Question about TruTech PVS31170S1W 17 in. LCD Television
We moved our TV from it's normal spot (hooked into different power source and cable outlet) and now it's dead. It won't turn on at all. We moved it back to it's old spot and still no luck. We bought it exactly a year ago. It can't be dead already can it? This it the 17 inch flat panel
  • 31 Answers
If it was plugged in during a power surge without a surge protector, there is a possibility it could be dead. Or if it was plugged into a new outlet without a surge protector, especially if it was never properly shut off before the move, that could kill it. Try unplugging everything and letting it sit for 30 seconds, then try again (with a surge protector if you have one)
Posted on Oct 04, 2009
Which cable outlet do i hook tv to for cable
most RV's have a selector box that takes signals in from all the different sources and directs them to the cable going into the TV. Should be marked "To Tv" or something similar. Then you just select the source as Cable.
Feb 28, 2015 | Keystone 2014 Outback 277RL
I have a 55" Panasonic flat screen that won't turn
Try disconnecting all of your HDMI cables and plugging the power cord of the TV into another wall outlet. If this resolves the issue, you may have had a small power surge from either your wall outlet or one of your source devices. It is recommended to connect your TV to a surge protector if you haven't done so already.
Sep 29, 2013 | Televison & Video
Power and OPC Lights flash twice and TV won't power on.
see this steps and fix it. God bless you
    • 1
      Press the power button on the TV and not the remote control. It is possible the remote control's batteries are dead. If the TV does turn on, you know you need to replace the remote's batteries.
    • 2
      Disconnect the power cable from the TV, then insert it into a different electrical outlet. On occasion outlets are damaged, and do not provide a power current. If this is the case, changing the electrical outlet connection corrects the problem.
    • Sponsored Links
    • 3
      Switch the television's input to a different connection. It may be possible you have the wrong input selected, causing the TV to give off a black screen.
    • 4
      Connect a different source device (such as a DVD player or cable receiver) to the television. If the source equipment is damaged, you will not receive an image from the hardware. If the TV still does not display an image, there is an electrical shortage in the interior of the TV. To see if there is any way to fix this issue, you need to take it into a local TV repair shop.
Read more: http://www.ehow.com/how_7308433_flat-screen-tv-won_t-turn.html#ixzz2ZROWyhSB
Jul 18, 2013 | Televison & Video
OPC and Power green lights blink twice, tv will not turn on.
follow this instruction and fix it. God bless you
    • 1
    • 2
    • Sponsored Links
    • 3
    • 4
Jul 18, 2013 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp aquos won't turn on
if it was a new tv you can ask the supplier for check up it was covered with warranty.
Sep 22, 2012 | Sharp AQUOS LC-22SB28UT 22" LCD TV
Daughter's TV was on during bad electrical storm. Screen went black and made high pitched sound. cable, internet and telephones all digital through Time Warner Cable. Now TV will not even turn on;...
Ur Main Fuses in the circuits breaker box must be to be restart it back.Turn off/on all the fuses on the main circuits breaker box to all the fuses in the box of the box to restart.All ur electical power outlets should work again.If not those power plug in outlets are shorted and dead must have to be replaced.
Aug 22, 2011 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
I have a Citizen C802DVD, that is dead, no power at all, what can be the problem? thanks for your help.
Instructions
    • 1. Press the power button on the TV and not the remote control. It is possible the remote control's batteries are dead. If the TV does turn on, you know you need to replace the remote's batteries.
    • 2 . Disconnect the power cable from the TV, then insert it into a different electrical outlet. On occasion outlets are damaged, and do not provide a power current. If this is the case, changing the electrical outlet connection corrects the problem.
    • 3 . Switch the television's input to a different connection. It may be possible you have the wrong input selected, causing the TV to give off a black screen.
    • 4 . Connect a different source device (such as a DVD player or cable receiver) to the television. If the source equipment is damaged, you will not receive an image from the hardware. If the TV still does not display an image, there is an electrical shortage in the interior of the TV. To see if there is any way to fix this issue, you need to take it into a local TV repair shop.
Feb 02, 2011 | Vizio 42 in. LCD TV
Tv powers up but will not turn on
A flat screen television is any TV with a flat glass front (instead of the older, rounded televisions). These televisions do not necessarily need to be thin--projection TVs have a flat screen but are still a foot or two deep. If you find your television does not power up properly, you need to troubleshoot the problem. The exact reason may vary, and hopefully you are able to correct the problem. (If the TV has shorted due to an electrical surge, you can't do anything about it).
Difficulty:Moderately Easy Instructions
    • Press the power button on the TV and not the remote control. It is possible the remote control's batteries are dead. If the TV does turn on, you know you need to replace the remote's batteries.
    • Disconnect the power cable from the TV, then insert it into a different electrical outlet. On occasion outlets are damaged, and do not provide a power current. If this is the case, changing the electrical outlet connection corrects the problem.
    • Switch the television's input to a different connection. It may be possible you have the wrong input selected, causing the TV to give off a black screen.
    • Connect a different source device (such as a DVD player or cable receiver) to the television. If the source equipment is damaged, you will not receive an image from the hardware. If the TV still does not display an image, there is an electrical shortage in the interior of the TV. To see if there is any way to fix this issue, you need to take it into a local TV repair shop.
Jan 09, 2011 | LG Televison & Video
My Pioneer Elite PRO-111FD just shut off on it's own, and now won't turn back on. No green or red indicator light... nothing. Any suggestions?
Check your power source (electrical outlet) and the power cable. If electrical outlet is ok, try using a different power cable (the cable that you plug on to the electrical outlet going to your TV set). If everything is ok but still no indicator light, call your technician there might be a problem with the TV power supply.
Sep 08, 2010 | Pioneer Elite PRO-111FD 50 in. Plasma TV
PS3 static on screen
It sounds like you're carrying interference to your TV. Try moving you station away from any power source. Make sure your hdmi cable is away from any power as well. This may also be a ground issue. Plug your ps3 power brick into a different outlet.
May 14, 2009 | Sony PlayStation® 3 (80GB) Console
TruTech PVS31170S1W 17 in. LCD Television Logo
124 people viewed this question
Top TruTech Televison & Video Experts
Radames Pagan
Radames Pagan
Jason Morris
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
