Question about Ovens
Fan oven does not get hot in fan mode, ok in all other modes
  • 464 Answers
Need to check the convection fan element, it could be burned out.
Posted on Oct 04, 2009
Why does the fan mode on the bottom oven on my zanussi Zou575 not working?
Because in Main Oven Cavity (large) around the convection fan is very powerful ring heating element 2500W (not visible) who works in the Fan mode. Therefore, it is not necessary that all heaters work because it will overheat the oven.
Dado
Aug 25, 2014 | Zanussi Ovens
I set my kitchenaid superba self clean oven to clean mode. It cleaned it however now I cant get the oven to work. Stove top works but oven doesn't. What can I do to fix this?
Pyrolitic mode heats up quite hot. Might have tripped the high temp cutout.
Does the oven fan work? if so >> check element
Oct 17, 2013 | Ovens
I have a kenmore oven. Just got an F2 error and the oven element will not turn off. Even when powered down, it heats back up when oven is in off position.
Range "Older Style"
F2 Oven too hot Replace relay board (if present) or oven temperature sensor
Range "Newer Style"
F2 Oven temp sensed; over 600F sensed by control in time of day mode, bake mode, or over 900F sensed in clean mode. Ohm test the oven temperature sensor, if OK, change power relay board.
Oct 17, 2012 | Kenmore 40494 / 40495 / 40499 Electric...
Gaggenau fan oven lights and fan are on, but there's no heat and the triangular heating signal light by the dials doesn't light up. What could be wrong? 3900W, 400V, 50Hz. E-nr EB140210
this could be a simple and easy thing check your clock is not in auto mode it need to be in manual mode ok if the clock is ok then its your heater element has gone ok
Oct 15, 2012 | Ovens
We bought a deDietrich oven UMP412 (Ser No 02-24-06004) on 31/08/2002. Recently the heater behind the in-oven fan blew and was replaced together with the lower heater (which was found failed) and main...
Hi Maurice.
Circulating is Fan Assisted mode. In this mode the fan kicks in when temperature is reached and runs all the time.
Here an extract from manual.
There is no preheat unless you set temperature. That is why you get the fan from start.
Oct 20, 2011 | De Dietrich Ovens
MY OVEN GETS HOT IN CONVENTIONAL MODE BUT DOESN'T IN FAN ASSISTED MODE
If the fan is working o/k, then it is going to be the element that is faulty.
This is located at the rear of the oven compartment behind a removeable cover, it is a round element
Dec 17, 2010 | Zanussi ZHQ575 Electric Double Oven
OVEN DOES NOT HEAT IN FAN ASSISTED MODE but the fan works ok
I would suggest that the oven element is faulty
This is located at the rear of the innner oven compartment behind a removeable cover.
Mar 10, 2010 | Neff U1461 Double circotherm plus Electric...
In fan mode oven very slow to heat up [ fan is working] all other functions ok
If you can, test the oven fan element, if you can't, then feel \at the back of the oven compartment in front of the fan, you shoud feel hot air blowing, if not, then you need to replace the oven element.
Please rate my solution.
Thanks.
Nov 04, 2009 | AEG B5741-4 Electric Single Oven
FAN COOKING MODE ON COMPETANCE B4101-4 NOT WORKING FAN WORKING BUT NO HEAT CONVENTIONAL MODE OK
If fan is working o/k, then you need to fit a new oven element.
Thanks.
Sep 26, 2009 | AEG Ovens
Bosch oven not heating to temp
Dear customer,
i recommend u to try the following routine to sort out this problem
  • Check timer and clock settings
  • Reseat the element
  • Test the element
  • Test the element connectors
  • Test the oven temperature control
  • Test the oven selector control
  • Recalibrate the temperature control
  • hope u find this useful. thank you.
    Jul 08, 2008 | Ovens
    Ovens Logo
    44 people viewed this question
    Top Ovens Experts
    Dan Webster
    Dan Webster
    ashburton
    Are you an Oven Expert? Answer questions, earn points and help others
