Question about Britax Monarch - Red Racer Booster Car Seat
Describe how to remove upper back from monarch car seat
  • 3 Answers
Remove the back and bottom covers (the back cover has four clips; the bottom cover stretches over the front of the base and has two elastic bands that stretch back on top of the base). While holding the base on the floor, push the backrest all the way back until flat (this will take some force). Slide the axel off to the right (your right as you are facing the front of the seat).
Posted on Feb 14, 2010
How to remove back seat of 79'camero
  1. Pull back of seat bottom up while pushing front of seat bottom towards trunk. They're held in with hooks on the floor. Once you've removed the seat bottom, you see the bolts for the upper seat at the bottom of them . Remove 4 bolts (I believe) then push seat up .
    We Are Here To Help !!
Nov 16, 2017 | Seat Cars & Trucks
Haw to gat out seat back
Rear Seat Backrest-SuperCab Removal
  1. Fold down both rear seat cushions.
  1. Remove the rear seat back.
    1. Push the wire hooks rearward to disengage the seat backrest from the back panel of the cab.
    1. Lift the rear seat back upward and remove.
Installation
  1. Align the upper hooks with the upper brackets on the back panel of the cab.
  1. NOTE: Make sure the safety belt webbing is not twisted.
    Route the rear center safety belt through the retainer ******** the rear seat back.
  1. Place the lower hooks behind the lower brackets on the back panel of the cab.
  1. Lower the seat back until the lower hooks engage the lower brackets.
  1. Verify all three upper hooks have engaged the upper brackets
Feb 12, 2011 | 2005 Ford F-150
How do I remove the rear upper back seat on my 4 door 2002 Ford Taurus?
Remove the seat cushion. The seat back has 2 bolts holding it at the bottom. After the bolts are removed, lift up on the seat back to release the hooks that hold it at the top.
Jan 30, 2011 | 2002 Ford Taurus
How do i take the back off on a 1999 nissan maxima bucket seat
Hi, follow the instruction below......
Rear
See Figures 3, 4, 5 and 6
  1. Remove the lower seat cushion by pulling straight up on the front portion and disengaging the clips. Then hinge the seat upward to release the rear clips.
Fig. 3: Pull up on the front of the lower seat cushion and disengage the clips
  1. Remove upper rear seat back-to-chassis bolts.
Fig. 4: Remove the bolts behind the center armrest ...
Fig. 5: ... and the bolts on the lower corners ...
Fig. 6: ... Then pull up on the seat to disengage the three clips on the top of the seat
  1. Remove rear seat back by tilting forward and pulling straight up.
To install:
  1. Install the lower seat cushion and torque the lower rear seat-to-chassis bolts to 15-20 ft. lbs. (21-26 Nm).
  2. Install the upper rear seat back cushion and torque the upper rear seat back-to-chassis bolts to 15-20 ft. lbs. (21-26 Nm)
Jan 19, 2011 | 1999 Nissan Maxima
Truck lock is jammed by briefcase strap. can i get into the trunk from the back seat? such as does the back seat fold down?
I searched the owner's manual and there was no mention of folding the rear seats down. If you don't have a manual, you can get one here: http://www.extendedgmwarranty.com/owners-manual/buick/1999-Buick-Century.pdf
You can remove the seats following the instructions below from autozone.com.
Rear Seats
SEAT CUSHION
Fig. Typical W-Body rear seat cushion removal
  1. Locate and remove the small bolts at the front lower edge of the seat cushion.
  2. Pull the tabs on the rear cushion retainers.
  3. Remove the seat cushion by lifting up and pulling out of the retainer.
  4. Installation is the reverse of the removal procedure. Make sure the retainer tabs are snapped into place. Tighten the bolts to 18 ft. lbs. (25 Nm).
SEAT BACK
Fig. Typical W-Body rear seat back removal
  1. Remove the seat cushion as described above.
  2. Remove the anchor nuts securing the rear seat retainer at the bottom of the seat back.
  3. Grasp the bottom of the seat back and swing upward to disengage the offsets on the upper frame bar from the hangers.
  4. Lift the seat back upwards to remove from the vehicle.
  5. Installation is the reverse of the removal process. Make sure the hooks on the seat back are properly installed to the hangers. Tighten the anchor nuts to 89 inch lbs. (10 Nm).
Nov 07, 2010 | 1999 Buick Century
How too remove back seat in a 1995 Nissan Maxima
Rear
To install:
Hope help with this (remember rated this).
