Question about Horizon T93 - Treadmill
I have a tsc4 horizon treadmill and it just shut off with an error of E1. I just replaced the circuit board in Feb 09, any answers
2 Suggested Answers
2manyhobbies
  • 128 Answers
SOURCE: I have a Tsc4 treadmill
E1 Is an RPM sensor error message. It simply means either the belt is not moving or the sensor is defective.
If the belt moves slowly then shuts down, check the RPM sensor located close to the drive pulley (under the motor hood). verify that it is as close to the pulley as possible without making contact. Verify that the magnet is present (mounted on the pulley). it will be a small round magnet, 3/8-1/2 inch diameter. If the magnet is missing, it may have attached itself somewhere on the treadmills frame. Reinstall it in the pulley.
Often there is an RPM LED located on the controller PCB. By manually passing the magnet past the sensor, you should see the LED flash. If so, that verifies the operation of the sensor, if not replace the sensor.
If the belt doesn't move at all, likely the motor controller PCB is defective..
Posted on Dec 17, 2010
Why my treadmils start working and and stops
Hi There, sorry to hear of your troubles. Could you mention what brand and model of treadmill? If this is a Horizon treadmill with E1 error, like models T101 and others from the years 2011-2013, there is one thing you can try. Unplug the treadmill and remove the motor cover to get to the Motor Control Board, or MCB. Be certain the treadmill is unplugged from the wall! Now, look on the MCB on the right side there may be ONE small blue "block" with a tiny screwdriver slot in the center, this is called a potentiometer, and if there is Only One, and a Horizon MCB, you can turn this pot to the right, clockwise, gently until it stops, and then back it off just a hair, reassemble unit, and try treadmill. If this doesn't help, the MCB most likely needs servicing due to failing storage capacitors which get quite hot while in use and can degrade over a few years of service. You can find some help by looking up jatinah electronics, who repairs these modules. Good Luck! ;o)
Jan 26, 2015 | Exercise & Fitness
My horizon 4.1t treadmill will incline/decline but does not run. showing an e1 error. please help
1) Adjust the speed sensor, clean, and tight the connector very well
see the diagram
2) Lube the deck belt, by lack of maintenance,
3) Test the motor input voltage, if there are the motor need repair.
4) Test the output voltage board, for input voltage motor,if there are the board is ffaulty.
RUN the software calibration for diagnose and troubleshooting.
May 09, 2012 | Exercise & Fitness
My Horizon fitnessT101 is brand new and i put it all together.Than i used the magnetic key and started it and the treadmill didn't start it just displayed E1 on the monitor.
Had same problem. I called horizon and after troubleshooting, they could not solve and replaced the entire circuit board. I was under warranty , so i was fortunate to not have to pay for one.
Sep 09, 2011 | Horizon Fitness Horizon T101 9 Program...
I have a Tsc4 treadmill that has worked perfectly until now, when it shut down displaying a E1 error message...any ideas on what to do? Thanks :)
Dec 17, 2010 | Horizon T93 - Treadmill
After starting the treadmill 10 seconds later E1 apears on the display
Your problem is that a magnet has fallen off. Here's an illustrated guide that should make fixing it easy: http://fixmytreadmill.blogspot.com/2010/10/how-to-fix-treadmill-e1-error.html
Good luck.
Sep 16, 2010 | Horizon Fitness Merit Fitness 725T...
Treadmill cuts out after 10 seconds and gives an E1 message.
Your problem might be that a magnet has fallen out of place. Here's an illustrated guide that should make fixing it easy: http://fixmytreadmill.blogspot.com/2010/10/how-to-fix-treadmill-e1-error.html
Good luck.
Jan 23, 2010 | Horizon Exercise & Fitness
E1 error code
Your problem might be that the sensor magnet has fallen off. Here's an illustrated guide that should make fixing it easy: http://fixmytreadmill.blogspot.com/2010/10/how-to-fix-treadmill-e1-error.html
Good luck.
Jun 20, 2009 | Exercise & Fitness
Error message E1
hi there we have an E1 error after 7 seconds of operation??
Apr 09, 2009 | Exercise & Fitness
Tredmill error code
Moat likely a problem with the motor control board. See treadmilldoctor.com
Apr 16, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Horizon T93 - Treadmill Logo
Top Horizon Exercise & Fitness Experts
Electro Med Services...
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Are you a Horizon Exercise and Fitnes Expert? Answer questions, earn points and help others
