Question about Dell Computers & Internet
Dell Monitor power button doesn't work. When I
Dell Monitor power button doesn't work. When I unplug and plug back in the screen and power button blink on/off several times. Eventualy it will work when I plug it in. Help.
  • 86 Answers
SOURCE: check signal message when data cable unplugged. blank screen when data cable plugged
This problem is most likely to be caused by a bent or broken pin on the CRT video cable at the VGA connector, OR, this could also be caused by a damaged VGA connector on the back of the laptop. If neither VGA connector is at fault, the problem could be caused a damaged (kinked) CRT data cable, or internal damage to the VGA connector on the back of the laptop, though I suspect the problem is more likely to be external, and you probably won't have to disassemble the laptop to locate the culprit...
Posted on Mar 31, 2007
SOURCE: Dell E172FP 17 monitor keeps blinking
That sounds like the backlight inverter board. Check ebay for the board or a repair kit for it.
Posted on Oct 23, 2007
skotkolr
  • 558 Answers
SOURCE: dell 17'' flat panel monitor power light is blinking
some transistors on the board have shorted they supply power to the inverter to run the lamps, they power is not cut off intermittently and the protection circuit has stopped the monitor. the fix is here
http://josepino.com/other_projects/?howto-repair-dell
goo dluck if you want it fixed for you let me know
Posted on Mar 22, 2009
  • 1684 Answers
SOURCE: Dell monitor shows blank screen, green power light stays on
You have a monitor with a common problem. After a few years some LCD monitorswill blow a power supply. The problem is caused by parts calledcapacitors overheating in the confined space of he monitor. If you aregood at electronics repair/soldering you can usually fix he problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htmYou can take the back cover off your monitor and look for the bad parts,replace any that look like the pictues and your monitor should workfine. The capacitors do need to be installed with the correct + and -connections, note the stripe on the old one and insert the new one thesame way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping. I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Posted on Jul 03, 2009
  • 1684 Answers
SOURCE: Dell Monitor Problems
It sounds like you have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of the monitor. If you are good at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping.
Buddy
Corporate Computer
www.ccl-la.com
Posted on Jul 17, 2009
My monitor will go blank and the power button flashes on and off but the screen is blank. whats the problem
You may need to reset it. Just search google for "how to reset MODEL NUMBER monitor" and find your answer. Usually it consists of unplugging the monitor, holding a button or a combination of buttons, the plugging the monitor back in.
good luck!
Oct 26, 2015 | Dell Computers & Internet
My insignia flatscreen tv monitor doesn't work. I
Shut off the tv, unplug it, hold the power button on the tv for 90 seconds. Plug it back in. Hit menu? Do you see a menu? (if not, your tv needs serviced)
You might also have a cracked LCD.
Jul 01, 2012 | Televison & Video
I am unable to turn the screen off and the Menu button, actually, none of the buttons on the screen works. It constantly shows the Volume in the centre of the screen and I cannot remove it. Please help! ...
If none of the button are working then it could mean that one of the buttons is stuck or there is an issue with the board on the monitor itself.
Unplug the monitor from power and the computer. Make sure none of the buttons are stuck down, plug only power back in to the monitor and see what it shows. Plug it back into the computer and check to see if the problem returns
Mar 07, 2011 | Acer AL1715 (Black, Silver) 17" LCD...
Power Save mode on, can not use computer
If your computer is indeed running, simply unplug your monitor from the wall, and then plug it back in. This will bring your monitor out of power save mode instantly.
Apr 22, 2010 | Dell Dimension 8400 PC Desktop
The power switch does not switch (no click)
Unplug the monitor from the power
Unplug the monitor from the computer
Plug the monitor back in.
Try turning it on.
DOES IT SAY "NO SOUCRE DETECTED" or soemthing like that???
if it DOESN'T it means there is something wrong with the computer.
if it DOES:
plug it back on to the computer, turn the computer power off.
Press and hold the power button on the computer for about 15 seconds.
Plug the computer back on.
Try turning the computer on.
if it's not turning on again there a problem either with your monitor cable, or the plug, or the video card plug. It is unlikely that your video card is broken if you hear no wired series of short and long beeps when you try turning the computer on.
Good luck.
Give us updates if you need more assistance
Aug 11, 2009 | Dell UltraSharp 1907FP 19" LCD Monitor
Dell E173FP Monitor requires unplugging/plugging back in to wake
Perhaps your computer is hibernating instead of going into standby which takes a little longer to wake up from. While you are playing plugs and cables it give it enough time to come out of hibernation.
When the computer is in this mode the USB ports turn off which disables keyboard and mouse so the only way to wake up the computer is to press the power button on the computer itself.
One tell tale sign a computer is in hibernation is that the power light on the computer will slowly blink.
I hope this helps.
Aug 08, 2009 | Dell Computers & Internet
The on off button on front doesn?t turn the unit off and on
Same here, your light went out if you put a VERY bright light on you'll be able to see something on the screen if you plug it up to your computer, if you are getting a new one go dell its worth it becase they last and are durable.
Jul 03, 2009 | Gateway FPD2275W LCD Monitor
Monitor problems all of a sudden
Replace your monitor power cord.
Apr 27, 2009 | Computers & Internet
Dell E173FPc monitor. Screen is black, power button color cycles
First, verify the monitor is functional.
Monitor STFC (Self Test Feature Check)
Turn off the monitor
Plug the monitor power cord directly into the wall socket to remove any
surge protectors or APCs from the troubleshooting equation
Unplug the monitor video cable from the back of the computer
Turn on the monitor
The floating dialog box should appear on screen against a black background.
If the issue appears during the STFC, the monitor is defective.
What are the results please?
Feb 24, 2009 | Dell E173FPc 17" TFT LCD Flat Panel...
Sceptre X7g Monitor Flashing Red & Blue Lights. Blank Screen
i fixed this problem by unplugging the monitor, unplugging the video cables. Then hold down the power button while plugging it back in. Release power button and then press power button for on. It worked then. I got the icon for no signal, i plugged back in my monitors. Sceptre X9W
Sep 11, 2007 | Sceptre X7GNAGAV 17" LCD Monitor
Computers & Internet Logo
96 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
