Question about AT&T 9345 Cordless Phone
Display not working correctly; battery replaced
Battery warning
Just ran into this problem. New 3rd party battery with the badly translated message:
"Battery Life Time in current state is not longer.
Because you may lose your data during using, please replace to new battery.
(honest goods)
Tip> Battery Pack is Cunsumerable device.
This pack is not working correctly or life time is not longer,
please use to replace to new battery (honest goods)."
What I did was when the message pops up, hot ctrl-ald-del > start task manager > right click on it in applications and click "Go to Process" > right click on the .exe file and "open file location" > and just changed the name of the executable file by just putting a 1 on the end of the name. No more pop-ups
Who the hell uses Easy Display Manager anyway? Stupid program.
Jul 19, 2012 | Computers & Internet
I have a powerware 9120 (6kva) and about 1 week i replaced all 20 batteries after the UPS failed. but its displaying battery disconnected when i try to power it. i cant seem to figure the problem. i tried...
Did your UPS display "Battery disconnected" or did it display "Battery Failure"? If it was "Battery Failure", for some reason the Powerware 9120 will take almost 18 hours after plugging in to power after battery replacement to correct the Battery Failure indication. Charger has to charge up the batteries, followed by an automatic battery test by the UPS. If the indication was "Battery Disconnected", you will need to check the internal fuses to see if they are blown. If the UPS keeps blowing fuses, it will require a board repair.
Jun 12, 2011 | Powerware 9120 UPS System
Wii controlers won't respond
If the Wii will turn on and display the menu, then I would say try replacing the Wii controller batteries first. If after you replace the batteries and it is still not working, the next best thing to do is make sure the sensor bar is correctly plugged into the console. If it is correctly plugged in, then it may need to be replaced.
Mar 29, 2011 | Nintendo Wii Console
Time on phone keeps changing and doesn't stay when I put the correct tome in...which I shouldn't to do right....its suppose to be automatic but its constantly giving me the wrong time...help please
Your secondary battery located inside your unit which is for correct time display maybe drained. I have the same problem with my phone. After I had it replaced by a technician, my phone clock display is now working nomal. Another option if you don't want your secondary battery replaced is setting your phone to automatically detect your network's time. Go to settings, look for time and date settings and locate the automatically update time or something like that. Everytime you turn on your phone, it should automatically detect and display a correct time.
Dec 19, 2010 | HTC EVO 4G Smartphone
I have this model and the outdoor temp sensor isnt working, and yes both modules have brand new batteries in them. what should i do to get the outdoor temp sensor to work.
My outside display stopped working, but the inside display still worked. I found that one of the two batteries in the inside unit was almost all the way dead. Once I replaced both batteries the outside display worked. I also checked the batteries in the outside unit. After all batteries were installed, I pushed the small button that is inside the battery compartment on the outdoor unit. It's now working perfect..
Oct 10, 2010 | Acu-Rite Acurite Wireless Weather...
Display not working after battery change
some have a small reset button on the back where you push it with a pencil tip. That may help!
Oct 28, 2009 | Honeywell Programmable Thermostat Heater
Keys not working
The following table shows the possible reasons for performing a hard reset on a BlackBerry device Keypad is not functioning correctly. For example, keys do not work, the trackwheel is not functioning correctly, or the handheld does not turn on. Handheld display is hard to read. For example, the display shows lines obscuring text. To perform a hard reset on BlackBerry smartphones
  1. Remove the battery cover.
  2. Remove and reinsert the BlackBerry battery to reset the BlackBerry smartphone.
  3. Replace the battery cover.
Sep 22, 2008 | RIM BlackBerry Pearl 8100
Fossil JR8096 - Display Not Working
hi i have a watch very simalar. They run on two seperate batteries. sounds like one of them is dead. get the digigtal one replaced
Aug 21, 2007 | Fossil JR8096 Wrist Watch
Battery Issue
This worked! Thank you! It was 49 degrees in the house, and now the heater is working again.
Thank you and warm wished for the new year!
Mary
Jun 05, 2007 | Honeywell CT3200 5-2 Day Electronic...
AT&T 9345 Cordless Phone Logo
19 people viewed this question
Top AT&T Lands Phones Experts
george  peters
george peters
Paul C.
Level 1 Expert
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
