Question about Toshiba Tecra S1 Laptop Notebook
Toshiba Tecra S1 'Display freaks out' Iserni hello, your help with my display problems for a toshiba tecra s1 was helpyul with one exception... What/whenre is the 'Berg Strip' I took the thing apart because it was out of warrenty and figured i might learn something, which I did... i didn't learn what this strip is. I did not take the actual 'display' apart. I only took the base apart and i did find a small brown wire that was basically 'taped' onto a copper/gold metal strip. This is located under the strip that houses the power button. It really looks like it belongs in another place where there is a receptor like on the wireless card. I have left the power button piece off and when I press by this brown wire, the display quits freaking out. Where is the 'berg strip' and what does it look like? Could the strip this wire is attached to be the berg strip? I can be emailed or called sirectly if this helps. Patrick
    Sergeant:
  • Toshiba Expert
  • 278 Answers
If it is a single wire ,pls check it and connect to wireless card , id it has cover ,don't need to connect. also it has multi wire connector pls connect to display connect on the mother board.
Posted on Sep 23, 2017
5 Suggested Answers
Geekman
  • 32281 Answers
SOURCE: toshiba notbook tecra s1 model no 831l-1104l -- No Display
If you see a very dim image or black screen or flicking image on the LCD screen it means you have a backlight problem.
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Posted on Mar 27, 2009
  • 72 Answers
SOURCE: Hi, i got a toshiba S1 PT831C with 1500Mhz
Its the same type of processor but the thing is their different speeds and one cold be hit by the mobo processor limiter and thats whats casuing it to not show up right, since you flashed the bios it nothing more to do. its onlya prob if you start having issues its nothing to worry aout other than that.
Posted on Jun 17, 2009
  • 644 Answers
SOURCE: Toshiba Tecra S1. My laptop has power but will
It has a memory problem, take the laptop to your local store and ask if they will test the memory for you, if it is the problem then you will have to purchase a new memoy module.
Posted on Jan 29, 2010
SOURCE: my Toshiba Tecra S1 Laptop has lines up and
You have press F1 to enter the bios set up and change the setting after then save changes.
Posted on Feb 24, 2011
My toshiba tecra S1 is showing blank screen after cleaning the motherboard and switching it on
check the cpu sometime the lock is not closed enough ,,, and check the rams did replace them will ? ,,, check the cable connecting the monitor to the motherboard ...
Mar 08, 2012 | Toshiba Tecra S1 Notebook
My Toshiba Tecra S1 Laptop has lines up and
hello,
the flex of your is either getting weak or it has shifted from its original location.. the flex is what connects the screen to the panel of the laptop and when it has a problem you experience lines on your screen..
what you should do is to open up your laptop and try to set the flex to its normal position and see if it stops the lines on your scree, if it doesn't then you have to change the flex
if you cant open your laptop,get someone with experience to help you
goodluckk
Feb 18, 2010 | Toshiba Tecra S1 Laptop Notebook
Jan 29, 2010 | Toshiba Tecra S1 Laptop Notebook
Boot Password
Actually its a malfunction and Toshiba knows it.
You should contact Toshiba, and they will fix it for free.
They will have to flash the BIOS, and fix the bug that caused it.
Please don't forget to rate this answer if it helps.
Oct 30, 2009 | Toshiba Tecra S1 Laptop Notebook
VGA problem
You can download any/all the Windows XP or Vista device drivers for your model laptop from the Toshiba WEB site from their download page. Make sure you enter the model of your laptop so you can get the correct drivers. Use this link :-. http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp#
Jun 24, 2009 | Toshiba Tecra S1 Notebook
I have a problem on my Toshiba Tecra S1 Laptop, Suddenly it stopes working, The main problem is the power indicator front lamp showed the electricity is plugging and the machine also turned on while their...
check your inveter in screen or vga cable maybe los only,.. if the power indicator is working and if you turn on the uit is working but no desplay.. check first the inverter.. if the inverter not problem it means need to open you pc and check the board...
if this underwarranty bring to warranty..
Jun 05, 2009 | Toshiba Tecra S1 Notebook
Cant install windows XP on my Toshiba Tecra S1 laptop.
Where did you get your disk from? It sounds like you may have a bad install disk?
Mar 25, 2009 | Toshiba Tecra S1 Notebook
Toshiba notbook tecra s1 model no 831l-1104l -- No Display
Video Drivers
Goto the following link and search as permodel.
Try this:
Thanks
Iqbal
Mar 23, 2008 | Toshiba Tecra S1 Notebook
Toshiba Tecra S1 Laptop Notebook Logo
153 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
