Question about Canon ZR100 Mini DV Digital Camcorder
Tape being rejected
I can not get a tape to stay in
I tried the tape that i just took out which was working fine untill i hit eject
i tried a tape right out of the package
and i tired a tape that has worked before
  • djj5 Apr 10, 2008
    I have the same problem with my ZR10.  I used the camera twice in one year and the problem of ejecting a tape occured two weeks after the expiration of the warranty.  I purchased this camera in 2001.  I searched for solutions and even called Canon, but they wanted to charge me 150. 00 bucks and gave no garuantee of a solution.  I learned my lesson the hard way as I paid 550.00 bucks for a sleek looking camera.  I won't ever purchase a canon product again.  What a ripoff!
    Problem Solver:
  • 6 Answers
I had this problem this weekend with an Elura 65, where the camera would not accept a tape. If you inserted a tape, it would beep a few times, the LCD screen would flash "REMOVE CASSETTE TAPE" and then it would spit the tape out. I had the camcorder stored in a ziplock bag in a cool / dry cabinet in our spare bedroom. None of the previous solutions worked for me (clean the heads, take out the batteries, remove power for 20 minutes, remove the memory card, etc).
What worked for me:
I left the main battery in, installed the small memory battery, installed the SD memory card and plugged in the power cord. I left the camera out (close to my computer), which is upstairs in my house- in a 70-75 degree Farenheight environment - for 24hrs. After 24hrs of sitting out and being plugged in to power, I suspect everything came to an ambient temperature and the camera worked fine. (you might try up to 48hrs of being warm)
I suspect that most people's cameras are having this trouble when the internal parts of the camera are not all warmed up so the camera will reject a tape because something is NOT functioning properly when cold.
If you look at the timing of these postings, you will see that most people are posting issues in the cold winter months. I won't buy another Canon Camcorder, but am appeased at it coming back to life long enough for me to download my information to my computer.
If you call the service support for Canon (which I did), they will ask you for your serial number, model, date of purchase, name, email address & mailing address. They will ask you to mial your camera along with the printed information above and detail your problem. It will take 7-10 business days for someone to contact you via email or phone.
Good luck with your camcorders!
cjammin - Cedar Park, Tx
Posted on Jan 08, 2008
Tape is stuck in VCR. I turn on the power and hit eject and it shuts off. Took the cover off but do not see a simple solution.
I am sorry that I do not have a technical solution for a problem like this one. I can tell you what my father did that worked for him. My father turned his vcr upside down and took a butter knife with a smooth blade and wiggled and manipulated the vhs tape until it popped out.
Aug 22, 2010 | Panasonic PV-V4621 VHS VCR
Shuts off when eject button hit.
does it open when you when you connect it direct to the wall scoket.
Jun 04, 2008 | Quasar VM-L153 VHS-C Camcorder
Sony Handycam DCR-HC38 is rejecting the head cleaning tape
camera has bad tape loader and or bad tape sensors. sounds drastic but bang it a few times with the palm of your hand. if this doesnt work contact sony service center
Jun 01, 2009 | Sony Handycam DCR-HC42 Mini DV Digital...
VCR won't eject tape - timing of loading mechanism is off
Now-a-days most of the gears are made out of plastic(HDPE, if I remember correctly), when the rewinding command is given even if one gear tooth is worn/broken it will throw the entire timing out of 'gear'. Since the problem has already occurred, and, this is the only function that has malfunctioned my advice would be to leave it as it is! ('cos repairing/replacing it is manual & therefore a costly affair plus there is no guarantee that the replacedment will function properly)....sodeep
May 09, 2009 | Sony SLV-940HF VCR
Tape ejects immdediately when I load tape.
I own a Sharp VL-Z1 DV video camera. I had this same problem and thought it was from using the ME Maxell tapes. I took the battery out of the unit and let it reset. Worked fine after that.
May 05, 2008 | Canon ZR85 Mini DV Digital Camcorder
Canon zr300 ejects tapes
There is a fix for this which was posted for either the ZR 200 or 400. They call it the "Fonzie" fix. Just hit the camcorder with your fist on the side where the tape goes in (with the door closed). Hit it lightly once, try inserting the tape. Repeat this process with increasing force each time until this works.
Surprisingly, this worked for me. Obviously, there must be something loose for this type of solution to work. I actually had it working once, then it acted up again. I tried the same solution and it's working again. No problems for several days now.
Feb 11, 2008 | Canon ZR300 Mini DV Digital Camcorder
Tape stuck in VCR, won't eject.
you posted 2 different problems here...
to answer this one ". The tape is stuck, won't eject and I'd like to get it out without damaging the VCR unit."...open unit, find motor that moves tape ejector and spin that motor by hand (power off)
the other problem, "the VCR will not insert a tape. It keeps rejecting it."...open unit and fully turn ejection motor until home position is reached...this is a home sensor switch not being activated.
Feb 04, 2008 | Televison & Video
What do I do when my Emerson TV keeps turning off by itself?
I had the same problem with mine turning off after 3-5 seconds. After much research I found a suggestion that on some combo units the vcr part could have a power supply cutout if it is not working correctly. I tried to insert a tape and found that the tape mechanism would not accept a tape. I used a little bit of force and managed to insert a tape. I then played the tape forwards and backwards and the power stayed on! I ejected the tape and found the TV then worked just fine. The power has now been on for over one hour. I hope this give you another avenue to try and fix your problem.
Nov 30, 2007 | Televison & Video
Power problem
Has this just started happening? What did you do just before this happened? You need to supply much more information, we are not mind readers! What's the make and model, this ain't a generic problem!
Oct 06, 2007 | Quasar VV1309 13 in. Combo
Canon ZR100 Mini DV Digital Camcorder Logo
117 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
