Question about Samsung Behold Cell Phone
My behold turns on, the blue load bar begins with the behold name still above, and when blue bar fills, it turns off.
My laptop won't boot up properly. It gets to the screen with the dell logo and the loading bar but the bar only fills about 3/4 of the way. It also begins beeping as soon as I turn it on. I tried to push...
Your RAM may be bad the beep is a bios checksum error letting u know that the CPU or RAM did not pass its test. It will not allow you to to get past the preboot test until it passes all its test. Replace the ram and u should be ok again.
Sep 19, 2010 | Dell Studio 1537 Laptop
I am trying to conecct it to my samsung behold but everytime i click the search button it tells me there is no bluetooth in the area. what ever its only inches away from it , I have turned the blue tooth...
you must make sure your headset is in pairing mode.
simply turn the headset off and wait a few seconds
now, hold down the power button
the device will turn on but continue to hold the button. When the light turns solid or begins to flash a different sequence (typically 15 sec will do it)
now your device is in pairing mode and can be found by any device in the area that sports the bluetooth hardware.
the default code is 0000
GOOD LUCK AND PLEASE RATE THIS POST!! :D
Mar 29, 2010 | Plantronics Explorer 220 Bluetooth Headset...
My phone got cold and now it wont turn on
Hey i just had the same thing happen to me this weekend. i had my phone in my pocket and i was outside for a couple hours in zero degree weather. I got a text message and clicked open and my phone shut off and turned on w/ a blue screen saying it needed to be rebuilt or something like that then it shut off and kept doing the same thing that yours is doing. Did you figure anything out?
Jan 16, 2010 | Samsung Behold Cell Phone
I have download the MFL-Pro Suite for my brother 7840W to my mac OS 10.6 and I am unable to find the software?
I don't see the ControlCenter in my Applications either, but there is an icon in the menu bar in the upper right hand corner. It's hard to describe what the icon is exactly, maybe tiny picture of a printer, file folder, etc, with an blue orbit. When I click on that icon and pick Open, it launches the ControlCenter. Hope this helps.
Oct 01, 2009 | Brother MFC 7840W Printer
Uploading windows vista upgrades command was to restart system for changes to take effect. On restart screen went blue and showed Tech info *** STOP: 0x0000C1F5 (0x00000000, 0x00000000, 0x000000000,...
Press F8 continuously while starting the computer. When black screen appears eventually (right before Windows loads), choose Last Known Good Configuration.
Aug 06, 2009 | HP Computers & Internet
Olympus FE-240
Hi cris9ken.
The little blue bar is your memory gauge.
The Little green bar blinks after each shot just to inform you the shot was loaded into memory.
As the memory fills the green bar will increase in height to give you a approximate idea of remaining usable memory.
You will notice that it function with or without the Xd card.
meaning it displays the favorites memory as well.
Best regards and say CHEESE, Paul
Apr 07, 2008 | Olympus FE-230 Digital Camera
Hotpoint wd420 leaking
they are called paddles ,they just slide and lift.can you rotate the drum with your hand??
Nov 26, 2007 | Hotpoint Aquarius WD640 Front Load...
Samsung Behold  Cell Phone Logo
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
