Question about Yamaha 12V Air Pump
I have a 1994 waverunner 3 that bogs down when I accelerate, and I also cannot find the flush port.
4 Suggested Answers
SOURCE: Waverunner bogs down on acceleration
Hi im sorry for your problem we BUY these things to have fun but they seem to hate us at times i had the exact problem on my 1200 waverunner if you have the stock cadilatic converter you might have burned it especaly if you dont use the YAMALUBE W-2 OIL. if you did every thing the book asked you to do as far as trouble shooting i know this is the problem. now if you have a cadilatic converter D PLATE asembly wich removes the converter completly this is a high performence item your computer might be going haywire because you need a chip just google d plate and chip and you will find it your problem is defenatly in your exhust system i hope this helpes my e mail is integrags_130@yahoo.com
Posted on Jun 25, 2009
SOURCE: 1997 yamaha waverunner 3
My 97 gp760 did this. I checked almost everything. Replace or clean your plugs, then run carb cleaner through your fuel filter both ways, and then spray carb cleaner into the fuel line from the fuel filter to the carbs. Run 10 minutes, more carb cleaner into the fuel line, and run it 15 more minutes. Then zip tie fuel lines at the fuel filter. I figure there was trash or buildup in the carb. Its easier than rebuilding the carb. Try it. Daniel at the MEXPIPE Pto Escondido Oaxaca.
Posted on Jul 27, 2009
SOURCE: I have a 2002 yamaha waverunner xlt 1200. it will
hate to break it to you. carbs need to be rebuilt. the new fuel doesnt bode well for the carbs, clogs a really small filter and jets in the carbs
just had it done for the second time for a cost of $550/each time
Posted on Aug 09, 2009
It Runs but has very little power,quits often,if you give it to much throttle it bogs down
Robert, First try new plugs, check fuel filter, sounds like it could be carburetor/injector issue, dirt,plugged jet, etc. Remove and clean/rebuild carb./injector.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
XLT1200 Bogs down
Thread 2004 FX HO ECU Problem
Waverunner Loses Power and Wont go Above 35 mph Solution
https://answers.yahoo.com/question/index?qid=20080525091900AATkgJh
May 23, 2016 | Yamaha 2004 WaveRunner Superjet Base
What causes bog down when accelerating?
Car bogs down when I accelerate !!! - Car Forums and Automotive ...
www.automotiveforums.com > ... > Cavalier > Cavalier Problem Diagnosis
I have a 1994 Cavalier 4cyl and it bogs down and struggles when I come from a dead and try to accelerate and sometimes when I get upto 55-60 mph it does it ...
Sep 26, 2015 | 2001 Pontiac Grand Prix
1994 Geo Metro won't accelerate past 1/2 way through each gear. When it gets half way through first gear, the car bogs down and won't accelerate further. Shifting into second, it lugs until half way...
I would pay more attention to the air flow sensor and mass air flow sensor, putting this on a diagnostic machine will pinpoint the errors stored on the onboard computer. both sensors can be cleaned by a competent mechanic, most mechanics don't want to, they prefer just to swap items out these days because of costs. get a reading, then you will know for sure. good luck.
Oct 20, 2013 | 1994 Geo Prizm
Engine bogs down going down the road and on acceleration
Could be plugged fuel filter. When you accelerate the engine demands more fuel and if it does not get it your engine will struggle to accelerate
Sep 06, 2012 | 1994 Honda Civic
Need Help On A 1994 Yamaha Waverunner 3
Check your pump and impeller, then trace water inlet hose from back to front, possibly have a flush kit thats missing the cap?
Apr 30, 2012 | Water Sport
91 waverunner overheats. it runs fine for about a minute then wont accelerate. When i remove the heat sensor it will accelerate but not as smooth as when it first starts.
THIS IS BAD ,,,THE HEAT SENCER IS THERE TO KEEP THE INGINE FROM BLOWING UP ,,,I RECEMEND THAT YOU CHECK THE WATER OUTLET PORTS TO MAKE SURE THERE CLEAR ,,,HOOK UP YOUR FLUSH HOSE AND FLUSH OUT YOUR COOLING SYSTEM ,,,IT COULD BE BLOCKED SOMEWHERE ,,,,MAKE SURE THAT WATER COMES OUT OF YOUR FLUSH PORTS AND THAT WATER IS COOL TO THE TOUCH,,,HOPE THIS HELPS..
May 16, 2011 | Boating
1994 Yamaha Waverunner 3 will idle but wont take throttle
1994 700 cc waverunner when it has run for 15 min engine bucks at full throttle at 3/4 ok i have changer plugs antreated fuel
Aug 01, 2009 | Yamaha 12V Air Pump
Our 1996 waverunner has been running great until this weekend. It seems to bog down after 3 minutes of running at full speed. If you keep it at 3/4 speed no problem, it runs steady. Tried carb cleaner but it still runs the same....What repairs are we looking at. thanks.....
Jun 15, 2009 | Yamaha 12V Air Pump
On a 1994 lebarron, it starts and but bogs down when u accelerate
Hook up a fuel pressure gauge to check the pressure.
Mar 01, 2009 | 1995 Toyota 4Runner
Yamaha 12V Air Pump Logo
203 people viewed this question
Top Yamaha Water Sport Experts
Colin Stickland
Colin Stickland
Piyal Perera
Piyal Perera
Are you a Yamaha Water Sport Expert? Answer questions, earn points and help others
