Question about Cameras
E-300 will not turn on when memory card is inserted. operates fine with no card. card does not insert all way in properly.
Insert smart sim
Insert sim error happen if the phone is not acknowledging the existence of sim card inserted in the phone.
1. Check if the sim is properly inserted.
2. Turn off mobile phone
3. Remove battery
4. Remove memory card
5. Remove sim card
6. Check the copper pins of the sim if there are dirts stucked on it
7. Ure clean cloth to wipe sim gently
8. Wait for at least two minutes
9. Gently and properly insert the memory and sim card
10. Insert the battery
11. Turn on mobile phone
13. Check if you will still recieve insert sim error
14. If you still recieved the same error you need to call your service provider and check the status and availability of your sim card.
Dec 09, 2011 | AT&T LG CU720 Cell Phone - Silver
OFFLINE MODE
Offline mode means that your phone aint getting any signal from your mobile service provider's BTS. You need to check it from your mobile service provider if there's an ongoing outage, you need to check as well if the sim card is properly inserted. Try powercycling your phone.
1. Turn off your device.
2. Remove the sim, memory card and battery.
3. Wait for at least 2minutes.
4. Plug back the SIM card, memory card and battery.
5. Turn on mobile phone.
6. Check if you are still getting offline mode.
7. If so, try to insert your SIM card to a different phone.
8. If using a different phone for your SIM displays offline mode still,then its your SIM card which is faulty. If it works fine make sure that you inserted the sim properly or the SIM card slot might be faulty.
Dec 05, 2011 | Nokia E52 Smartphone
Camera will not turn on. Already replaced batteries.
as per your camment you already replace the battry thats means no problem in battery Ok Firstly please follw the steps,remove memory card(if have),power resourses like AC power adaptor and batteries and wait some some just about 10 min,than reinsert the battrie and AC power adaptor,swith on the camera without memory card,if it is work and than insert ithe memory card otherwise reinsurt the memory card correctly and close the memory card door properly if the camera working fine other wise follw the third instuction that check the AC power supply,this is connect properly through input or not.connect the properly and turn on the camera and check issue is resolved
If you not find the solution thats means your camera has been damaged,need the service of camera and second resion is if you insert the battry incorrectly ,some issue
One more resion is images in memory card,firstly download ths images in system and formate the card.
Thanks,
Jan 16, 2010 | Sony Cyber-Shot DSC-F707 Digital Camera
My sony dsc w35 turns on fine, then the word
This means it's having an issue using the memory card or internal memory (which the DSCW35 does have some of). Check to see that your memory card is inserted properly, and if so, try putting a different card in.
If the cards are inserted properly and switching out the cards doesn't help either, the pins that touch the memory card are likely scratched or have been damaged. If they appear to be fine, your camera is having issues reading cards and will need to be sent for service repair. If it's inside of warranty, contact Sony or the retailer you purchased it from, otherwise, look for a local service depot; the repair is not expensive.
Dec 08, 2009 | Cameras
Tom tom go 300
The memory card you have inserted is damaged and needs to be replaced
Jun 30, 2009 | Tomtom GO 300 GPS Receiver
My computer cannot see my 8gb sd memory stick even though the reader is working it keeps asking to insert a disc
chek the memory card is not insert properly in the card reader , first u properly insert the card into the card reader and then check
Jun 08, 2009 | SanDisk 2GB microSD Memory Card
N 72 hangs when inserted a memory card
hi there!
How much GB did you inserted?
Did you tried turning off/on the phone? Did you tried turn on the phone without inserting the memory card?
Regards,
Feb 19, 2009 | Nokia N72 Cellular Phone
SD Card error
Hi, Since the SC card is properly inserted, then it is possible that you have to format the memory card. Go to the camera's utilities/menu and look for the format function. Perform format operation on the card. Hopefully this should revive/restore the card to an operational status. This of course would erase all data/photos inside the memory card. Good luck and kind regards.
Sep 04, 2007 | Vivitar ViviCam 3746 Digital Camera
Card Eject Button Not Working
I hgave the came camera it does take two pushes to get it to lock down - just a quirk I guess
Jul 30, 2007 | Olympus EVOLT E-300 Digital Camera
Cameras Logo
16 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
