Question about Lexmark Photo Printer, Scanner, Copier and Fax
How do you recieve a fax? I had a person send me a fax and the fax he said went threw but the machine did nothing.
  • A Miller May 11, 2010
    You are hooked to the telephone line? Did you hear the phone ring? This is in a home situation? Can it be that the machine stored it in memory because it was told to do so or there was no paper? Does this all in one scan? Copy? Print?
Ajkill
  • 2035 Answers
SOURCE: Fax Machine
Turn the printer off and open the access cover.
Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
Watch the paper as it feeds through and try to determine where the jam is occurring.
Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
Turn the printer off.
Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Posted on Mar 13, 2008
  • 79 Answers
SOURCE: will not recieve faxes
Hi i'm an ex HP employee
i got this information from HP's website
  1. Phone company services: Do you have any of the following telephone line services from your telephone company: Voice Mail, Privacy Block, Security Screen, Anonymous Call Rejection, and Privacy Manager. These phone services are meant to prevent unwanted calls, but they will also stop faxes. Contact your telephone company for their recommended solution for receiving faxes on the same line with these services.
  2. If you wish to receive faxes automatically, verify that automatic answering is enabled on models that have an Auto Answer button, or that the Rings to Answer setting is set to a number equal to or larger than one for models that do not have an Auto Answer button. On models with an Answer Mode setting, it should be set to Fax, FaxTel, or AnswerMachine depending on your setup.
  3. If you have a HP PSC 2200 or an Officejet 6100 that interrupts calls or will not receive faxes, download and install the HP Firmware update for these products.
    1. Visit the HP Support and Drivers Home page .
    2. Select Download drivers and software .
    3. Type in your model number (HP PSC 2210xi for example).
    4. Click the search arrow to the right of the text entry box. You may be asked to select your product from a list of models.
    5. On the software download page, select your Windows version.
    6. Locate and select the firmware update.
    7. Follow the directions to download and install the update.
  4. If an answering machine is connected to the same line, fax reception problems can occur. These problems may be corrected by changing settings or phone line connections. For more information on using a TAM or distinctive ring service, go to Using the HP All-in-One and Fax Products with a Telephone Answering Machine (bpu04072).
  5. If you have a PBX phone system, or an ISDN or DSL modem connected to the line, there may be some phone line configuration problems. Fax machines are analog devices and cannot be used on a digital phone service such as those used in many businesses (PBX systems). Install an analog phone line for a fax machine. Refer to document Using an HP All-in-One or Fax Product on a PBX, ISDN, or DSL Phone System (bpu50333) to learn how to correct these problems.
  6. If the problem still exists, continue troubleshooting in the Faxes cannot be sent or received or you're not sure of the problem section below .
this is the link http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu02151&lc=en&cc=us&dlc=en&product=441125&rule=2043
hope it works out
thanks
Posted on Jun 04, 2008
  • 48 Answers
SOURCE: CAN'T RECIEVE FAXS
Make sure the Auto answer the button is on....
Or
Reset the printer setting to default and set the rings again to 3...and try..
Posted on Jun 26, 2008
old marine
  • 2039 Answers
SOURCE: Cannot recieve or send faxes
Check out the Easy Setup Instructions available here. If you can neither send nor receive faxes, you may not have the phone line connected to the correct port, see page 34 of the guide. Also check what receive mode the machine is set for. Pages 42 and 43 explain the different options and how to change the receive mode.
Posted on Mar 16, 2009
  • 77 Answers
SOURCE: i am unable to send faxes or recieve faxes
Please follow the steps given below to check wheather the error correction is turned off.
You need to disable "Error Correction," please follow the steps given below:
1. Press "Fax Mode."
2. Press "Menu."
3. Press "Up" or "Down" Arrow button repeatedly until "Ringing and Answering" is highlighted.
4. Press "Select."
5. Press "Up" or "Down" Arrow button repeatedly "Error Correction" is highlighted.
6. Press "Right arrow" or "Left arrow" button until "OFF" appears.
7. Press "Select."
Please follow the steps given below to recieve the fax:
1. From the control panel, press "Fax Mode."
2. Press the "Menu" button once.
3. Press up or down arrow repeatedly until "Ringing and Answering" is highlighted.
4. Press "Select."
5. Press up or down arrow repeatedly until "Pick-Up On:" is highlighted.
6. Press left or right arrow to choose an option.
7. Press "Select."
If you want to set a schedule to turn "Auto Answer" "on" or "off:"
1. Press up or down arrow repeatedly until Auto Answer Scheduling is highlighted.
2. Press left or right arrow until "On" appears.
3. Press "Select."
4. Press down arrow button to select the time for "Auto Answer On."
5. Use the keypad to enter the date and time. Press 1 for AM, 2 for PM, or 3 for 24-hour mode.
6. Press down arrow button to select the time for "Auto Answer Off."
7. Repeat step 5.
8. Press "Return" button to save the settings and exit the menu.
9. Make sure the "Fax Auto Answer" light is on.
When the number of rings you set is detected, the printer automatically receives the incoming fax.
To scan a document, please follow the steps given below:
1. Go to "Start," "Programs," Lexmark printer, "Lexmark All-in-One Center."
To see how an image will look after it is scanned, click "Preview Now."
2. Click "Scan," "Send scanned image to."
If scanning an image, choose a graphics program such as "Lexmark Photo Editor," "MS Paint," etc.
If you wish to "Scan to OCR," choose a text program such as "MS Word," "WordPad," etc.
Once the image is scanned, the "Abbyy OCR" software will open automatically.
3. To begin the scanning process, click "Scan Now."
4. To view the additional options, click "See More Scan Settings."
To indicate what type of image is being scanned, select the "Option" next to the type of object you are scanning. Your settings will be optimized for that object type.
To indicate how the scan will be used, select the relevant option from the menu. Your resolution and other settings will be optimized based on your selection.
5. To revert back to the normal All-in-One main page, click "Hide Extra Scan Settings."
6. Under "Display Advanced Scan Settings"; you can see change settings, which will affect the outcome of your scan.
Posted on Apr 27, 2009
We are not receiving faxes..we keep getting error code 407..Please help? Thank you.
The message means:
407 No confirmation from the receiving station for the
previous page sent.
Wait a few minutes and send again.
This can mean 2 things
1) you have not set your fax machine to recieve faxes
2) you need to have your fax machine serviced because the part that makes it pickup a fax has malfuctioned
Clean all paper paths with paper path cleaner.
Unplug and then after 10 seconds replug the fax machine and do a test recieve for it
If all else fails, you may need to call a service person to repair or replace the broken or defective part that recieves faxes.
Hope this helps :)
Mar 16, 2010 | Panasonic Panafax UF-890 Plain Paper Laser...
Fail to send and recieve
Well it was fixed after I called our telephonecompany.
They told us last Thursday that the lina was ok, but yesterday I talked to a extremely competent callcenteragent and he could confirm the problem lay in the connection.
So, it wasn't a problem wit the JX200 after all.
Jun 03, 2009 | Canon FAX JX200 - Fax / copier - ink-jet...
Fax machine sending but not receiving --help me!!
Check the settings and see if it went into "memory" mode. They may call it somthing else in the menu so check the manual if you have it.
Mar 23, 2009 | HP 1040 Plain Paper Inkjet Fax
Cant recieve fax
please help me how to switch my machine Brother MFC440cn to fax/tel mode.
Oct 26, 2008 | Brother MFC 420CN All-In-One InkJet...
Samsung SF 3200
The person you are sending to has a busy phone line.
Call your cell phone from the fax machine to test.
Oct 24, 2008 | Samsung SF-3200 Fax
1840C Brother fax machine
Do you have ink / toner / paper?
Unplug the power cord for 10 seconds.
Sep 08, 2008 | Brother IntelliFAX 1840C Plain Paper...
Can't recieve fax
hello jimb 1
check the faq on here see if any guide Customer Support
riz.
May 13, 2008 | Lexmark X7350 All-In-One InkJet Printer
Brother fax 930 machine
I would try sending to another source. If the document goes threw the machine and you get a confirmation report saying it was sent, then it was sent. The person on the other end may be having trouble with their machine as well.
Aug 03, 2007 | Panasonic KX-FP85 Plain Paper Thermal...
Can't send any faxes
Hello,Mafriend,It sounds like you might have recieved a Fax machine that Recieved a surge,To verify this Ck the Jack where the Phone line goes in to see if you have any type of discoloration there,also see if it locks up your phone line from making calls or recieving Them ttech
Jul 20, 2007 | Panasonic Panafax UF-560 Plain Paper Laser...
Lexmark Photo Printer, Scanner, Copier and Fax Logo
12 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
