I have a philips plasma tv model 42pf3320/10 i have to plug the tv on and off from the socket to get it on it clicks at the back of tv for a whie before it start to come on
jdbouncer
  • 72 Answers
SOURCE: plasma tv
Ok first i have to ask when u turn sound off on TV and get close to the TV does it make a buzzing noise ? If so u have a damaged Plasma panel .
If this is not the problem you could have a bad logic or y-main (most common problem) will need to perform a white screen test on the plasma panel to verify this is the problem.
This is what u need to do
1. Remove the back panel of the TV.
2. Remove the Small Signal Board bracket ( the two long bars on back of the plasma panel, the bracket that is connecting the two with SSB on it, remove this and disconnect the connectors to the power supply (CN1M02,CN1M03, CN1M45)except for the main power plug in you will still need this)
3. Once u remove the SSB bracket you should see a plasma panel resembling pic 1.
4. Place a jumper wire or connect the two pins (CN 2012) on the logic board located underneath the SSB bracket.
5. Also place jumpers on the power supply (J8003 and J8004)
6. Now plug in the power supply, U should hear the relays click and after 5-10 sec you should see a green led on power supply, and 2 green leds on logic board 1 will be solid and 1 will flash.
With this set up you should get a white screen on your TV this will let you know if the panel is bad or not.
Also forgot to ask have u had this TV worked on recently or this just happen for no reason.
Posted on May 10, 2008
SOURCE: philips plasma tv model#42PF7320A/37
yeah my tv the black bar is getting bigger and bigger
Posted on Jun 12, 2008
  • 166 Answers
SOURCE: Got a philips plasma tv
A possible cause is the 1.0uF.630v capacitors in the power supply need changing.SUPER8
Posted on Nov 26, 2008
dsacco86
  • 1077 Answers
SOURCE: Philips 50 Inch Plasma Model 50PF7320A/37 will not turn on
Commonly it's going to be a power supply related problem. The two boards that need to be looked at is the Main Power Supply Board or the power supply board for the screen. The one that powers the screen, some manufactures call it a Backlight Inverter Board.
If you have some electronic experience, you can sometimes find a Service Manual for the TV over the internet for less than $20. It will have the all resource material for repairing your TV model. It's just the matter of replacing the bad part on the circuit board.
Posted on Aug 12, 2009
SOURCE: Panasonic plasma TV model TH-42PD60U won't turn on
I had this problem in 2007 / 2008 here is what happened to me. Jan 09, 2008 - I also have brought the unit to the authorized Panasonic repair facility and the problem is a failure in the P-board which is the power supply board. The P-board needs to be replaced. The repair will cost $475 plus tax. $250 is for labor. The unit was nop more than two months out of warranty. This does not speak well for Panasonic. I have been researching the problem and it looks like this has happened to many of the Panasonic plasma TVs.
Jun 14, 2008 - As an update to my problem with the failed P board. Contacted Panasonic Service and talked to a customer service representative. I told them how I have purchased many Panasonic products and how unhappy I was with the failure of the product. They proposed paying the labor cost of $250 and I would pay for the part. I just hope it does not happen again.
Posted on Oct 14, 2009
PSU on philips 50" plasma just clicks when powered up and TV does not show any lifr in audio or video. Green light responds to the remote..
Sounds like sustain board fault. Check and replace the damaged one. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Dec 04, 2015 | Philips Televison & Video
How do I fix a clicking Philips 42PF5321/10 Plasma TV?
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience.
May 01, 2014 | Philips 42PF9966 42 in. HD-Ready Plasma...
Hi i need how to connect this to my rca tv
Very easy, try this. take a set of red/whie and yellow av cables. Peel the yellow wire off the red/whie ones like a banna peel. connect the yellow wire to Video out on your DVD player, other end to Video in on the TV. part one is done and your ready to watch movie, get the TV remote and set the TV to the coreect inpout using TV/Video button or input. now take the red/whie cables. now if you have a satellite or TV converter box find the red/white audio out jacks and connect those to audio OUT, then connect the other end to audio or AUX input on the Surround sound, push the function button on the surround sound until you get to AUX mode and bang, you got TV audio from the satellite or TV box.
Oct 05, 2013 | Philips MX5060D System
I have a philips model 50pfp5332d 37 We turned it on and it just clicks (like it is turning off an on) no picture, nothing. Will not respond to the remote or to the on off switch. Had to unplug to stop...
The tv power supply board is the causes and the problems.That the board,where the power a/c cord plug into it.Try website like Ebay.com to buy a whole refurbish power supply board for the replacement.
Nov 28, 2010 | Philips 50PFP5332D 50 in. Plasma...
I want to connect to a pc (vga) but don't have instructions
First ensure your tv has a vga socket at the back. You will need a vga cable with 2 male ends. On the pc goto display properties by right clicking on the screen, goto settings and adjust the slider at the bottom of the window to 800 by 600 resolution and adjust the bit rating to 24 or 16 bit. Plug the cable both into the tv vga socket and the pc vga socket, and boot the pc. Make sure the tv's input is set to pc or vga and you should now have windows on your tv. Hope this helps
Oct 27, 2010 | Philips 42PF7320A 42 in. Plasma HDTV
42PF9630A 42 in. Plasma Television: hi there, I have a phillips 42 inch plasma flat...
This is because the power switch operated the socket that your TV is plugged into. Unplug it and plug it in another socket that is not operated by a switch. Appliances should not be plugged into a socket operated by a switch because of the inconsistency of power to the socket. Lights are about the only thing that should be plugged in.
Dec 23, 2017 | Philips 42PF9630A 42 in. Plasma Television
I just bought a philips 42" flatscreen TV model #42ef73208-37 and it won't turn on. I have a red blinking indicator light but the TV won't turn on, what can be the issue?
  • Your TV has a protective mode in case there is too much heat build-up.
  • Check the clearance around the vents of the device to be certain there are no blocking walls or cabinetswhich would limit the air flow.
  • • Check that the TV’s AC power cord is plugged into the mains socket.
    • Unplug the television, wait for 60 seconds.
    Then re-insert plug into the mains socket and turn on the television again.
If that fails take it back.. Good luck
Sep 09, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
Aug 12, 2009 | Philips 50PFP5332D 50 in. Plasma...
Philips ambilight 42inch plasma
You can fix this yourself with a software upgrade - get the upgrade from Philips website - go to www.usasupport.philips.com, enter your model number, click on the verison of your model ending in /37, and click on "Software & Drivers"; click on the link that says "Firmware Upgrade - Software". Instructions are on the same page - make sure you only transfer the .upg file, not the entire zip file to a portable memory stick.
Jun 08, 2008 | Philips 42PF9630A 42 in. Plasma Television
Televison & Video Logo
61 people viewed this question
Top Televison & Video Experts
