Question about Xerox XC356 Copier
GETTING STREAKS ON COPY. - Xerox XC356 Copier
    President:
  • Xerox Master
  • 990 Answers
Hello sir; It's time to replace drum cartridge. after you replace still have problem then let me know.
Posted on Oct 04, 2009
Hi, My Canon 3245 Imagerunner is streaking.
First, the streaks appears when copy from glass or adf, when printing or all?
Solution #1:
How many copies did you do from last drum changing? if over 80 000 copies, replace the drum unit.
-in case that streaks appears when copy and print
Solution #2:
If the streaks appears only if you copy from adf or glass, clean the glass and dry it out. Both glasses, narrow on left side beneath the adf/cover and glass for copy of original.
Solution #3:
If the streaks are wide and solid, with possible toner left overs, you need to replace fixing film.
Hope that helps!
Apr 04, 2011 | Canon ImageRunner 3245 Black and White...
Printed document has white streaks. I've replaced all toner cartridges AND replaced the toner waste unit. The streaking occurs when I print or copy but is much worse when I make a copy. Is there a printing...
If you are getting vertical white streaks or faded streaks from the top of the page to the bottom. It sounds like the developer blades in the imaging unit needs to be replaced. It cost around $120 to replace, but after a while it will happen again. This is a common problem with this printer. It can be cleaned by taking the unit apart and cleaning the developer blades, if you are handy. I have posted detail instructions in my tips section. or you can click on this link:
http://www.fixya.com/support/r4120906-clean_developer_blades_samsung_clp_300.
Hope this helps.
Jun 13, 2010 | Samsung CLX 3160fn All-In-One Printer
I have a PC 25 copier. I am getting black streaks
Run a copy and shut the machine off when the copy is half way through. Open the machine up and remove the toner cartridge. Turn it over and slide open the flap that covers the drum. If you see toner streaks on the drum surface similar to what you see on the page you have a defective toner cartridge. Most likely the toner you bought is remanufactured as this machine is very old. Maybe you can return it for another.
Oct 18, 2009 | Canon Office Equipment & Supplies
I have started getting streaks on Image Runner 2020
Try to print something, if there is any streaks?If no the problem is in copy glass (dadf or platen glass).
If there is streaks on print also,it could be the drum unit ( pull the drum unit out and see if on drum surface is any black streaks), fixing film is worn out, and in the worst case you have problem with toner unit ( on toner unit you have current leackage ) and you need (in best case) clean the contacts on toner unit, and in more expencive case tochange the toner unit.
Oct 01, 2009 | Canon imageRUNNER 2020 All-In-One Laser...
New toner but still have dark streaks
IF YOU ARE ONLY GETTING THE LINES WHEN YOU PUT THE DOCUMENTS INTO THE TOP FEEDER AND NOT FROM PRINTNG TO COPIER OR IF YOU PUT A COPY ON THE GLASS UNDER THE DOC FEEDER AND NO LINES APEAR CHECK THE SMALL GLASS WINDOW UNDER THE DOC FEEDER THERE MAY BE SOME TIPEX OR INK RUBBED OFF AND LEFT ON THE GLASS THERE.. THISD MIGHT BE CAUSING THE STREAKS YOU CAN CHECK THIS BY PUTTING THE PAGE IN THE DOC FEEDER AND DOING A COPY AND THEN PUT IT ON THE GLASS PLATE UNDER THE LID AND DO A COPY OR IF HOOKED UP TO COMPUTER DO A PRINT JOB.. IN NO STEAK APPEARS YOU CAN BE SURE ITS ON THE THIN SCANNER GLASS.. GOOD LUCK ...a
Jun 24, 2009 | Xerox XC356 Copier
Black streaks all over copy
Copies come out with one black line
Feb 05, 2009 | Sharp AL 1631 Copier
Constant Streaks
If the streaks only happen when using the document feeder, cleaning the thin glass strip on the left of the machine will help.
Mar 17, 2008 | Canon imageRUNNER 3300 All-In-One Laser...
Black streaks on printout page
It sounds like excess toner has built up in or around the imaging drum. I would *carefully* remove the toner and drum (can be messy) and use some canned air to clean the inside out. If you are still getting these streaks, it might be time to get a new drum (DR 400) as you are supposed to replace the drum every 6 to 8 times you change the toner cartridge.
Aug 22, 2007 | Brother HL 1440 Laser Printer
Xerox XC356 Copier Logo
159 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
