Question about Canon PowerShot S3 IS Digital Camera
Fix my on off switch
Somehow the on off switch for my Canon Powershot S3IS is lifited.. so to turn it on i have to press it down then move it to the on position.. the off button no longer works an when i try and click the knob down to put it back to normal there is a click and then it just pops right back up.. help!!!
bmwrider
  • 215 Answers
SOURCE: Canon Powershot S2 IS Super Macro mode
Make sure your camera isn't zoomed in (full telephoto) The camera can't handle both full zoom AND super macro. Don't forget super macro goes from Zero to 20cm from the lens. Zoom completely out and you should be able to see something within that range. The biggest complaint I've heard about the S2 IS is if you take closeups of bugs the chances of the bug crawling onto your lens is pretty good.:-) Be very carefull of blocking light with the lens at extreme closeup too. Although the flash squelches well to allow for closeups it can leave a nasty shadow. If you're really serious about macro you'll find a ring flash would come in handy. BMW
Posted on Jul 14, 2006
JoshOHoward
  • 63 Answers
SOURCE: lens won't extend
The lens is jammed meaning you are going to have to open it yourself you should onlyhave todo that once and itshould work again
Hope This Helps - Josh
Posted on Jan 30, 2008
SOURCE: My Canon Powershot A630's flash
I was having the same problem...
1. I took off the two screws on side closest to flash
2. Removed side cover
3. Gently wiggled the round silver capacitor at the top that is wrapped with a black film
4. Voila... the flash worked and I put the cover and screws back.
I think over time that little capacitor detaches because of the vibrations. Hope it's of help.
Posted on May 16, 2008
informatica
  • 1114 Answers
SOURCE: canon s3is driver
Hi - You can download the software from the link underlined in blue below:
canon s3is
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Posted on Aug 25, 2008
t00nz
  • 4738 Answers
SOURCE: Neither viewfinder will work - nothing appears
It could be a stuck shutter. To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Posted on Jun 25, 2009
Why can I not get my Canon PowerShot S3 IS to switch to the PLAY mode?
Search Results
    [PDF]Manual
    gdlp01.c-wss.com/gds/3/0900001323/01/PSS3ISCUGba-EN.pdf
    Avoid dropping or subjecting the camera to severe impacts. Do not ... 2006 CANONINC. ... When switching between shooting and ... The camera switches to Playbackmode, but the lens does not retract ..... Play/Print/Set up/ My Camera Menus.
    Canon S3 IS Review: Full Review - Operation
    www.imaging-resource.com/PRODS/S3IS/S3ISA3.HTM
    Record Mode LCD Display: In Record mode, the PowerShot S3 IS's LCD reports ...Unlike its behavior in Record mode, the Display button will not let you view ... switchwith the red camera icon, this mode sets up the Canon PowerShot S3 IS ... exposure setting you've chosen if the camera can't get a good exposure with it.
    [PDF]Download
    galeria-zdjec.pl/ksiazki/instrukcje/Canon/canon_pss3_eng.pdf
    Shoot movies in any mode by pressing the movie button ... with My Colors ... caused by the malfunction of non-genuine Canon accessories (e.g., ... warranty does not apply to repairs arising out of the malfunction of .... Switching between Metering Modes . .....Do not get the camera caught on other objects or subject it to.
    How to give your low-end Canon digital camera RAW support
    archive09.linux.com/feature/118946
    Linux.com
Jan 24, 2016 | Canon PowerShot S3 IS Digital Camera
LCD not working on Canon S3IS
When you press the DISP button the screen will light up. But there is a power save function that will turn the screen off after 1 minute. This value can be changed if you press MENU, select the tools tab and then look under Power Saving. Check what this is currently set to, it may have been changed to be less than a minute. You can make the time period longer.
Mar 18, 2010 | Canon PowerShot S3 IS Digital Camera
I have a canon powershor s3is and i was wondering
You can access this via the FUNC button, this shows a very confusing list of icons. These are explained in the user manual which can be downloaded from Canon
http://software.canon-europe.com/products/0010335.asp
you can choose My Colors either while shooting or add the effects afterwards
Feb 27, 2010 | Canon PowerShot S3 IS Digital Camera
How do I activate digital zoom on my canon S3IS
I believe there is a ring around the button the shutter button (the button you press to take the photos. Your sort of push it left or right (near or far). The digital zoom should activate after it goes past its optical zoom range. Push it only slightly to slow down the zoom process.
Aug 12, 2009 | Canon PowerShot S3 IS Digital Camera
Neither viewfinder will work - nothing appears I have a Canon Powershot S3IS
Jun 23, 2009 | Canon Cameras
Displays "lens Error"
This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Apr 22, 2009 | Canon PowerShot S3 IS Digital Camera
Hi there, I have a Canon Powershot S3IS and just lately when you try to turn it on it comes up with a message that says E24. I have looked through the manual and cannot find anything resembling this...
You have 2 choices here, one is send the camera into Canon for exchange or replace the Camera, this would be based on cost. You can't fix it as no parts are available from the manufacturer to the public.
Apr 05, 2017 | Canon G7 G9 S3is S5is S2is
Canon s3is driver
canon s3is
Informatica
Aug 25, 2008 | Canon PowerShot S3 IS Digital Camera
Blured viewfinder
Look at the viewfinder on the camera.
Now look on the LEFT side of the viewfinder; just above the swivel-screen.
You will see a little thumb wheel there.
That is the focus for the viewfinder. Move it up and down to bring the viewfinder into focus. (Don't forget to do this while you are looking through the viewfinder so you can see what you are adjusting.)
Easy fix. :)
Sep 29, 2007 | Canon PowerShot S3 IS Digital Camera
Canon PowerShot S3 IS Digital Camera Logo
20 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
