Question about Heavy Duty Intermatic INC Tn800cl Indoor Timer with Outlets 15 Amps
I am not sure how to use this intermatic timer TN800CL. I followed the instructions but when I plug the lamp or radio it doen't work at the time that i program initially.
    President:
  • 1,714 Answers
Make sure you have the 'ON' tripper (green) in the time on position and 'OFF tripper (Red) set for the off time. Very important. Also the 'white' times on the dial are for 'AM' and the dark times on the dial are for 'PM'
Posted on Oct 04, 2009
I lost my instructions onhow to set my lamp intermatic timer to go on and off automatically. How do I get the instructions?
Open following link to identify timer and download possible manual:
http://waterheatertimer.org/Intermatic-timers-and-manuals.html
Open following link to set analog timer by experimenting with features:
http://waterheatertimer.org/How-to-set-timers.html
Add a comment any time for help with specific timer
Take a moment and rate answer for accuracy of information provided:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 12, 2011 | Hardware & Accessories
How do i set up the timer for a hb65r
Intermatic HB series timers have on-off trippers that push all the way down onto the dial.
Then you rotate dial until current time lines up with arrowhead located on inner dial.
Plug timer into outlet. Turn ON your lamp and make sure bulb is good, plug lamp into timer.
Open following link for step-by-step instructions with illustrations for setting analog timers:
Jul 16, 2011 | Hardware & Accessories
Lost the guide book for setting the timer. please help me with directions to program time for lamp to come on and go off daily. Thanks My email address is ilewis@h2l.com (H2L.com....all lower case)
Check following link to make sure this is your timer:
http://www.intermatic.com/products/timers/consumer%20indoor%20timers/digital%20timers/dt620cl.aspx
Manual for DT620
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/dt620cl.ashx
This is a plug-in timer with internal rechargeable battery.
If battery will not charge, then display doesn't show, and timer is no good.
If this is not your timer, then add a comment with detailed description of timer for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on timer.
Jan 04, 2011 | RTO Intermatic DT620CL 15 Amp Indoor...
I HAVE INTERMATIC MODELTN300 and don't know how to set it up,
Intermatic TN300 timer is same as Woods 59200 timer
See timer at Amazon
http://www.amazon.com/Intermatic-TN300CL-Indoor-Mechanical-Timer/dp/B001KBZUK8
Timers are sold under different brands and numbers depending on who is packaging and marketing the product.
59300 manual:
http://waterheatertimer.org/pdf/Woods-59200.pdf
Rotate dial to set current time, when plugged in, dial rotates
48 segments located on dial; each segment is 1/2 hour. Push segment down like piano key.
Segment pulled up = lights OFF
Segment down = lights ON
Override switch on top of timer.
For programs to operate, move switch to Timer ON
Plug lamp into timer.
Turn lamp ON
Plug timer into wall
If instructions above don't match your timer, see following page to identify timer:
http://waterheatertimer.org/Woods-timers-and-manuals.html
Dec 14, 2010 | Hardware & Accessories
I need the instructions to do the set up
You posted under Intermatic TN300 24-hour plug-in indoor timer with 2-prong outlet
If this is not your timer, add a comment
Intermatic TN300
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/tn300.ashx
TN300 is same as Woods 59200
Rotate dial until current time lines up with arrowhead located on inner dial.
The segments located around edge of dial are pushed down or raised to set on-off times.
Push segments down for times you want timer ON
Turn lamp ON
Dec 09, 2010 | Intermatic 10 Amp Mechanical Indoor Timer
I have digital programmable timers (Model DT121 and Model DT11) that will accept programs, but won't turn the attached lamps on and off at the programed times. The batterys are new and I've had them...
DT121 Manual
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/dt121c%20-%20english.ashx
All Intermatic manuals
http://www.intermatic.com/customer%20service/instruction%20manuals.aspx
Intermatic does not show DT11
Intermatic shows the DT121 is no longer available
If the display shows and you can set programs, then the battery is good.
Does the manual override work? This indicates whether the timer on-off switch operates.
If manual override does not work, then I discovered that timers are no longer any good
Programming:
Set present time
Then set ON time for program 1
Set OFF time for program 1
Then set ON time for program 2
Set OFF time for program 2
Most timers will not function if there is a conflict in programming > for example Program 1 says ON at 6 and OFF at 7 and Program 2 says opposite or has overlapping times
When events are set, press SET once > this will put timer in RUN mode
If manual override works, and you set programming correctly, but timer does not carry out instructions, I guess the timer is no good.
Intermatic has 24 hour timers with 2 on-off per day
http://www.intermatic.com/products/timers/consumer%20indoor%20timers/lamp%20%20appliance%20timers.aspx
Intermatic has 7-day digital timers (all digital timers today are 7 day where you select the day that each program works)
http://www.intermatic.com/products/timers/consumer%20indoor%20timers/digital%20timers.aspx
Oct 12, 2010 | Intermatic Hardware & Accessories
No instructions!
Open following link to identify Woods and Intermatic TN300 manuals and see written instructions.
http://waterheatertimer.org/Woods-timers-and-manuals.html#59200
For troubleshooting and photos of timer dials.
http://waterheatertimer.org/Woods-timers-and-manuals.html#troubleshoot
Upvote the help.
Aug 05, 2009 | Intermatic 10 Amp Mechanical Indoor Timer
How do you operate lamp timers
Yay!!! I found out the solution, and I tried it, and it DOES work!
I got these instructions from Intermatic Technical Services. I e-mailed them with my problem and they finally got back to me.
Follow them exactly and you will have no problems!
1) Pull up all trippers.
2) Push down the tripper at the time you want the light to turn on
3) Push down the tripper at the time you want the light to turn off
4) Push down all trippers for the duration of your on time
5) Set the current time of day with the time of day arrow
6) Plug in your lamp and make sure the lamp's switch is in the on position
7) Set the slide switch at the top to the timer position
If this does not help, please contact technical service by phone at 815-675-7000, option 1 then option 2.
Dec 18, 2008 | Hardware & Accessories
Heavy Duty Intermatic INC Tn800cl  Indoor Timer with Outlets 15 Amps Logo
499 people viewed this question
Top Heavy Duty Hardware & Accessories Experts
jeff5may32
ray gallant
Gene Haynes
Are you a Heavy Duty Hardware and Accessory Expert? Answer questions, earn points and help others
