Cooling fan overheating Samsung HLP4663W. unit shuts off and will not stay on unless allowed 10 mintues off. Flashing lites on on/off button indicate "cooling fan not operating normally". Common problem? repairable?
Therinnaiguy
  • 1420 Answers
SOURCE: no cooling after power out, indicator lights pattern not in manual
The Mitsubishi units have to be reset by turning off the indoor units by switching the remote or thermostat to off. Then turn off the breaker to the outside unit(s). After 30 seconds,turn on the breaker and then you can turn on the remote for cool. If no lights come on on the inside units, most likely you have blown a fuse soldered on the main PC board. At this point, call your technician. A goos tech will be able to wire in an in-line fuse holder so if it should happen again, you can easily replace the fuse. If you do see a light or two come on at the indoor unit but the outdoor unit does not start after 3 or 4 minutes, sounds like you will need to call a technician. Most likely you have a blown fuse on the main PC board of the outside unit. It is not an easy one to replace. Good Luck!
Posted on Sep 04, 2007
SOURCE: Zenith e44w48lcd Won't turn on
need manuals for model z32Lc2d ser719192169807
Posted on Jan 31, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Magic Chef MCO153UW
The cooling fan is a must!
Otherwise, the magnetron will be ruined, and that drives up the repair cost.
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can order parts here: https://www.mcappliance.com/partorder.aspx
To contact Magic Chef about getting an *authorized* servicer, see: http://www.mcappliance.com/contactus/contactus.asp
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Mar 04, 2008
  • 3 Answers
SOURCE: lights flashing all cooling appears normal ice maker flap continually opens and shuts no water buttons not operational
As I mentioned before my Maytag was doing the same thing, I called Maytag expecting a big fight but they were really nice about it.
This is a recall problem and even if your warrenty is up Maytag will repair it at NO COST to you.
They shiped me the HV board and sent a repairman who had it fixed in about 10 minutes with a newley designed HV board.
Posted on Mar 30, 2008
Marrie
  • 563 Answers
SOURCE: projector indicates overheating and shut down
HI there
Is there any on scren messaes before shutting down and when shutting down - which of the LED's on the unit is flashing and what colour ?
Posted on Apr 21, 2008
Why will my rts he 10 not stay on no longer than a couple of seconds
Have you been playing the unit really loud or have you connected more speakers to the device, than originally came with the unit? I had a Yamaha unit and connected 4 extra speakers to the unit, which eventually overheated the device and the device would simply shut off, until it cooled down, however; the unit finally failed and burned up. I used a fan to keep the unit cool, until it finally failed, though......
KR
May 26, 2014 | Samsung Audio Players & Recorders
Wall furnace heats up after 10 minuts shuts off and doesnt come back on
What is the make and model of the unit? This is a sign that the unit is overheating and it can be a hazard.
Feb 26, 2018 | Rival Heating & Cooling
When im welding the xmt 304 machine will arc out and the volts will say HE.L and the amps will say P.5 its like it loses ground what does the volts and amps mean when it says that.
Help 5 Display Indicates the right side of the unit has overheated.
The unit has shut down to allow the fan to cool it. Operation will continue when the unit has cooled.
If unit overheats, output stops, a Help 5 message is displayed, and cooling fan runs.
Wait fifteen minutes for unit to cool.
To avoid this problem Reduce amperage or voltage, or duty cycle before welding.
Jan 22, 2011 | Miller Welding Tools
Shuts down not allowing Windows XP to start
If the Computer shuts down automatically, then the issue might usually be due to the overheating issues.
The overheating issues develop, if the Cooling Fan in the Computer is malfunctioning.
The Processors are designed to shut down automatically, if there are any overheating issues.
For such issues, it would be better to get the Unit examined at the Service Center.
Replacing the Cooling Fan should resolve the issue.
Hope this helps.
Jul 07, 2010 | Toshiba Satellite A105 Notebook
Need to replace cooling fan
could the reason for the picture going off after 10 mins be the cooling fan if so how do i replace it my model is sp46l6hx
Oct 23, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
TV keeps turning off after a few minutes.
when all three lights are blinking its indicating that the lamp may be defective.
Sep 26, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Samsung 1080i compatible tv 42 inch
This is very common with Samsung and is considered a overheating or lamp issue. cheapest fix before changing out the lamp is to unplug the unit after it has shut off its fans and open the back up and blow all the vents and circuit boards off with can of compressed air. Then remove the lamp to get to the larger fan that is behind the lamp, be carefull to not let the fans to spin when you hit it with the air because it will spin the fans faster than they are ment to spin, so gently place a finger on the blades just enough to keep the fan still and clean off any dust you see on the blades and area. Put everything together and give it a test run. If it stays on longer you know it was just to dusty to stay cool , if no change then try the lamp.
Sep 12, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Projector indicates overheating and shut down
HI there
Apr 21, 2008 | Eiki LC-X50M Projector
Televison & Video Logo
44 people viewed this question
Top Televison & Video Experts
