Question about Dryers
While in the drying session, my dryer squeels. What might it be?
    President:
  • 1,564 Answers
There are to felt and steel seals on the drum. One is located at the front and the other the rear. After a good deal of heat and friction these seals can fail which leaves a drum rubbing on the metal inner ring.Hence the squeak. To check these your dryer has to be dissasembled. If you're a good DIY'er you can do this. If not it's best left to a proffessional. Thanks, Dana
Posted on Oct 04, 2009
  • 339 Answers
Most likely a loose or dirty belt.
My dryer will run and dry clothes but as soon as the drum starts to turn it has a constant squeeling noise ( not a squeek like the wheels would cause) what is my problem and how can I fix it?
some dryers has a center bearing on the rear of the drum, once this bearing dries out it will make noise along as the drum turns.
Mar 25, 2015 | Dryers
FPaykel Dryer model # DE05US2 is making a screeching LOUD sound ... still turns and dries just VERY VERY LOUD and high pitched squeeling
It could be bearing or guides in the drum.Go to http://fisherpaykelparts.net/techhelp/fisher-paykel-top-load-dryers-us-models/ This forum will work you through your problem
Sep 27, 2010 | Fisher and Paykel DEGX1 Electric Dryer
Squeeky dryer
belt is stretched from a worn bearing in the belts idler pulley
Replace the belt along with the pulley sold at most Sears stores
Jun 20, 2010 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
Squeeling while drying
worn belt, needs replacing
Oct 07, 2009 | Dryers
My Kenmore dryer squeels when drying. It is an electric dryer, about 4 years old.
Two things the dryer drum is turned by a belt that goes around the motor, drum and a tench pulley. The tench pulley could be making the squeal. Or the drum rides on two wheels on the bottom side of the dryer they go bad and need to be replaced.
Jul 14, 2009 | Kenmore Dryers
Dryer started out squeeling and now is making loud sounds?
This is very likely due to bad drum support rollers which is really not a difficult repair on these dryers.
Whirlpool Dryer Repair Manual
www.RepairClinic.com
Feb 02, 2009 | Whirlpool LER4634J Electric Dryer
GE evolution dryer has intermitent squeeling!
Is the belt slipping? Check and see if it is worn. Open door, remove 2-4 screws at 12:00 position, lift up cover. The belt is the little band wrapped around the big thing.
Jan 25, 2009 | GE DBL333EA Electric Dryer
Dryer making horrible squeeling noise
this is normally a problem with rollers that have gotten dry bearings , take the drum out check the rollers if they turn hard or act sticky you may clean them up and and oil with turbine oil , do not use wd-40 or 3in 1 as these will dry the bearing, check the idler pulley while you have this apart also oiling it if need be
Dec 30, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Dryer help
Pop the top and get the front off. Get the ball of lint out the blower housing and replace the bad blower wheel.e00d80d.jpg30eaeb0.jpg
Dec 16, 2008 | Dryers
Dryers Logo
54 people viewed this question
Top Dryers Experts
