Question about Mitsubishi MSH09TW Air Conditioner
Indoor unit is dripping water during operation. Have tried "Dry" mode, but there water standing in bottom tray.
  • 3,230 Answers
Please check all the followings -
1. Ensure the air conditioner is installed properly. Window units should have front slightly higher than the rear of the air conditioner. A 1-inch difference between the front and the rear is sufficient for proper draining. This allows the water to roll out the back of the unit. If the front is lower than the back, then water can drip into your home.
2. Prevent a warm airflow from settling around the air conditioner. If your air conditioner is in a position where there is a flow of warm air, condensation occurs. The condensation can cause a buildup of water that may drip inside of your house.
3.Unblock the air conditioner's drain hole. The back of an air conditioner has a hole or groove that allows water to escape and drain off. If it clogs, the water cannot flow and may back up and drip inside your home.
4.Check for icing. If your cooling coil is icing up, the melting ice may drain into your house. If you can access and check your air conditioner's cooling coil and find ice forming, contact a service professional.
Good Luck!!
Thanks
Posted on Oct 04, 2009
Kenmore refrigerator model 795
This is a simple fix but will take a little time to correct this. First of all, empty the freezer of food and shelving, ice maker if you have it also. The back wall in the freezer is a false wall, so gain access by removing screws and harness from top left corner. By the way turn off the unit or unplug it!! Now at the bottom of the unit far back you will see an ice glassier in the bottom middle is a drain hole that all the water is to exit after defrost. Well because its blocked with ice the water overfills and leaking into the refer section. Make sure you can use hot water to clear this out but make sure you cleaned out the entire drain system before reassembling this to restore cooling. Once clear you problem is solved.
Good Luck
Oct 29, 2013 | Refrigerators
I have an SA12059 Windchaser portable a/c. After using it and rolling it around, the top condensate tank drips lots of water. I tried to drain the bottom tank via the hose, but the top tank doesn't seem...
There is not actually a top tank, just a drip tray with little drain holes that become easily clogged. After removing the rear cover of the unit and cleaning thoroughly, you can use a can of air (like the ones to dust pc's) wth the little straw attachment to try to clear te clogged drain holes in the tray below the evaporator. If your unit froze up condensate may have overflowed into the fan area. Let the unit defrost, and run it in fan mode for awhile to dry this moisture out.
Sep 01, 2013 | Windchaser PAC9 Air Conditioner
Bosch WFVC6450UC Washer leaks at bottom
How about loose fill hose connections?
How about incomplete shutoff of the internal fill control valve between wash cycles?
Sep 22, 2012 | Bosch WFVC6450UC Front Load Stacked Washer...
Dripping water from portable aie condtioner
Remove the rear cover and clean the unit throroughly. Use a can of air duster with the little hose to carefully clean the drain holes in the drip tray under the evaporator (upper radiator) let the unit fully defrost, drain the unit from the bottom plug. Clean the fins wth a toothbrush and windex if needed. Reassemble and run the unit in fan mode for an hour to let it dry out.
Jul 08, 2012 | Windchaser PAC9 Air Conditioner
Et 18nkxfno-1 water dripping from top and going into bottom draws
Appears you have a drain blockage.
Switch off fridge let it stand for a couple of hours . At the rear bottom you will find a compressor and a drip tray . Above the drip tray there should be a tube that drains water from the freezer compartment. Using a stiff wire try and insert it into the drain tube thus clearing the blockage.
Aug 05, 2011 | Whirlpool Refrigerators
I have a cv615 Miele Coffee Machine. The water reservoir was not inserted properly and water leaked into the bottom of the machine (drip tray). We got the Water System Fault message, so we removed the...
just use your hair drier to dry out the remaining water.Before doing anything remember to unplug the device.Remove the tray and other such attachments and let it to dry by itself for a day or two.this should solve the problem.never plug in the device till then.
regards.
plz. rate this
Jul 04, 2011 | Microwave Ovens
Water is leeking from bottom of unit.
If this is a mini split system, with the indoor unit mounted up on the wall, and water is dripping from the coil, I would say that the condensate line has a partial plug. Take a ladder and remove the front cover. It may have screws or just snap in place.You will see a drip tray around the perimeter, and dirt from the foam filter sometimes gets into this tray and will over flow.You may be able to see the plastic drain line going to the out side, and may be able to clear it by blowing through it or using compressed air.You could also lay something on the floor and take a picture of water and try washing the dirt and junk free.Wash the filter out while you have it out.I hope this solves your leak problem, i am confident it will.
Good Luck, Shastalaker7
Nov 01, 2009 | Heating & Cooling
I have a George Forman GRP46R. I'm having a drip tray problem where the grease is going under the unit and then dripping from the bottom. Some of it goes in the tray but the majority of it goes under the...
Since I accidentally left my drip pan inside the unit and preheated the unit without checking, I am now without a drip pan. The unit really heats up fast and likes to melt plastic. Anyhow, I used a cookie sheet underneath that has a lip around it to catch the drippings. I would suggest that you place your whole unit on a cookie tray so no matter where the grease runs out it will go on the cookie sheet and not your counter.
Oct 14, 2008 | George Foreman GRP4P Indoor Grill
Leaking water
water leakage from indoor unit
1.clean cooling coil
2. wash air filter
3. check drain tray.if it block then clean it
4. check drain pipe U band.
5.check indoor unit water tray.if damage change by new one or repair it
Sep 04, 2007 | Friedrich QuietMaster RS10J10 Air...
Fujitsu wall mounted air conditioner.
 during Cooling and Dry modes, if the unit is used under conditions of
lower temperature (18C)  the heat-exchanger may freeze, leading to water leakage and other damage.
If the unit is used for long periods under high-humidity conditions, condensation may form on the surface of the indoor
unit, and drip onto the floor or other objects underneath. (About 80% or more)
Increase Temp to 20 and also run coil dry cycle,
Jun 03, 2007 | Fujitsu 24C1 Air Conditioner
Mitsubishi MSH09TW Air Conditioner Logo
251 people viewed this question
Top Mitsubishi Heating & Cooling Experts
D. E. Hev
MightyMikeJr
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
