Question about Makita BO4556 2 Amp Finishing Sander
Sander has a electrical problem I need to know
Sander has a electrical problem I need to know how to open
  • A Miller May 11, 2010
    What is the nature of your electrical problem?
Makita / mactec designed
the first broken / wear off are at the SWITCH button (so they didnt LOOSE very much on ur FREE spare part.
if u want to change the COL BRUSH just open the BLACK part or the head , if it looks like wear off, THINNED, then buy/ ask for GUARANTEE, for free part .
third problem are the TEETH of the ARMATURE/ the one that SPINS in the middle.
THE CABLES are TOUGH enough.
but i better didnot recommend to buy BO 4556, it is DESIGNED flaw, the METAL shoe WEAR off easily, speacially the 4 corner SPRING shoe.
my emial are         miqsanc             at          yahoo         dot           com
Posted on Nov 20, 2009
Why is my 5" sanding disks not sticking to my sander?
The holes are to suction dust for a vacuum attachment or dust collection bag. The sander will have a very smooth pad almost shiny if it takes stick-on discs (PSA). If not it will be a velcro pad and in that case you need the velcro discs. This description sounds like you have a velcro pad. Sticky discs wont stick to a velcro pad.
Apr 24, 2016 | Sander Tools & Hardware - Others
How do I troubleshoot why the sander is not turning on? Have replaced switch and opened the sander to check all connections and there is nothing not intact.
Try and test the motor coil if you can to see the motor is intact. If you notice a small circuit board inside, you might as well test its electronic components, e.g. capacitors. You may also test the power cord and the pins to prove they are OK. If these options are exhausted, you can refer to an experienced service tech.
Nov 09, 2015 | Sander Tools & Hardware - Others
Where can i find parts for a sky1373 drywall sander
I would love to know where to find some drive shafts for this product as well!!! the porter cable drive shafts are not the same.
May 28, 2014 | Sky Drywall Sander 710 Watts Commercial...
I have acquired a makita 9924db belt sander, but not a manual. The dust bag is wide open on the bottom - shouldn't there be some sort of device on it to keep the dust in? Also, I would like to know...
there is usually a plastic clip that slides over the bottom to seal the bag, as for the manual go to "makitausa.com" and you can download a manual from there. Let me know if you need more assistance.
Jul 08, 2011 | Bosch 1274DVS 3" x 21" Belt Sander
We have a really old Stanley 3" Belt Sander that has a worn electrical cord. We want to replace the cord; however, we cannnot get to sander open in order to install a new cord. We have all the...
use a screwdriver (rubber handled) to smack around the tool to losten it. you hill find that the seam will start to open.. then carefully pry it open with a flat blade.. if it is hard in one area look close to see that you didn't miss a screw ... jay
Jun 06, 2011 | Stanley Tools & Hardware - Others
Palm sander 6016... i have to replace the
you dont need a puller for the fan, remove the lower pad assembly and the torx screw holding the bearing in place. use a screwdriver to gently lift the fan. the bottom of tool has to be disassembled to open the halves. Go to Milwaukeetools.com and type in your model number under the download section for a parts/tool explosion. Let me know if you need more assistance
Aug 25, 2010 | Milwaukee Tool Milwaukee 1/4 Sheet Orbital...
How do I remove the rubber pad from the 31-7 sander? Which way should I turn the the allen wrench?
hold pad and turn the screw counter clockwise to loosen. Let me know if you need more assistance.
Mar 24, 2010 | Bosch 3107DVS Electric Sanders & Polishers
Electric Bosch hand held orbital sander belt not rotating properly
My guess is that your sander got gunk in the belt and other rotating parts and you are either burning up the belt, or (hopefully not) the motor windings. Rick
Apr 13, 2009 | Air Tools & Compressors
Need a wiring diagram for a delta drum sander
Here's a link to the online manual.
As far as that diagram....didn't you label the wires?
Take a look here, it may help you. circuit wiring , especially the paragraph that begins: "Knowing that electrically common points have zero voltage drop between them is a valuable troubleshooting principle." Also read about resistors. That speed control knob is one.
Hope that helps...
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread. If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Feb 20, 2009 | Delta 31 - 255X X5 18'' x 36'' Drum Sander
I have a du-8r clarke floor sander, i need a schurter switch, swiss made, a146f160u4-azm11, 120v, 16 amp. do they still make this part.
I can't find anything on Clarke's website for this tool. But if you have the switch out I would take it to a local repair facility or electrical supply house and have them match it up. There is usually nothing that special about the switches. Let me know if you cant and I will try and dig deeper.
Jan 21, 2009 | Sander Industrial Original Clarke Floor...
Makita BO4556 2 Amp Finishing Sander Logo
Top Makita Tools & Hardware - Others Experts
Jim Thurston
John Porter
Are you a Makita Tool and Hardware - Other Expert? Answer questions, earn points and help others
