Question about Dewalt D24000S Wet Saw With Stand
Wet tile saw just stopped cutting; I only cleaned the water tray??
  • 54 Answers
How thick is the diamond bearing segment running around the rim of the blade? There needs to be at least an eighth inch. The last part contains no diamonds. If their is sufficient diamond left the material you were cutting may not have been abrasive enough to expose new sharp diamods. You can cut a small piece of asphalt. This will wear the matrix down so new diamonds are exposed.
Posted on Nov 19, 2009
Where do you put the water?
Most wet saws have a water tray below the table area. The blade moves thru this tray and gets cooled and lubricated by the water
Mar 06, 2015 | Qep 60087 Table Tile Saw 7" Wet
I have a 10" ridgid
With bigger tiles I have to cut more than half way, and then turn tile around and cut last bit from other direction.
You might be able to cut half way down tile, and then move tile forward on tray.
My wheels come to a stopper and don't run off the track, so my saw is different than yours.
Jan 24, 2011 | Ridgid 10"Wet Tile Saw with Laser and...
Cannot keep water on the blade of my 10" Rigid wet
if waters not getting to the blade you will see the powder of what ever your cutting coming off the back of machine,i like to put my pump in a bucket of water under the drain plug instead of puting the pump in the water tray,you can run bigger tubing up to the blade and reduce it down and it will give you better presure,good luck
Dec 31, 2010 | Ridgid 10"Wet Tile Saw with Laser and...
Applied dark brown glass tiles and those that were cut with a wet diamand blade saw are darker in colour to the others. will cut tiles become the same colour as other non cut tiles?
THIS COULD BE CAUSED BY 1 OF TWO THINGS, WHEN YOU USE WATER TO CUT ANY TILE YOU ARE INTRODUCING WATER TO THE INSIDE OF THE TILE WHICH WILL CAUSE THIS DARKENING OF THE TILE, 2ND WHEN YOU WET CUT USE A SLOW LITE PRESSURE LET THE BIT DO THE WORK TO MUCH PRESSURE AND NOT ENOUGH WATER WILL CAUSE OVER HEATING AND DARKEN THE TILE. HOPE THIS HELPS. ALSO
THIS DOESN'T ALWAYS WORK BUT AFTER CUTTING PLACE TILE IN A HEATED AREA TO DRY OUT THE WATER ,THE GLAZING IS WHAT PROTECTS THE INSIDE
Dec 01, 2009 | RTO 1/8"wet Diamond Glass, Tile, Stone,...
Ridgid Wet Tile saw water pump operates, however the water is not getting directed onto the blade. Hose partially plugged? How to clean nozzle?
You could clean the hose ... however, I think Id get to the hardware store and get a new piece.
Clean the end with a broom straw. You could trim a small piece of the hose off. Dont neglect to clean the filter on the pump. Slide the bottomoff the pump to expose the filter.
Oct 21, 2009 | D Cut CS-070 Wet Tile Saw
Nada
According to my translation your question is:
"I would like to know the price of water for cutting ceramic tiles"
Your best bet is to figure out how much water you will require and then call the water company to inquire what the charges would be for that amount.
Aug 17, 2009 | Ridgid 10"Wet Tile Saw with Laser and...
How to fix a tile saw pump
take it all apart and clean it completely. They do not put pump in saw water, use only totally fresh and clean water.
Jul 14, 2009 | RTO 6391K Felker 24" Tile Master Plus Wet...
Wet saw not cutting material completely
It might need a new blade. But try putting an old tile or offcut behind the tile you are cutting. Make sure the table surface is clean and flat. Residue tends to build up around the front of the blade which could cause the tile to crack. The ryobi's have a habit of water getting into the motor and the bearing destroys itself. Next time you take the blade off, take of the blade support and put bearing grease behind the rubber washer. I've blown up two this year until I worked out what the problem was.
Apr 25, 2009 | Saws
Crooked cuts
The bearings in your saw need to be replaced. I would contact a DeWalt store to obtain the parts or have them do the repair. You have an excellent saw there, well worth repairing. good luck.
Jan 04, 2009 | Dewalt Heavy - Duty 10" Wet Tile Saw -...
Dewalt D24000S Wet Saw With Stand Logo
307 people viewed this question
Top Dewalt Saws Experts
Parson's Repair...
Parson's Repair...
JOHN LAPIER
Are you a Dewalt Saw Expert? Answer questions, earn points and help others
