Question about Garden
Wont start getting gas and fireing but still wont start
2 Suggested Answers
haider_alhar
  • 90 Answers
SOURCE: wont start 88 dodge dakota getting fire and fuel
pls be more specific its crank or no its maybe you motor so if you can specify
Posted on May 31, 2009
Honda lawn mower wont start
fuel spark air has to get all in the proper time to fire remove plug and squirt a little gas in hole put plug back and try again
Apr 18, 2015 | Honda Garden
My truck ids getting gas and fire cranks but wont start
See if your getting spark,If not its probably the crank or cam sensor.
Aug 21, 2014 | 1991 Chevrolet S-10
My 2000 Chrysler 300m wont start it turns over but wont fire its getting gas but wont fire
Are you certain it's getting gas, does it smell flooded?
Pull one of the plugs, see if its wet after cranking.
Ground plug and check for spark, if no spark, problem could be crank sensor or coil packs.
Aug 30, 2013 | Chrysler Cars & Trucks
1998 ford contour cranks but wont start
need more info is it getting fire getting gas remove he air filter and drop some gas down the carb if it starts then it is in the fuelsystem if not check your plugs that they aer fireing rember gas fire timeing and compreshion
Mar 05, 2013 | 1998 Ford Contour
Just wont start got getting fire and gas still wont crank even if i put a little gas on sparkplug
Pull cap check to make sure you are firing in seaquance you may need to put the number 1 up and check to see if the number 1 is is firing number 1. It's due to someone not setting the timing properly
Sep 11, 2012 | Poulan 25CC Gas BlowerVac
My car wont start. I'm getting fire an gas. If I
Is the security light lit on the instrument cluster ? Injectors firing ? Spray carburetor cleaner through the throttle plate an see if starts then . If it starts an runs for a second it's not getting any fuel . How do you know it's getting gas ? Did you hook up a fuel pressure gauge ? Hook up a scanner an check an check data parameters ?
Feb 15, 2018 | 1996 Pontiac Grand Am
Changed distributor cap and now van wont start did not have firing order . we now have correct firing order. van was possibly flooded from checking firing order. now carborator is smoking and engine wont...
I would pull the plugs and let the gas into the cylinders to dry out , you may have a hydrolock engine after putting so much gas into it , recheck the firing order to be sure is OK ususlly when you see a carb backfiring and smoking the firing order is not right
Aug 02, 2009 | 1992 Chevrolet Lumina APV
Engine wont fire has spark gas not getting thruogh
pour alittle bit in carb & if it starts then it could be the fuel pump or the fuel lines
Jul 19, 2009 | Craftsman 24 Hp 48" Deck Yard Tractor
Wont start with new plug. I can smell gas, but none on plug
Check the start stop switch, sometimes they can get dirty causing the saw not to get spark. Also maybe check Your air cleaner. if it's clogged it may be flooding itself out?
Jan 26, 2009 | Makita DCS6401 20 20",64cc Chainsaw 2...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
