Question about La Pavoni ZIP Auto Electric Grinder
Extremely course grind - La Pavoni ZIP Auto Electric Grinder
    President:
  • 1,618 Answers
Remove bean hopper, clear chamber of all beans, either by grinding or using a vac cleaner, then turn adjustment collar finer until it cannot move, then back it up about 1/4 to 1/2 a turn. That should give you a good starting point on your grind.
Posted on Oct 05, 2009
My hot point aquarias extra wma 40 has started making extremely loud grinding and crunching noises when it spins I am extremely worried please help
Please Switch if off immediately and call Authorized Service Center. Operating this Machine with such symptom may be hazardous!
Apr 26, 2014 | Washing Machines
Coffee grinder only grinds to course no matter where grind adjuster is set
From what I've read about this grinder, you should be happy that it worked well as long as it did.
I say chuck it & buy a new one!!
Apr 13, 2012 | Coffee Makers & Espresso Machines
My belt siezed and broke off earlier there was a grinding rattle in engine for past few days and my ac hasnt worked for more than a month
grinding noise was probably a bearing in ac compressor, when it froze up completely it stopped turning causing extreme wear on the belt ..so it broke... check ac compressor out , could be bearing only ..could be whole compressor ..have it fixed...when compressor is removed the hoses have to be disconnected of course so if it still has refrigerant in it, that will need to be recovered at a shop..the ac system will have to be vacuum pumped down and recharged anyway.
May 23, 2011 | 2000 Saturn Ls 4dr Sedan
Brakes are making a grinding sound
If your brakes are grinding I would take the tires off and check the pads and rotors for extreme wear. The grinding sound could be the pads are so wore that the metal pads are digging into the rotors.If this is the case before putting the pads back on replace or cut down the rotors if there not to damaged.
Mar 11, 2011 | 2005 Dodge Caravan
Ge spacemaker xl1400 model# jvm141obc Turntable still turns..but while making grinding sound Please help
My wife noticed a strong smell of something burning inside our home. Luckily we were home. The microwave was NOT on...and the turntable was turning and making that grinding sound. When I opened the door, the turntable kept turning....all digital lights were OFF. The microwave does not work. I am extremely angry that this unit was able to continue to grind unnoticed. If we were not home, I assure you that this would have caused a kitchen fire. The upper inside portion was extremely hot to the touch and the cabinet on top of the over-the-range microwave was also very hot. This would have easily caused ignition and a subsequent kitchen fire. I am going to report this to the UL.
Feb 10, 2011 | Microwave Ovens
Lexmark C510 is making grinding noises while printing large jobs
I found another posting stating that the culprit was the black toner cartridge. Sure enough I changed our black cartridge and the grinding noise has stopped. No wonder the grinding noise was not happening all the time only when the black cartridge got low. Thanks for the help!
Oct 15, 2009 | Lexmark C510 Laser Printer
Mazzer luigi super jolly
Easiest way to set the grind on the super jolly is to remove the beans, turn towards fine until you can barely move the middle stem in the grind chamber, then turn towards course about 12-14 notches on the grinding adjuster(not numbers but notches between numbers). If you still cannot get a fine grind and it is not a brand new grinder replace burrs.
Feb 28, 2009 | Mazzer Coffee-grinder SUPER JOLLY Electric
How to select grind courseness for a DeLonghi DCG39 grinder
Go to delonghiusa.com. customer care. manuals. They have yours to download.
Aug 18, 2007 | DeLonghi DCG39 Electric Blades Grinder
La Pavoni ZIP Auto Electric Grinder Logo
131 people viewed this question
Top La Pavoni Coffee Makers & Espresso Machines Experts
billconfused
Pieter Vleeshouwers
Pieter Vleeshouwers
NOEL
NOEL
Are you a La Pavoni Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
