Question about Kenmore Dishwashers
My Kenmore dishwasher starts to fill and then stops
My Kenmore dishwasher starts to fill and then stops working. I have removed the parts inside of the d/w and cleaned the impeller of string and hair. After it ran on quick rinse once. When I ran the normal wash it filled partially and stopped once again.mod.# 58715252402
I've got the same dishwasher....mine is 2 years old and used only 3 times a week and now the motor is burnt out. I understand that this unit is a Frigidaire and is one of the worst ..quality speaking. I guess that why they only provide an one year warranty. Unfortunately, we got a LEMON
Posted on Aug 16, 2010
Kenmore dishwasher filling up with water but never spinning and cleaning
I have had this happen before on my dishwasher. The timer inside the door is stuck or the contacts on the timer may have broken off. When you turn the knob on the dishwasher it sends power to a timer, which continually turns until the end of the cycle. This timer is attached to a bunch of arms which close contacts to send power to different parts of the dishwasher during different times in the cycle, now if the timer is worn out and missing parts of its gears or missing some of the armatures the machine will only get so far along in the cycle until it doesn't know what to do next and just stops. Hope that helps
Sep 06, 2012 | Kenmore Dishwashers
My Kenmore washer would not stop filling with water. i checked and the pressure sensor hose was of the switch, i rehooked it, but it still does not stop filling with water. do i need to do something...
Hello.
Kenmore washer come in a variety of s and styles,including extra-large dishwashers and dishwashers that are accessible for thedisabled.
A Kenmore washer automatically resets itself every time a washingcycle completes.
If you want to reset an Kenmore washer in the middle of acycle, you can easily do so. Resetting a Kenmore washer takes only a fewseconds to complete.Instructions.
1 Press the"Start/Stop" button.
2 Hold the buttonfor three seconds and release.
3 Select the program and options on the frontpanel you want the dishwasher to use. Press "Start/Stop" to restartthe dishwasher. You have now reset a Kenmore washer Thanks.
Jul 30, 2011 | Kenmore Washing Machines
My Kenmore 13593 dishwasher has stopped washing properly. It seems like the spray nozzles are not spinning. Almost as though there is not enough pressure or their is an internal leak. I have plenty of...
Look for plugged screens in the pump area... House water pressure has nothing to do with washing pressure as house water only fills, then the dw pump takes over...
Sep 20, 2009 | Kenmore 13593 Stainless Steel Built-in...
Kenmore Dishwasher 5871525 stops running after a few minutes
sounds like a stuck key pad since you said the normal wash button flashed.. the other thing is try holding the door shut while you run it.. to see of it is maybe not latching properly..
Apr 10, 2009 | Kenmore 15762 Dishwasher
Dishwasher leaks
Sound like the fill valve is not working. I woudl check the hoze for a clogged screen ,then replace the fill valve if no clogs found.
Jan 06, 2009 | Kenmore Dishwashers
Kenmore Dishwasher #587.... doing nothing but heat dry
The problem appears to stem from the float and float switch. The float is a mushroom shaped plastic part that resides on the bottom left, just inside the door. It appears that the float does not release the float switch, causing the dishwasher to think it is full of water, and won't allow the dishwasher to fill. It's a relatively straight forward repair, but even with a new part, the same scenario is likely to repeat itself until the float or float switch is modified by Kenmore.
Nov 20, 2006 | Kenmore 16602 / 16604 / 16609 Built-in...
Dishwashers Logo
363 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
