Question about NetGear DG834G Router
My netgear4aol modem router wireless has turned off so its still working on the computer its connected to but its not giving out wifi so i cant connect to it with my ipod touch. how do you turn it back on? thanks.
  • 8,404 Answers
Hard reset to factory specs ... look for a very small hole in the case, press and hold the buttonn with a paper clip for 30 seconds
Posted on Oct 04, 2009
Cant connect the router over wifi
To turn on wifi connect the power cord from your routers to the power outlet box then connect a computer to one of the rg45 or LAN of your router check the manual of your router for setting by using your browser with the ip specify on your router's manual eje: http:\\192.196.0.1:80 on your browser it dependent the manufacture of your router. And locate it the right setting or power ciacle the router by turning it off or desconnecting from the out let for 5 minute and make sure your computers have wireless on look by the button sing of wireles on your computer hold it and let go until you see the wireless light
May 14, 2016 | Dell TrueMobile 1184 WX-6215D Wireless...
Tip
Share Your Internet Connection with More Than One Computer- The Easy Way
Here is a simple way share your home internet connection with more than one computer. This will work for both wired and wireless and doesn't require alot of technical or computer skills to accomplish. I'm sure there are other ways, but if you're looking for a simple repeatable setup, here it is.
If you've got a dsl connection through a dsl modem, this TIP will work for you.
If you've got a cable modem, this TIP will work just as well.
Here's a list of what you'll need.
  1. Dsl or cable modem that works on your system and you can access internet with one computer (If you're using the internet, most likely you've got this already).
  2. Wired (Ethernet) or Wireless Router (wifi routers have 4-6 ethernet ports also).
  3. For Wired: Ethernet cable to connect modem to router.
  4. For Wireless: Wifi compatible computer or wifi card for your computer (follow manufacturer's instructions for proper install).
Procedure:
  1. Turn all components off. This includes anything on your existing network- computer, modem, printer and any router you may currently be using.
  2. With all power off, connect an ethernet cable between your modem and your new cable/dsl router(wired or wireless).
  3. Turn on the power to your new router only and let it boot up completely.
  4. Turn on the dsl/cable modem and allow it to boot. Since the router was booted first, the modem with recognize the router's MAC address (ethernet numerical address) and connect that address to the internet.
  5. Connect all the other components onto the router with the ethernet cables as needed and turn on the components- no particular order is necessary after the router and modem are booted. Your router will assign MAC addresses to all the ethernet components. Once the MAC address is assigned, your computer should work correctly with the internet and shouldn't drop out when the second computer is turned on.
  6. For wireless connections, boot up your computer with the properly installed Wifi card, airport card and allow it to "find" your router. Once you get confirmation of the signal, you're good to go.
Following this procedure will allow your modem, your router to use their designed software to connect you without a bunch of programming. You will actually enjoy having more than one computer sharing an internet connection.
Remember this procedure and follow the steps again if you lose power and have to reboot your network.
on Dec 04, 2009 | Computers & Internet
I cant get wifi and internet on my computer at the same time
Hi. Let's hava look at what you are doing.
I'm guessing that you have a cable modem a dlink router with wifi and a computer, right?
If you connect the cable modem to the computer you have internet. You shouild also have wfi but the wifi will not give you internet because it is disconnected from the modem.
The Dlink has to be connected to the modem but it will also need to be configured. To *** that you will need help from your cable company.
The connections should be. Modem connected to the outside world. Dlink connected to the Modem. Computer connected to the Dlink by either wifi or Ethernet.
Feb 28, 2012 | D-Link RangeBooster G WBR-2310 Wireless...
Im trying to connect my ps3 to my wireless router. it has recently stopped working. is there anything i can do?
Sure! Try this:
1 Turn your network off. Modem router, computer, printers etc. turn them off.
2. Leaving the wireless router connected to the modem with an ethernet cable (modem power off) , turn your wifi router on and let it cycle up.
3. After the router is cycled up, turn power on to your modem , leaving the ethernet cable connected to the wifi router's internet port. Let the modem cycle up .
4. After this, turn on all computers, routers and etc... no particular order.
This should allow your modem to find the wifi router and direct it to your computer via wifi or ethernet..
Dec 08, 2009 | Computers & Internet
I moved and trying to get my wireless going again to my lap top. I have my internet connection hooked up but don't know what to do next.
Here's how to get the router communicating with your modem.
You stated you've got internet hooked up, so I'll assume it's working..
So here's the procedure:
1. Turn off your modem (you can leave it connected .. just turn it off.
2. Turn off computer, router and any printer.
3. Make sure you've got a ethernet cable connected between your modem and wifi router.
4. Turn on the power to your Router ONLY. and let it boot up.
5. Now turn on your modem and let it boot up.. it will find your wifi router and all lights should lite on the modem.
6. Turn on your computer and it should find the wifi signal and you should be ready to go!
Keep these instructions and follow this procedure if you have a power outage... the sequence of events is the key.
let me know if I can assist you further!
Dec 05, 2009 | D-Link 802.11g Wireless Router WBR-1310...
I did a firmware update and now i cant get a wifi
After the firmware upgrade, did you configure the wireless router settings again?
To set-up and secure the wireless router from unauthorized access, follow these steps: -
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL IP address.
3. Enter the router setup, login and password
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WPA2 (if not then WPA).
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router wirelessly.
Nov 13, 2009 | Trendware TRENDnet TEW-435BRM 802.11g...
Changed from AT&T to a cable company for DSL. Trying to set up
You need to "fool" your cable box into thinking that the wireless router is the computer. This just means that the modem is locking into the first ip address it can get... it tends to block out all others. Here's how to remedy and allow everything to get access...
1 Shut off computers, routers, everything.
2. Turn on your wireless router FIRST... leave everything else off until you see it's completely booted.
3. Then with the cable connected to the modem/cable box and the router, turn on the cable box/modem and let it cycle up. This should allow the cable modem to "find" the wifi ip address as the main ip.
After that, turn on any other routers, and the computers...
This should allow you access to the net by any of your computers because the wifi router should give all the other comptuers and routers on the system inddividual ip addresses and all should be well...
Give it a try and let me know!
K
Aug 28, 2009 | 2wire (1000-400108-001) Router
D-link wireless wont work after high speed disconnect.
it's pretty easy to remedy...
1. turn off all computers including wi fi laptops... turn off routers, modem, wifi router as well.
Here's the trick:
Turn on your main router... the one that is plugged direct to your modem.
turn this on before anything else... once it's booted up, turn on your modem... it will cycle up and find the first ip address which will be your router that was turned on previously...
Then turn on all the other routers, wifi computers.... the main router should give all the other equipment their addresses automatically and you should have wireless working at that point...
Good luck... let me know if it gets you up and running.
May 27, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
Can I use my router just as a Wireless router with a DSL .
i doubt it will work. most times the cable companies give you a modem/router all in one box. the problem is there in no inbound connection to recieve an internet signal other than the cable cord connection. with the dsl modem you will need a seperate router. they cost around $40-50 on avg
Feb 05, 2009 | Arris SURFboard SBG900 Wireless Router...
No wifi connection
Verify which MAC Address U have Cloned. MAC Address of Your PC WiFi and Cloned One must not be same otherwise it will not work...
Feb 02, 2008 | Belkin (F5D7231-4) Wireless Router
NetGear DG834G Router Logo
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
