Question about Westinghouse L1975NW Monitor
I need a manual showing all the oarts of the motor I'm not getting any fire at the plug. Switch is on but no fire. I need a complete schematic of the whole machine so I can find the caise and repair it. Weed Eater trimmer Model XT260 serial # 06081N100 153 (08-04) Model PP138E 711891
    President:
  • 2,666 Answers
Http://lawnandgarden.manualsonline.com/manuals/mfg/weed_eater/weed_eater_trimmer_product_list.html
Posted on Oct 04, 2009
Have fire to starter, fire to ignition switch, when i turn key not getting fire to solenoid
Check the schematic to locate any and all parts in line between the battery and the motor.solenoid.
Feb 12, 2016 | Garden
Not getting spark on snapper backpack leaf blower model #BPB4150M can't locate manual wondering what the little red button was and if should house a fuse and be pressed in or popped out like it is
OK that little red button looks like a kill switch pop it out pull the cord if you start getting fire its just a simple kill switch grounding out your fire!! Now if you can't get fire either way get a voltage meeter put it to the terminals and if you get any electricity and no fire replace the fuse?? If you get nothing from the plug wire at all you need a new coil pack
Dec 30, 2014 | Garden
Free wiring schematics
go to the library they will have a book for your truck that will show you the plug wire location for the distributor and distributor rotation and firing order and cylinder position on the engine. is this is all you need.
Sep 04, 2014 | Cars & Trucks
Have a 1992 Ford Bronco Eddie Bauer Tailgate window motor problem
I looked at my schematics, and they don't show a relay. They do, however, show two ground wires coming out of the tailgate window switch. There is a ground wire for the "up" side of the switch, and a ground wire for the "down"side. These would be color-coded black, and I think that it is worth checking to make sure you don't have a corroded /broken ground running from the tailgate switch. If only one grounding wire was broken, the window would operate in only one direction. Both dash and tailgate switches share the same wiring circuit, and these wires are "hot" all the time. It's normal when you get both sides of the motor leads at 12VDC when neither switch is activated. These switches function by switching off one of the two motor leads, and connecting it to ground, thus allowing power to flow thru the motor windings. Of course, reversing the polarity on a DC motor will change the direction of rotation, so changing which black lead is switched to ground gives the up or down direction to the motor.. since you can read schematics, you might check out ebay for a used Haynes manual cheap. hope this helps
Apr 29, 2010 | 1992 Ford Bronco
I need a repair manual to show assembly of the power switch
Not sure about the repair manual.. here is a link to the schematics I used:
http://www.toolpartsdirect.com/cgi-bin/schematic.cgi/makita/LS1013FL
For better view use the PDF version.
Jan 08, 2010 | Makita LS1013FL 15 Amp 10 Inch Dual Bevel...
Wiring ? dimmer switch onto wiring, 2 cable, which is plugged into ordinary 13 amp wall plate I have lights which are wired together with 2 core cable, max 120w, which are then plugged into wall socket...
It depends on the dimmer, but the usual in-line dimmer will have a wiring schematic o show you, you don't usually have to wire the neutral (second wire that goes to the non fused leg of the 13A plug top)
I presume the bulbs are regular incandescent and not CFL's or halogen?
Oct 13, 2009 | StarTech.com StarView SV211K 2-port KVM...
Need info on how to change wiring from recirculation to remote
get another electrician, he doesn't know what he is doing, this is not easy to figure out without diagrams of the connector that shows exact wire colors and where they go or went in prev installation..
Apr 10, 2009 | Thermador UCV36ASS Kitchen Hood
Westinghouse L1975NW Monitor Logo
53 people viewed this question
Top Westinghouse Computers & Internet Experts
Matthew Spark
Matthew Spark
Iqbal Husain
Iqbal Husain
Are you a Westinghouse Computer and Internet Expert? Answer questions, earn points and help others
