Question about Pro-Fit Pro.Fit Jp 73 02 Jeep Liberty 02 Up
My air bag light comes on intermittently on my 02 Liberty. I had a collision a few months back; airbag did not deploy, but since then, it comes on occasionally. If you turn the Jeep off & on again, the light goes off. My BIL says it's not an issue. Is he right?
  • 37 Answers
I also own a jeep liberty, 2005, and my passenger airbag light does the same thing. I have also been told it's not a problem, and I've never known a mechanic that wouldn't fix whatever they could to squeeze more money out of me, so he's probably right.
Posted on Oct 04, 2009
I was t-boned in my 2005 monte carlo and my air bags did not deploy. Why?
You should be very happy that it did not deploy as that is probably why you are here today to write this question. Airbags will generally only deploy in a severe collision where there is a high probability of serious injury or a fatality. In your case it obviously was not severe enough to seriously hurt you. Be thankful and send the car manufacturer a thank you letter for building a car that helped you survive.
Aug 26, 2017 | Cars & Trucks
How du you reset the airbag light on a 2005 nissan primera
Depending upon which "airbag light" you see, it's one of two things:
  1. If you are seeing the yellow AIRBAG light on your dashboard, it means that your airbag system is not operating properly, and should be serviced IMMEDIATELY, because it will not protect you in the event of a collision;
  2. If you are seeing the light in the middle of the dashboard that says "PASS. AIR BAG OFF," it means that you have disabled the passenger air bag, and it will not deploy in the event of an accident. Follow the directions in your User Manual.
Jul 22, 2014 | 2005 Nissan Primera
Airbag light stays on 1996 saab 900s what to do
The most common cause for your air bag light is a faulty sensor. In this condition, the airbag cannot be depended upon to deploy in a collision. In almost every case, replacing the airbag sensor will solve your issue.
Dec 27, 2011 | 1996 Saab 900
Air bag light showing at the dashboard. It's intermittent happening. The air bag light dissapeared for a month then iy\t's back again. It usually appears for a couple of days. What could be causing t
The airbag light on the dashboard comes for few reasons, either there is a bad connection or connection came loose but than the light would stay on at all times, if it comes periodically than I would look up to the owner's manual and also find the airbag check label inside the car as it might be faulty or in need of replacement. The danger is that if it is faulty it can blow up by itself or in case of accident (hope none happens) it will malfunction.
Oct 18, 2011 | 2001 Pontiac Montana
AIR BAG LIGHT STAYS ON; light with the exclamationn mark; and another light stays on all the time
Anytime your airbag light illuminates, there is a problem with the SRS system and the airbags will not deploy in the event of a collision. Have it checked out asap, if you want the airbags working.
Sep 14, 2011 | 2007 Chrysler Sebring Sedan
Airbag locations
In the steering wheel and passenger side dash.Due to the age of the vehicle probably doesn't have the curtain "side" airbags.The airbags were designed primarily for head on collisions. Here is some useful information to why the may have not deployed courtesy of http://www.asashop.org/autoinc/dec2001/collision.htm
How Air Bags Work To have a frontal (driver or passenger) air bag deploy, certain criteria must be met. One of these criteria is that the frontal impact must be within a 60-degree window, occurring within 30 degrees from the vehicle's centerline. Another key element is that the crash forces are equivalent to a head-on collision with an immovable barrier at 10-15 miles per hour. Because a typical automobile accident only lasts about 0.125 (1/8th) of a second, air bags deploy within 15 to 20ms after the initial crash impact. To create a protective cushion between the occupant and the vehicle's interior, the air bag inflates at speeds up to 200 mph within approximately 30ms after impact. This allows the occupant to contact a fully inflated bag within approximately 45 to 50ms after the initial crash impact. Approximately 100ms after impact the bag deflates.
May 30, 2010 | 2001 Buick LeSabre
Front airbags go up sometimes n sometimes it takes them a while to go up oc i turn off the navi front air bags go down after an hour or 2
your airbag diagnostic module senses an intermittent fault and needs to be fixed at once cause it might not deploy the airbag module in the event of a collision. This symptom needs to be checked in a workshop using a diagnostic computer to find out the fault code. Its not an owner quick fix
Feb 09, 2010 | 2003 Lincoln Navigator
Have there been any unexplained air bag deployment in 2005 santa fe on the drivers side while in motion. my husband was driving and he said the air bag deployed and then he hit a car in front of him. do...
http://www.nhtsa.dot.gov/cars/problems/ is the website I checked for your car and found no reference to this issue. There are reports of airbag deployments with no collisions, although they are rare. The computer in your car is capable of displaying the deployment, and may show which sensor in the front if any caused it to deploy (collision first/deployment second) or if no sensor signal (deployment first / collision second) is logged. Whatever the outcome, you will need a specialist in data extraction to achieve this.
Jan 06, 2010 | 2005 Hyundai Santa Fe
Light stays on and warning for airbag service on reader board
If the airbag light stays on after it completes it's "check light" process then there is a fault in the air bag system. It could be anything from a bad sensor (there are 3 of them) to a wire that has become unplugged. This problem should be repaired as soon as possible because the air bags will not deploy in a collision while the warning light is continually on.
Nov 03, 2009 | 2004 GMC Yukon
Air Bag Code
Code 52 relates to low voltage detected in a capacitor inside the airbag module. 45 seconds after key on, this capacitor should have a voltage of around 23 volts.
This capacitor stores energy to deploy the airbag in the case of a collision.
Because your airbag light is on, your system is deactivated (cannot deploy)
In your case, the airbag computer detects less than 23 volts at that capacitor 45 seconds after key on, and disables the system.
There is a diagnostic procedure involved in fixing this problem, but usually means a bad airbag module (computer)
This should only be checked by a qualified technician, as airbag service can be dangerous and there are strict procedures to follow so the bags don't inflate suddenly and cause injury.
Aug 27, 2008 | 2002 Ford Taurus
Pro-Fit Pro.Fit Jp 73 02 Jeep Liberty 02 Up Logo
299 people viewed this question
Top Pro-Fit Car Audio & Video Experts
greg benton
Craig Butler
Craig Butler
Are you a Pro-Fit Car Audio and Video Expert? Answer questions, earn points and help others
