Question about Kodak EasyShare MD853 Digital Camera
My pictures come out purple
Everything is purple, you can see the things in the picture, but in a purple hue.
Pictures are all purple
Hi. not much you can do with cheap cameras. people pay more than $24 for dummy cameras.
you will have to buy better quality cameras if you need better images.
I assume the DVR recorder you are using is of the same quality. But take a look in its menus and see if you can find hue and saturation controls to adjust the color. Some programs let you do it for each camera and others only have 1 global setting.
Jul 16, 2016 | Home Security
Samsung digital presenter purple hue
There is no magic reset button. you can try a firmware upgrade but I doubt this will help. Shop time.
Dec 04, 2012 | Samsung SDP-860 Digital Presenter : SDP860...
My pictures are printing with a purple hue. I
You still have some clogged heads.Head cleaning once is sometimes not enough to clean your heads properly, especially if you are using 'compatible' ink cartridges. You need to clean your heads again, and possibly still again, until your test print pattern produces the correct colours.
Jul 10, 2010 | Canon I960 InkJet Photo Printer
Tv color problem . all orange, green, purple,
Picture is going out.Now days it's cheaper to just get a new one.Try adjusting the hues tins and contrast.
Mar 23, 2010 | RCA Televison & Video
Fuji Finepix V10 Red Pink Hue in pictures and on LCD
Sounds like the sensor ribbon has slightly come out of it's socket.
Just needs re seating
Jan 24, 2010 | Fuji FinePix V10 Digital Camera
HP photosmart c7280 printing photos with purple hue
Does the c7280 use seperate Magenta and PhotoMagenta cartridges? If so make certain the right cartridge is in the correct slot.
Jun 20, 2009 | HP Photosmart Pro B8350 InkJet Printer
Pictures have a purple hue to them Cyber-Shot DSC-P52
I suspect that the color is fine in the screen, if that’s true I would check the “White Balance.” This control is use to compensate for different light sources. The electronics will respond different for sunny or cloudy days and for incandescent or fluorescent lamps. I suspect that it was taken out of AUTO mode. I find that AUTO works well for most people in most situations.
Select photo or movie mode press menu, select WB, select AUTO.
Dec 04, 2007 | Sony Cyber-Shot DSC-P92 Digital Camera
Samsung TXN3275HF 32" tv - purple picture
Chuck the TV - probably It depends on the repair facilities available where you live. In big urban areas the cost of staffing a repair shop is such it can cost nearly as much per hour just to look at an item is it does to buy the next one-plus you get all the latest features.
May 21, 2007 | Samsung TXN3275HF 32" TV
Picture problems
My computer did this and I think my TVs just gone the same way. Was definitely a loose connection somewhere. In the computer monitor it was because the pins in the plug were slightly bent and if I moved the wire the picture got better. In the end I had to replace the connecting cable
Mar 17, 2007 | Sony Grand WEGA KDF-42WE655 42" Rear...
Kodak EasyShare MD853 Digital Camera Logo
211 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
