Question about Gateway GM5084 PC Desktop
Gateway Foxconn C51GU01 (105552) Problem: blue
Gateway Foxconn C51GU01 MB Problem: blue screen when all mem slots occupied. Sometimes boots with first 3 slots occupied. No boot with 2 slots occupied (all dimms seem to be OK) MB Bad?
  • Vaio Tech
    Vaio Tech May 11, 2010
    WHAT IS THE TOTAL AMOUNT OF MEMORY INTALLED ON THE PC AND IF THE MEMORY IS THE SAME FREENQUENCY OF THE ORIGINAL ONE? THANKS
    Sergeant:
    Novelist:
  • 191 Answers
Possible a memory socket is bad. Make sure you are using the correct type of memory including parity and compatible speeds. It is recommended to use like memory sticks in each slot. Some PCs even require the sticks to be equal memory capacity. User's guide should tell you what the compatible capacities and speeds should be. If you don't have the manual, you can get by looking up your PC model number on Gateway.com.
Bret
1-2-1ComputerServices
Posted on Oct 05, 2009
Chat room
First of all, take the MBput and clean the dust off of the MB. Make sure the PCI slots are clean. Take out the memory stick and clean them with a pencil eraser. Get into the BIOS and check the date and time, if the date and time is wrong, that won't let you boot up. If every time you boot, the time is incorrect, then you need to change the internal battery, this is the one that is plug to the MB.
Jun 19, 2013 | Gateway Computers & Internet
Hello, ive got a HP 5189-0466 FOXCONN MCP73M02H1 NAPA HP MOTHERBOARD. and im building just an internet comp for the downstairs for the kids but im having troubles finding the manual for it. Cant seem to...
open side panel remove cable from usb reader i have pulled CABLE AFTER install new mother board same thing stuck no key board 1 blink/ f10 got setup ..... stuck . This may be a chip set driver not installed. or a bad hardware pulling to mush power. I change CPU, MEM sticks. Power supply all the same thing. Just pull these cable to hadrware not hdd. boot right up . BINGO> c:\users\office\appdata\local\temp\msohtml1\01\clip_image001.gif down 1yr.
Jun 23, 2010 | Computers & Internet
I want to put in 3 x 2gb mem. I have the correct type but when i boot it does not work. i then put 2 x2gb and it works. is this a bios set up problem or something else?
Ram on an ATX motherboard is called "DIMMs", that means it has to be installed in Pairs, you cannot have an empty slot, if you are running windows XP or a 32 bit operating system, then I would put (2) 1 GB sticks in the same colored memory slot and then (2) 512 MB sticks in the other two alike color slots. The memory slots are color coded. If you were only putting in one pair of sticks they have to go in the same colored slots.
Oct 09, 2009 | Foxconn 975X7AB-8EKRS2H Motherboard
Automatic shut off of pc
There is a CD tool called "Ultimate Boot CD" which can be downloaded at http://www.ultimatebootcd.com. On this CD there are quite a few tools that you can use to test your RAM, CPU, Hard Drive, etc.. for problems. Just boot up with this CD and select the corresponding testing program to use. Test each thing until you find the component causing the issue.
Aug 17, 2008 | Foxconn P4M9007MB-8RS2H Motherboard
I have an older Gateway pc with Bios version 4w4boxo.15a.0017.p12. I added a 512mb of RAM, and when I attempt to boot up I get an error message that says; Error Code 0232: Extended RAM failed at...
I am trying to remember that computer but in most Gateway computers you have to have equal values of ram in the two ports and both must be occupied . I/e two 256 mb.Good luck... Be mucho blessed...Mark
Jun 26, 2008 | Gateway Computers & Internet
Computer will not boot with 2 gigs of ram.
yaa viz eagle is right, its really seems like frequency mismatch. The both RAM must of same size, same type, and same frequency.
Thanks
Iqbal
Mar 24, 2008 | Biostar P4M80-M4 Motherboard
Foxconn 661mx plus
blue screens means you have problems with your operative system or memory so make sure your operative system cd is in good coditions and reinstall it
Dec 31, 2007 | Foxconn 661MX Motherboard
Blue screen display
Check the memory of your computer. this could cause blue screen display. Be sure to check also the cooling fan for microprocessor and video card cooling fan if it is working. Sometimes it cause blue screen and needs to re-start your computer. If you have two slot of mem that is occupied then, you can remove one and leave the other one. Be sure to power off your computer before doing this. Then turn on your computer and try to observe it. If the problem still exist then do the same with the other memory and check it again. I hope that these could help your problem.
Aug 25, 2007 | Microsoft Broadband Networking MN-520...
Gateway GM5084 PC Desktop Logo
296 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
