My philips plasma 42 inch tv model 42pf3320/10 will not come on with the remote it makes a clicking sound at the back of the tv if i pull the plug in and out a couple of times it comes on but this is taking longer each time
  • jackie280663 Oct 04, 2009
    thank you that was very helpful
  • 3,741 Answers
There are two problems in the tv i will explain both.
1)in the tv there is a ir sensor located at the inner side of the front panel connected to the main board.when you press any button on the the remote facing the tv the ir sensor in the tv gets that command.but in your tv as you said its making clicking sound when you press the remote button that means the ir sensor is weak but not faulty.it needs to be re-soldered.
2)at the back of the tv there is a power supply board.on that there is a power connector from where the tv power cord wire comes out from the tv.that power connector has two pins connected to the main board of the tv.in your tv the two pins are got loose from the main board.but when you again n again remove n insert the plug this pins gets connection and tv turns ON.but this will not last longer.so its advisable that get the loose components on the main board just re-soldered.there is nothing faulty in the tv main board.only the components have got loose so its happening.this is common problem occurs many times and gets solved after getting the loose components re-soldered.a local tv repair shop has this soldering machine you can get it re-soldered from them if you dont have soldering machine .
thanks.this will help.please do rate the solution.thank you for using fixya.keep updated.
Posted on Oct 04, 2009
How do I fix a clicking Philips 42PF5321/10 Plasma TV?
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience.
May 01, 2014 | Philips 42PF9966 42 in. HD-Ready Plasma...
42 inch plasma tv
Power supply needs repair.Est in range of $150 is fair. Find a qualified shop
May 12, 2010 | Philips 42PF9631D 42 in. Plasma Television
My phillips 42 inch plasma tv just clicks when I
There is no lamp in a Plasma TV screen and no ballast.
Check the power supply capacitors.
Aug 19, 2017 | Philips 42PFP5332D 42 in. Plasma...
42 inches samsung plasma screen with sound and without image
Check this link to find the LJ41-02759A board for your TV. These boards fails quite often and the TV will power ON but with the same symptoms as yours.
Jul 15, 2009 | Philips 42PF7220A 42 in. Plasma Television
Just bought a philips 42 inch ambilight plasma t.v,and didnt know the plastic screening round the out side is supposed to light up, how do i go about setting this up?
Bottom left button on your remote should turn the light on and off. if this doesn't work sort through the options on remote and select ambiant light functions
Mar 12, 2009 | Philips 42PF9630A 42 in. Plasma Television
ESA EDTV - 42 inch plasma TV, sound OK no picture.. has vertical lines.
pull plug. allow to reset. try again.
good luck on that, otherwise you need service.
good luck
mark
Nov 28, 2007 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Philips plasma 42pf5520d pictures has gone?
My Philips Plasma TV model 42PF7220A/37 went into "no menu exit" mode on 11/28/2007. I went to www.usasupport.philips.com and downloaded an upgrade. Just followed the instructions and my TV is all better.
Nov 21, 2007 | Philips 42PF9630A 42 in. Plasma Television
LG plasma tv 42 and 50 inch
probably you switch was sticking causing it to behave that way.just monitor you tv if it happen once more then it will be time to call the tech.standby my brother.
Apr 03, 2007 | LG 50PX4DR 50 in. Plasma TV
Televison & Video Logo
137 people viewed this question
Top Televison & Video Experts
Electro Med Services...
