Question about Craftsman Garden
Solo hablo espanol.tengo una weedeaater 25cc gas
Solo hablo espanol.tengo una weedeater 25cc gas line trimmer ref:7179660 estaba trabajando y de un momento a otro se paro y no
pude arrancarla de nuevo.cual es la solucion al problema.?
Revise gasolina y la mezcla de aceite, filtro del carburador y la bujia.Todo lo anterior se encuenta bien.Que puede ser?
kakee
  • 1269 Answers
SOURCE: Problema router linksys modelo BEFSX41
Can you please post it in English so we can assist you? Thanks!
Posted on Oct 17, 2008
evwood
  • 50 Answers
SOURCE: Trimmer starts immediately, then stops
How old is the trimmer? If still under warranty, Sears can fix this. If not, then my experience has been the problem is a bad coil. This is due to heat build up. When the coil gets hot, it shorts out.
Posted on Dec 07, 2008
SOURCE: Se reinicia a cada rato
tengo un problema con el ADF de una Xerox Pro 215 cuando quiero copiar algo se van las hojas en fila no juantas sin separarlas una por una que podria ser el prolema alguien podria alludarme
Posted on Feb 27, 2009
SOURCE: Require Manual for Ryobi PTL 2543 25cc line trimmer
Or sometimes you unscrew a retaining bolt set into a plastic "lug", the spool drops out, refill t with line, replace it putting line through holes in the spool casing, refit the "lug" and tighten it again. I think I have the manual for this though and if so maybe I can send you a link to images on MSN Homepage to help you..
Posted on Mar 17, 2009
  • 279 Answers
SOURCE: Replaced Poulan 25cc weedeater fuel lines/Now no start
You have/had a fuel filter in the tank.The connector goes to that filter, I think. The length does mean something but I don't know any way to figure it without a manual. You could try to figure from the total length. The fuel filter hold the line toward the bottom. Good luck.
Posted on Jul 14, 2009
Hola tengo un codigo de falla p0301 en mi 99 ford mustang cobra y no se q hacer . ya cambie el coil y sigue la luz de check engine la bujia no es .y para conprobar desconecte el cable q ba ala bobina i no...
puede conectar una spark plug al coil y con corriente a tierra y si hay chispa, chequear el injector de gas, esto se deagnostica de la siguiente forma desconectando la coneccion de el injector si el motor cambia de forma como tembroroso quiere decir q el injector esta trabajando bien, ya solo queda chequear conprecion del los pistones
Jan 23, 2011 | Ford Mustang Cars & Trucks
Mi carro no enciende porque no le estaba llegando combustible, porque la bomba no estaba trabajando, se verificaron todos los fusibles y relay y los mismos estaban bien, procedimos a bajar el tan que de...
Hay un relais del surtidor de gasolina si usted tiene la inyecci?n de carburante y bomba el?ctrica... debajo de la capilla. (busque una caja grande que los parecer ?l puedan contener los fusibles) muchas veces este relais saldr?. Los contactos pueden ir malo.
Jan 04, 2011 | Ford F-150 Cars & Trucks
No tengo audio en mi computadora, en media player si pero cuando quiero ver un video en youtube tengo imagen pero no audio.... que hago
si puede leer un poco inglese, va aqui. tiene muchas photos pueden ajudar. hablo un poco de espanol... no puedo recomendar bastante bien. o repetir su busca en espanol para conseguir consejos mejores. lo siento.
Jan 03, 2010 | Dell Dimension 8200 PC Desktop
Hola mi nombre es christian, yo tengo un pioneer DEH-P7900BT y cuando lo conecto solo prende las luces de los botones pero la pantalla no, no se si esta mal conectado o el stereo no cirva. por favor...
Esto no es una solucion, pero la misma cosa esta pasando a mi. Estava trabajando, pero en un momentito se cebro.
pienso que tu radio no cirva. La misma cosa esta pasando a otros dos personas en estos forums.
my espanol es muy mal.
Dec 08, 2009 | Pioneer DEH-P7900BT CD Player
Problemas de transmision automatica
hola que tal, tengo un saab 9000 1988 y tengo problemas con la transmicion aveses me hace los cambios y abeses no, si abansa para atras y para adelante pero me abienta los cambios cada que quiere,,, alguin tiene idea de que pueda ser?? nesesito ayuda ya estoy desesperado...
Aug 02, 2009 | 2001 Hyundai Accent
La computadora dejo de trabajar al no llegarle enregia electrica
Estimado amigo Jose Diaz.
En la oportunidad que mi lap top no encendia, utilice el poder del AC y la falla continua.
Es de hacerte conocer que tengo conectado la computadora a un dispositivo de regulacion de voltaje para prevenir un salto de corriente que pudiera dañarla. El regulador de voltaje esta funcionando un 100%, y solo lo utilizo para conectar la Lap Top.
Espero me puedas responder pronto.
Tu amigo.
Eleazar Curiel
Oct 23, 2008 | HP Compaq Presario V2000 Notebook
Aire acondicionado
tengo problemas con mi aire acondicionado ..al cambiar el filtro...solo tira aire caliente no enfria en lo absoluto
Jul 06, 2008 | 1994 Toyota Land Cruiser
Idioma
Si lo has comprado en un pais donde se habla espanol, o en un pais europeo o en los EEUU deveria de tener el espanol en los seteos del idioma. Si es asi aconsejo de ir al vendedor y chequear.
Si no tiene espanol puede ser de improtacion. En este caso tienes que re instalar el firmware.
No se si le valdra hacer el update desde el telefono (nececita conesion al internet). Yo aconsejo de ir a un vendedor de telefonos y pedir de reinstalar el software del telefono, es una operacion bastante sensilla. aconsejo de grabar todos los contactos anter de llevar el mobil a la tenda.
Otra solucion podria ser bajar el software desde el internet i instalarlo usted con un cable y una ordenadora, esta operacion tiene un poquito de riesgo si nunca lo hizo antes.
Apr 06, 2008 | Sony Ericsson K750i Cellular Phone
Garden Logo
106 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
