Question about Philips PSS110/17 MP3 Player
Pss110/05 wont disconnect from my computer i click on the safely remove hardware icon disconnect it and them unplug it but it always says problem any idea
  • 476 Answers
Close any software that may be accessing the device. (including "My Computer" or "Windows Explorer" and try again.
Posted on Feb 08, 2008
16gb pendrive
Which operating system ?
It's always a good practice to safely remove your USB flash drive before unplugging it from your computer.
This prevents data loss and extends the life of your external storage device.
Removing a flash drive from your computer is very easy and doesn't take a long time to do.
Close all files you accessed from the flash drive.
This is necessary for the device to be removed properly.
Don't forget to save your files before closing the files.
Right-click the "USB" icon marked with a checkmark.
It is located on the bottom right of your taskbar.
From the pop-up menu, click "Safely Remove Hardware."
A small window will be displayed.
Select the USB flash drive you want to unplug then click the "Stop" button.
A confirmation window will appear. Click the appropriate hardware device, then click "OK."
The "Safe to Remove Hardware" window will inform you that it's now safe to unplug the USB flash drive from your computer.
Click "OK," then click "Close."
or
Click start all programs accessories windows explorer navigate to your usb drive right click on it select remove or exit.
Jul 27, 2013 | SanDisk Computers & Internet
My safe to remove icon has dissappeared how can re install it please
Which operating system ?????????
The system tray in Windows XP is the right side of the small blue bar at the bottom of the screen that houses the clock and a few other small icons. You can add icons to the system tray for ease of access, including the "Safely Remove Hardware" icon, which allows you to easily remove hardware from your computer.
Turn on the Windows XP computer and right-click the taskbar. Select "Properties" from the menu that appears. Check "Hide Inactive Icons", then select "Customize" A new window appears with all of the icons currently on the system tray, along with icons also for some programs that don't appear on the tray. Click next to the icon "Safely Remove Hardware," then check the box "Always Show". Click "Apply". Safely Remove Hardware Icon?
http://www.pulpfusion1.com/demotech/e_article000253202.cfm
Mar 13, 2013 | Compaq Computers & Internet
On Excel 7, before remoing the usb (removable stick. what are the steps
It's always a good practice to safely remove your USB flash drive before unplugging it from your computer. This prevents data loss and extends the life of your external storage device. Removing a flash drive from your computer is very easy and doesn't take a long time to do.
Close all files you accessed from the flash drive. This is necessary for the device to be removed properly. Don't forget to save your files before closing the files. Right-click the "USB" icon marked with a checkmark. It is located on the bottom right of your taskbar. From the pop-up menu, click "Safely Remove Hardware." A small window will be displayed. Select the USB flash drive you want to unplug then click the "Stop" button. A confirmation window will appear. Click the appropriate hardware device, then click "OK." The "Safe to Remove Hardware" window will inform you that it's now safe to unplug the USB flash drive from your computer. Click "OK," then click "Close."
Feb 08, 2013 | Dell GX270 P4 256/40/48X/XPP/NONE...
I cannot eject my buffalo ministation HD-PCU2 and when I remove it safely, a message prompts and says "device is currently in use. Close any programs or windows that might be using the device."...
Hi Welcome to FixYa!
I am having the same scenario too sometimes.. What i usually do if the drive is not in use, I turn off the computer first then unplug my external hdd. in that case, the computer is completely off as well as the drive. But if you feel like its a hassle of turning down the machine for you to remove the drive, you could try the following steps:
There is a setting for the USB drives which tells the OS how to optimize their usage. Either it is optimized for Quick Removal or for Performance. To check it, do the following:
-Right click on the USB drive icon in My Computer. -Select the Hardware tab. -Select your USB drive and click on Properties. -Now click on Policies tab.
Optimize for Quick removal This setting disables write caching on the disk so that you can disconnect this drive without using theSafely Remove Hardware icon.
Optimize for Performance This setting enables the write caching on the disk so as to improve disk performance. To disconnect this drive, you should use the Safely Remove Hardware icon so as not to hurt your USB drive.
Hope this would help!
Sep 06, 2011 | Buffalo Technology 320GB MINISTATION TURBO...
How do I DISCONNECT CAMERA FROM COMPUTER? SY TOMASHOFF stomashoff@sbcglobal.net
left click on the "safely remove hardware" icon (see attached image). Select your camera from the pop-up list (it may be listed as a drive). Wait a few seconds until computer says, "safe to remove hardware."
NOTE: if you have any applications open, e.g., photoshop, that are accessing files on your camera, the computer will indicated it can't stop the drive. Close all the applications and try again.
If that fails, shut down your pc and unplug the USB connection.
Mar 02, 2011 | Pentax Cameras
I have lost my playlist file
try connecting the mp3 player to your computer, then after it has connected click on the safely remove hardware or USB icon, disconnect the player and see if it creates a new playlist (mine always updates playlist after disconnect)
Mar 08, 2010 | Samsung YP-U3 MP3 Player
How to disconnect mp3 from computer
From a command window run:
C:\WINDOWS\system32\rundll32.exe shell32.dll,Control_RunDLL hotplug.dll
Also, you can try this if it goes away again:
Right click on the taskbar, select properties
click Customize
click on "Safley Remove Hardware", and set to "Always Show"
Jan 03, 2009 | Insignia Kix MP3 Player
I just connected my lg rumor to my computer and disconnected it. My phone continues to say that it is still connected with the USB cable, but if I actually do connect it, my phone turns itself on and off.
Make sure when you disconnect any USB devices, safely disconnect them. If you are going to just unplug it without telling the computer when you need to, you will have major problems. Find a little USB icon in the system tray and click on "safely remove hardware."
Sep 21, 2008 | Lands Phones
Icon doesn't show up in my computer
Do a firmware upgrade first. If not allowed, then download the Sansa Connect Recovery Tool from:
http://www.sandisk.com/Retail/Default.aspx?CatID=1532
"Safely remove hardware" is a normal function of Windows - it allows you to disconnect your Mp3 player without messing it up (unplugging any mp3 player while it is still "thinking" is the number one reason for mp3 player failure - always be patient with mp3 players, and try to always use the Safely Remove Hardware feature of Windows).
-Tha Mp3 Doctor
Feb 03, 2008 | SanDisk Sansa Clip MP3 Player
What is the proper way to disconnect the camera from the computer?
Depending on the operating system that you work with, there is a proper way to disconnect your camera from your computer to ensure smooth operation. With Windows 98, you can simply turn your camera off and unplug it. Make sure you are not in the middle of downloading when you disconnect your camera, or you might loose some or all of your pictures. In Windows ME and Windows 2000, you must go to the system tray (on your task bar usually located on the bottom of your screen) and look for the "unplug/eject hardware" icon. Click this "unplug/eject hardware" icon once to pop up a list of devices available for disconnection, then click on your camera's drive. When the computer tells you it is safe to disconnect your device, then simply turn your camera off and unplug it. Windows XP also has an "unplug/eject hardware" system tray icon, which you should use. However, if you are not in the middle of downloading your pictures, it is generally safe to simply turn your camera off and unplug it. On a MacOS computer, you should drag the camera's disk icon to the trash can before turning off or unplugging it.
Aug 30, 2005 | Pentax *ist D Digital Camera
Philips PSS110/17 MP3 Player Logo
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
