Question about Lexmark X4550 InkJet Printer
How to add a computer to my printer - Lexmark X4550 InkJet Printer
Change printer
you must uninstall the old printer first then do this.
  1. Click the Start button, and then, on the Start menu, click Devices and Printers.
  2. Click Add a printer.
  3. In the Add Printer wizard, click Add a network, wireless or Bluetooth printer.
  4. In the list of available printers, select the one you want to use, and then click Next.
More items...
Fix printer problems - Windows Help - Microsoft Support
if you have any trouble goto this link..
For Seniors How to Install Printer for Your Computer dummies
Dec 23, 2016 | PRINTER Office Equipment & Supplies
Printer setup network
You need to add the printer I.P address to the list of printers on p.c
start>devices and printers>add printer>then follow prompts
Jul 05, 2013 | Minolta Di3010f Printer
Printer crashes computer
Simple tip to fix this issue is to Index your Computer and Add Hardware based on the Test Results:
Windows Experience Index rates up your computer. You can add appropriate hardware based on the search results.
  • Click Start.
  • Press ENTER.
  • Windows Experience Index will launch.
  • Click Rate this computer button to start conducting the tests.
  • After these tests are completed, you can get the overall performance results.
You are advised to add new hardware based on the search results. For example, upgrade your processor, add more RAM and add a Graphics Card.
For Instant Fix use Reginout system utility.
Jan 16, 2013 | Oki Electric Industry MB290 A4 Mono Laser...
I can't connect the printer with my laptop. The printer is connected to my main computer and I'm trying to get my laptop to recognize the printer.
You will need to add this printer as a network printer using the main computer as the server. This is easily done, but is different for each operating system.
winXP= start>settings>printers and Faxes>add a printer> add network printer (next will search for printer)
- sometimes you must share the main computer by opening windows explorer and right clicking on the c: and select sharing and follow the screen
- Hope this helps, send more info if you need more help
Aug 28, 2011 | HP PSC 2210 All-In-One InkJet Printer
Want to install printer
If you are running Windows XP or Windows Vista, you may simply plug in the printer to the computer, and the computer will install the generic driver.
By default, Windows XP and Vista already has the generic driver installed.
However, if the printer is not a Plug-n-Play device, you will need to load the CD that came with the printer, and follow the installation wizard.
Thank you and good luck!
Jun 13, 2010 | Brother MFC 240C All-In-One InkJet Printer
How do I network brother mfc-440cn printer - what
  1. Plug the printer into a computer on your network.
  2. This computer must be on and remain on for the printer to work.
  3. Add this local printer to this computer in "Control Panel" - "Printers".
  4. Now share the printer.
  5. Go to another computer on your network.
  6. Add this printer (as a network printer) to this computer in "Control Panel" - "Printers".
  7. The system should find the printer and add it...
Nov 15, 2009 | Brother MFC 420CN All-In-One InkJet...
How do I get my computer to print from the printer?
Have you installed it yet? Click "control panel" on computer, Click "printers & faxes", in Printer tasks on left side of screen click "Add a printer", then the add printer installation wizard should come up. Follow the instructions and you should be right. Good luck.
Apr 03, 2009 | HP 7210 OfficeJet All-In-One Printer
Printer installation
On the computer that the printer is connected to, go into the Printers and Faxes window, RIGHT click on the printer you want to share and select "Sharing...". After you finish going through the printer sharing wizard, go to a different PC and try to add a printer, select network printer. Make sure that the computer that is sharing the printer is on during this process, it sounds strange to have to mention this I know but you would be surprised. I'll check back later to see how things worked out.
Feb 21, 2009 | HP Office Equipment & Supplies
Add printer to computer
All you have to do is add a driver. Download the driver from here:
http://downloads.lexmark.com/perl/downloads/downloads.cgi
Then install and restart. Viloa! Your printer is installed
Jan 31, 2009 | Lexmark All-in-One Printer with PictBridge
Lexmark X4550 InkJet Printer Logo
21 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