Jul 19, 2010 | 1995 Nissan Maxima
OLDSMOBILE ALERO 1999 MY KEYS ARE LOCKDED IN THE TRUNK...HOW DO YOU LIFT THE BACK SEAT
1) lift the back seat bottom cushion up sharply at the 2 front corners , until the 2 clips come out of the body, then slide it forward and out of the car
2) at the lower corner of the seat back remove the nuts securing the seat back tabs
3) With the nuts removed pull the seat back forward enough for the tabs to clear the studs , then pull the seat back sharply up and towards the instrument panel to disengage the upper seat clips from the body
4) remove seat
Jun 12, 2010 | 1999 Oldsmobile Alero
I am unable to remove the back to convert this car seat to a booster.
Sep 02, 2009 | Britax Monarch - Red Racer Booster Car...
I need to replace a rear seat belt in a 1997 Ford Tarsus. Does any know the best way to access the assembly? In addition, are there any diagrams available that show the connection points?
please don't forget to rate, thx.
Retractor and Tongue—Sedan
SPECIAL SERVICE TOOL(S) REQUIRED Description Tool Number Safety Belt Bolt Bit T77L-2100A
NOTE: Safety Belt Bolt Bit T77L-2100-A should be used for safety belt removal and installation.
Removal
  1. Remove rear seat cushion. Refer to Section 01-10 .
Seat Cushion, Rear Sedan
Removal
  1. Apply knee pressure to lower front portion of the rear seat cushion. Push rearward to disengage rear seat cushion pad and frame (600A88) from rear seat cushion front retainers (63370).
  1. Remove rear seat cushion from vehicle.
  1. Remove rear seat back. Refer to Section 01-10 .
Seat Back, Rear 60/40 Split Bench—Sedan
Removal
  1. NOTE: Safety belt bolts do not secure seat back to vehicle.
    Remove rear seat cushion as described.
  1. Fold down back seat and remove two bolts in the center of each seat back striker plates.
  1. Remove two bolts from outboard rear seat back frame retaining brackets.
  1. Lift seat back up and pull forward to remove from vehicle.
  1. Remove panel (52018) and quarter trim panel (31012). Refer to Section 01-05 .
Trim Panel, Quarter—Sedan Removal
  1. Remove rear seat. Refer to Section 01-10 .
  1. Pull up on rear section of rear door scuff plate that overlaps lower quarter trim panel.
  1. Pull lower quarter trim panel away from body.
  1. Remove safety belt retaining bolt.
  1. Feed safety belt through lower quarter trim panel.
  1. Remove safety belt anchor plate-to-sill bolt from quarter panel.
  1. Remove retractor anchor nut and retractor from rear quarter panel.
  1. Remove upper seat belt anchor bolt and anchor from upper rear quarter panel.
  1. Slide anchor plate end of safety belt through the openings in the quarter trim panel.
  1. Remove outboard front safety belt retractor and tongue (611B08) from the vehicle.
    Item Part Number Description 1 386277-S190 Bolt (Part of 611B68) 2 31012 Upper Rear Quarter Trim Panel 3 611B60 Retractor and Tongue 4 N800937-S190 Nut 5 389370-S190 Bolt 6 — Rear Quarter Panel (Part of Body) 7 52018 Lower Rear Quarter Trim Panel 8 — Mounting Stud (Part of Body)
  1. Remove seat belt anchor bolt and retractor and tongue from rear deck panel.
Installation
  1. To install, reverse Removal procedure.
  1. Make sure the safety belt webbing is not twisted. If it is, remove the twist.
  1. Tighten retractor anchor bolt and safety belt anchor plate-to-sill bolt to 34-46 Nm (25-33 lb-ft).
  1. Check the restraint system for proper operation.
Jun 30, 2009 | 1997 Ford Taurus
How do you make the britax monarch a backless booster?
While holding onto the base, push the backrest all the way backward. This will take some force. Once the backrest is flat, you can slide the axel off. Note that it only slides off one way - toward the open end.
Oct 06, 2008 | Britax Monarch - Red Racer Booster Car...
Britax Monarch  - Red Racer Booster Car Seat Logo
146 people viewed this question
Top Britax Baby Gear Experts
Jennifer Rock
Jennifer Rock
ray gallant
Tom Chichester
Are you a Britax Baby Gear Expert? Answer questions, earn points and help others
