Question about Whirlpool Home
I have a Mansfield, Swirl-way tub. Jets won't come on. Lights are working, but no action from the jets.
On mine water got behind the soft touch controll and corroded the connection see if there is green gunck on the phone like plug
Posted on Mar 12, 2010
We have gunk coming from the jets when powered on - What's the best way to clean this tub so we can actually use the jets?
You need to use them on a regular basis. Put as little water in the tub as you can get away with and then add some bleach. Run the bath jets for 15 minutes to clean and sterilise it. Empty the bath and fill it again with plain water. to rinse it.
Feb 25, 2018 | Jet Home
Air jets
is there voltage going to the motor?
Rod
US Parts Center
Jun 24, 2013 | Maax Calla 6042 Bathtub - 101058-000
Jets will not turn off
Sounds like your air switch is bad in the little box on top of the motor.
It is part # TBS-339
Rod
US Parts Center
888-521-6183
Apr 25, 2013 | Whirlpool 6060 DL Corner Pro-Fit Acrylic ...
Need to find out why 2 of the 6 jets on my acer swirl bath tub don't push water out like the other 4, and where can I find replacement jets. We bought the home recently and it was built in 2000. so...
see if the jet faces turn at all. Sometimes the jets are adjustable to allow more pressure from some jets.
turn the face of the jet and see what happens.
Aug 16, 2011 | Home
Just bought a home with a swirl - away tub need to clean out and I am not sure how to remove the jets from the inside of the tub. I need to clean them..
Check with your local plumbing supply shop, there are special self cleaning chemicals to run thru the system, also can be purchased on line.
May 19, 2011 | Whirlpool Home
I discovered tiny ball bearings in my hot tub. Where could they come from? The hot tub is working fine.
The ball bearings from your spa are from a roto head jet. Typically they are from one of the larger sized jets and they make the swivel action in the roto swirl jets function smoothly. You can determine which jet is coming apart by the loose function of the center nozzle. The jet can be removed and replaced to solve this problem. Most jets screw out but when they have deteriorated a lot, you may need plyers to take the jet out in pieces.
Jan 03, 2010 | Qca Spas Majestic Series Aruba Xl Hot Tub
My jets in my new tub will not turn on.
You could have a GFCI receptacle tripped or in test mode. look close to tub or in and around tub area for this. This receptacle has a test and reset button on it.
Aug 30, 2009 | Mansfield Plumbing Products Mansfield...
Cold air coming from jets in a large garden tub indoors
jets pull outside air in thru the water jet in a natural Venturi action. If you are referring to the air bubbles in a bathtub then, yes there are air blowers that have heaters inside them to warm the air before if goes into the tub.
Feb 20, 2009 | Home
Only 3 of 6 jets in jacuzzi tub working
Make sure the jets themselves are fully opened. Some models you can turn individual jets on & off
Dec 04, 2008 | Home
Home Logo
1,837 people viewed this question
Top Whirlpool Home Experts
Craig Butler
Craig Butler
john h
Mike
Are you a Whirlpool Home Expert? Answer questions, earn points and help others
