Question about Gateway 503GR PC Desktop
My Gateway 503 gr quit turning on. At first it chattered a little and then went dead. Now it won't even do that. The power supply has been replaced with a new one but no change. I need to see if the power switch is broken but where should I look next? The CMOS battery? HDD? A fuse?
  • Vaio Tech
    Vaio Tech Oct 04, 2009
    LOOK THIS TYPE OF GATEWAY DESKTOP HAVE A NOW ISSUE OF THE MOTHERBOARD GOING BAD BECAUSE OF A 915 INTEL CHIPSET BE A PROBLEMATIC CHIPSET TRY TO REPLACE THE MOTHERBOARD WHID THE NEW CHIPSET EFFICIENT G31 G45 MOTHERBOARD AND YOU WILL HAVE PC FOR YEARS TO COME
    Scholar:
  • 67 Answers
Check the condensators. If there are not any blown condensators or leakage, keep the video card (or at least the one on board if any) and remove all the other cards, also the memory. Check the CPU with a known good motherboard. If the CPU is ok begin by adding the memory, one bar at a time (you may alternate the slot also). If the computer do not start the motherboard is defective . If the computer starts but no sound is heard motherboard could be defective. Try to install a previously checked memory. If you do not get any signal the board is dead. If you get video signal, add one card at a time until you identify the bad component.
Posted on Oct 05, 2009
My comp start but the os not show up the os on screen just tge gateway banner
Posted on Jul 25, 2010
Gateway GM5472 won't boot no power
No power and won't boot suggest a power supply problem in the tower--it is listed as a desktop unit.
What is common on a lot of units (computer towers, TV sets, you name it) is the stand by power supply which is on 7/24 fails.
The most common reason is filter caps dry out because cheap ones and ones rated too low a voltage are used.
The beauty of this is if the power supply is removed and opened you will be able to SEE the bad ones.
I will attach a photo of bad caps--tops which should be perfectly flat are puffed up from a little to a lot and or brown material is seen at top and bottom of the cap.
I have fixed many towers (desktop units) and other equipment with this problem---most of them at first had to be turned on a few times to get them to come on--it gradually gets worse until it will not make it on.
If bad caps are found you can usually buy a replacement supply at a reasonable price or replace the puffed up caps (seen as many as 8 bad in one computer tower).
This answer is based on the information you provided in your question and the answer from personal experience.
SD TECH
4_25_2012_5_11_26_pm.jpg the two larger ones are bad for sure.
Apr 25, 2012 | Gateway GT5220 PC Desktop
I went to turn on my Samsung a little bit ago, which was working earlier today, and now it won't turn on and is making a clicking noise. The noise does not stop until 10 seconds after I unplug it...
The tv power supply board it got short and already dead some how,tv have clicking noises mean ur tv power supply board are not stable and not regulating high voltages to the rest of the tv other boards.The tv power supply board that the board where the a/c power cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish tv power supply board for the replacement.
Aug 13, 2011 | Samsung LN46A650 46 in. LCD HDTV
We were watching tv and the screen went black, the sound got quieter and then it turned off. We left it overnight and now it won't even turn on. The red light isn't on to indicate the tv is off. We...
Your power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Hope this will help in solving the problem...
Jun 26, 2011 | ViewSonic N3252w 32 in. LCD Television
My Gateway FPD2275W LCD monitor went complely dead. I order cap kit and replace all 9 caps in the power supply. Of the 9 , 4 looked bad. Reassembled everything and now get the tones and the blue power...
Can be that
other components have also failed each unit can have additional problems remaining
after replacing the caps.
Sprint6@zominternet.net
also
interested in purchasing any units that have been deemed non repairable.
Feb 09, 2011 | Gateway FPD2275W LCD Monitor
Dead gateway
That is most likely the power supply, check your cord in the back and make sure it is firmly seated. You may need to replace the power supply, and can getthem online for $50.00 You can check with another extension cord to see if the outlet is bad, if it still dn't wotk you will have to replace the power supply if no lights atall come on. I have had to replcae a few in the gate way, Virus's won't kill power supply.
Oct 15, 2009 | Gateway 3250X Media Center PC Desktop
My gateway 540 gr start for 5 seconds and turn off, the fan starts to then turn off.
Disconnect everything except for the power to the motherboard. If you turn on the computer and everything still turns off, then try another known working power supply. If the machine stays turned on then connect power to your drives one at a time with the computer off each time to see which drive is the culprit.
If everything still turns off then reseat the CPU and the memory and if it still turns off then that means the motherboard is bad and it would need to be replaced.
Jun 25, 2009 | Gateway 500GR PC Desktop
Gateway 500xl pc will not turn on power button is lit up yellow
A LOT of Gateway computers will go into this catatonic state because of a dead battery. The battery is on the motherboard -- it looks like a metal disk about 1" in diamter. Check it or replace it. This applies to laptops too (not the actual laptop battery, the CMOS battery -- a laptop will have one on the motherboard too)
Hope this helps
Mar 13, 2009 | Gateway 500XL PC Desktop
Gateway 504 GR No Power.
I had the same problem. Turned out to be a bad power supply unit. Once it was replaced, machine was back to normal.
Jun 26, 2008 | Gateway 500GR PC Desktop
Gateway 503GR PC Desktop Logo
255 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
