Question about Microsoft Xbox Console
I have an original xbox and was wondering why my light is flashing yellow and green.
  • 5 Answers
Check the cable to the tv... if it's not plugged in plug it in. If it's plugged in unplug and re-plug and try again. Y/G means the AV cable isn't plugged in.
Posted on Oct 04, 2009
Ok I turn on my original xbox it flashes. Green the starts flashing yellow then red and continues to flash these colors it will not open then disc tray or anything pleasse help what's going on and how can...
Unplug video connection in the back,,make sure plugged in all the way,,and try again,,if not probly bad video cable,,my xbox does that if video cable not plugd in ,,when set on hd settings
Nov 04, 2010 | Microsoft Xbox Console
Power box light is blinking orange and sometime a steady red and console want come on.
Green Indicator Light:
The default indicator light is green. When the Xbox 360 power supply light is green it means that there are no problems with your power supply. However, if you are having problems and the power supply light is green, this means that the console is faulty and you need to contact Xbox 360 support.
Orange or Yellow Indicator Light
When the Xbox 360 power supply light is orange or yellow this means there is no problem with your console but the power supply can't supply it with power.
To remedy this problem, first try unplugging the Xbox 360 power supply from the console and unplug the power cord from the wall outlet. You'll also want to uplug the Xbox 360 power supply from the power cord.
Wait for about five minutes and then reconnect everything. You might also want to try plugging it into another wall outlet without an extension cord.
If you are still getting an orange or yellow indicator light, then something is at fault with the Xbox 360 power supply. If this is the case, contact the Xbox 360 customer support to get a new one.
Red Indicator Light:
If the xbox 360 power supply light is red, then there is something wrong with the power supply connection. If this is the case, try the same solution as listed above of unplugging the power supply from the console, unplugging the power cord from the wall outlet and unplugging the power supply from the power cord. Wait for about five minutes and then reconnect everything. You might also want to try plugging it into another wall outlet without an extension cord.
If the indicator lights are still red, then there is a fault with the power supply. If this is the case, contact customer support about getting a new one.
No Indicator Light:
If the XBox 360 power supply light is not illuminating at all, this usually means that the Xbox power supply is not connected to the wall outlet correctly. On the other hand, it might also be a fault with the power supply or the power cord.
Either way, try the same solution as listed above for the red indicator lights. If you still don't see any lights illuminated after unplugging and then reconnecting everything, you'll need to contact customer support about getting a new power supply.
Green and Orange Indicator Light:
If the indicator light is flashing green and orange, this may mean that the console does not detect the AV Pack.
Disconnect and then reconnect the Xbox AV Pack. Make sure the connections are firmly connected. Turn your Xbox back on.
If the indicator light is still flashing green and orange, try another AV pack if one is available.
If the indicator light is still flashing green and orange, you'll need to contact Miscrosoft Customer support.
Flashing Orange Indicator Light:
If your Xbox console's indicator light flashes orange, this means the internal components have overheated and the Xbox has automatically shut down to prevent damage.
Turn off the console and let it cool for at least 10 minutes.
To prevent the Xbox from overheating in the future, make sure that it's not placed in a closed cabinet or on carpet. It's best to get the Xbox elevated off the ground where the PSU can have maximum heat release.
You'll also want to make sure the Xbox is not located near a heat source like the back side of a television, computer, monitor, or other electrical device.
Aug 26, 2010 | Microsoft Xbox 360 Elite Console
Original xbox continous blinking green light, no eject & loading
sounds like a bad cable between the console and the TV, the XBOX is notorious for having issues if the cable isn't the correct one (a Microsoft one) or damaged.
the flash green with nothing else happening can be a failed bios.. coma console variant. It's possible to fix it with a chip, but uneconomic considering the price of a working box these days. It can also be a failed ide controller or bad ram..whatever, it's normally a scrapper with these symptoms unless you have a good junkbox...
If you have an xbox that fell it's always worth changing over the dvd drives, as they can cause weird faults as well, (as mentioned above re: unknown disks) as the green flashing is the usual "loading disk" message.
Sep 08, 2009 | Microsoft Xbox Console
3 red lights and yellow power supply light
at the very least the main board is acting flaky with the 3 red lights flashing. Here is tutorial courtesy of LLAMA to show how to resolve that problem:
http://www.llamma.com/xbox360/repair/ring_of_light_x-clamp_fix.htm
As far as the yellow light on the power supply is concerned. Unhook it from the Xbox 360 and only plug it into a power outlet. If the light is yellow then the power supply is bad. If the light stays green then plug it into the xbox 360, if it tells yellow then, at that point you know that the main board is causing the yellow light on the power supply and that means the main board is bad.
Aug 03, 2009 | Microsoft Xbox 360 Console
Original xbox red ring of death
you have to take the xbox apart open the dvd/cd rome and clean the eye and the disk spinner then put it back together and it should work fine
Dec 28, 2008 | Microsoft Xbox Console
Xbox Original flashing green and red
Hi there!
This is known as the Christmas lights or FRAG frequent red and green error.
Most of the time the screen is blank and if you were doing work recently such as modchipping this could be caused by solder splashes on the mobo or a shot MCPX chip. Removing the MCPX chip is impossible without very expensive equipment so if you can't find any solder splashes or you weren't soldering on the board junk the whole board.
However, since you said that your xbox is original, I would assume that you haven't done any modifications yet so chances are, the xbox can't find an AV cable connected to this unit. If you do have one, please check if your AV cable is damaged (a frayed or damaged wire). Replace your AV cables and your good to go.
Cheers!
Dec 21, 2008 | Microsoft Xbox Console
Nintendo xbox
Have you opened the console and tried to fix something? or taken it somewhere to have it fixed?
Nov 21, 2008 | Microsoft Xbox 360 Console
Xbox 360 adapter
The flashing yellow light on the Power adaptor points to a potential failure with the power adaptor. Usually when the adaptor is idle their is a solid yellow light, A red light for a total failure and a green light for on.
A YEllow flashing light would indicate that there could be potential problems with the adaptor overheating and/or being faulty. where is the adaptor located ? just like the console itself. they are prone to overheating and collect dust very easily.
i would suggest moving the adaptor into an area with a large opening to allow the flow of air to keep it cool, also i would attempt to remove any dust inside.
Try doing this and if the problem persists, let me know
Oct 25, 2008 | Microsoft Xbox 360 Console
Nintendo xbox
yo you mean like traffic lights green, yellow red or am i going bananas bananaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
Jan 16, 2008 | Microsoft Xbox Console
Microsoft Xbox Console Logo
303 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
