Question about Goodman Heating & Cooling
Generator will not run furnance
Generator
    President:
  • 1,714 Answers
What is the voltage level from the generator? Does the furnace run fine on electric? What is the Btu or Wattage rating of the furnace? What is the Wattage rating of the Generator?
Posted on Oct 04, 2009
RUUD Air Conditioner not turning on
Need to check the breaker to the unit at the electrical breaker box. You should have a dual 60 amp breaker that runs the unit. Also if you removed the front of the furnance on the inside the system will not work unless the front of the furnance is on. There is a safety switch that will not allow the system to run with the door off. There could be the problem if the breaker is on and electricity is supplied to the unit that switch may be out and need replacing. The furnance is operated on 110 volts the condensor (outside section) operates on 240v you need to insure that the proper voltage is supplied to both.
Since both units work together yet operate seperately if the furnance comes on and the condensor doesn't then there is an electrical problem at the condensor (more than likely the contactor switch) if the condensor comes on and not the furnance then there to is an electrical problem (either 110 volts not supplied) or the switch to the safety cut off is bad. Now if neither furnance nor condensor comes on there could be improper power to both or a bad thermostat since the thermostat activates both furnance and condensor. Good Luck on repairs
Dave
Sep 04, 2009 | Ruud UBHC Air Conditioner
Furnance not starting
Try cleaning the flame sensor. Its the most common problem on todays furances. You should clean it with a fine grit sandpaper or emery cloth once a year.
Apr 11, 2009 | Heating & Cooling
Water keeps running into humidifier even furnance blower is not
This sounds like, the 550 transformer is not connected to the blower motor power connection (in parallel)
Feb 19, 2009 | Aprilaire 550 Humidifier
How to connect a Honda EU3000is Generator to run the home furnanc
In shor NO.....
1st item to buy if you must conect to your house is a change over switch.it HAS TO ISOLATE THE MAIN LINE TO THE HOUSE< OR YOU WILL KILL SOME ONE....the other thing you have to know is the house just a single phase or a multi.....to save you life and the lines man working on the line when you run your genset, get a contractor to do it....
Jan 28, 2009 | Electrical Supplies
Fan in furnance
any furnace with a blower will go on your electric bill but it really should'nt draw enough power to raise your bill noticably unless it's running constantly.
Jan 24, 2009 | Coleman Propane Forced Air Heater...
Carrier furnance keeps running
check for open limit switch, their are multiple, check return air filter.
Dec 17, 2008 | Heating & Cooling
Progrmmable Thermostate
Check to make sure you have pm or am set correctly. Or reset everything. ??? ;)
Dec 13, 2008 | Hunter Fan Company 5/1/1 Programmable...
Heating & Cooling Logo
109 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
paulcarew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
