oct 30, 2007 | Sony Cyber-shot DSC-W55 Digital Camera
Sony cybershot dsc p5
probly has salt spray sticking the lens cover shut
Sep 19, 2007 | Sony Cyber-Shot DSC-S60 Digital Camera
Sony Cyber-shot DSC-W130 Digital Camera Logo
761 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
