Question about Gestetner DSm615 Digital Imaging System
Machine display an error code sc 500
Hi Nogging
my machine stop working and I have tried my level best to rectify
the fault arise with no successiful by using sp mode 107 and I went direct
to the mode as well I tried to accelerate with arrows to find out the word concern still I fail. as longer as the machine is working sometimes as a printer but the mainly duty is worked as photocopy machine
please advise how shoud I go about to rectify such problem.
regards
Jordan Jasson.
    Problem Solver:
  • 6 Answers
YOU MUST RESET machin by: press clear mode key(yellow)---enter 107 by keyboard----press clear/stop key (red) for4 seconds--- turn off machin and on
Posted on Sep 17, 2012
Our University Gestetner MP 1600Le displays an error code SC402. Could you please assist us on this regard.
Eastern University,
Sri Lanka.
Posted on Feb 12, 2008
Ricoh 3045 sc865-01 , any solutions ?
In general the SC 860-900 refer to HD acces error.
SC 865 - the hard disk detected an error.Error detected other that the bad sectors error SC 863 or the CRC error SC 864.Reset the error code by turn the operation switch and main power switch OFF and ON.Try disconnect and reconnect the hard disc connectors and verify the cable.
Feb 20, 2013 | Ricoh Aficio 3045 Digital Copier: 45cpm....
My Aquasmart WL80T65D washing machine is telling me that it cannot lock the lid - but it is shut and appears to be in place.\r\n Does anyone have any suggestions for this?
Hi just read your posting.Does the machine stop and beep and show an error code in the form of lights on or an error code in an LCD display?Please reply with additional information and I am sure I can help you rectify the fault.Looking forward to your reply.
Oct 10, 2010 | Fisher and Paykel Fisher & Paykel Washer
FAULT CODE 124-373 ON WORKCENTER 5225 WILL NOT CLEAR
Xerox 5225 keeps showing error 124-373 and cant one to enter into set-up or status mode.How to correct this error?.I have jobs to copy for urgent meeting soon.your email is needed
Aug 28, 2010 | Xerox Workcentre 5225 / Copier, With...
When copier is putting on , it displays " error code SC:551"
There is a bad thermistor in the fuser most likely.
You can try pressing Clear all then 107 and hold the stop button down.
That should put you into the SC area. Press copy sc then turn the machine off and on to see if it clears the fault.
Otherwise replace the thermistor.
Aug 01, 2010 | Ricoh Aficio 2015 Copier
Fault code 104
Hi just read your posting.Unfortunately in my manual it says that error 104 is Comms. Error Time-out.This means that there is an error in the communications between the Display module and the Motor controller. Now to rectify this fault the manual says to 1st change the Display module, and if this doesn't rectify the fault change the Motor controller. And lastly if you have changed both these parts and it still faults the manual then says change the Rotor Position Sensor.There is no way to check which part is actually causing the fault and the recommended way to rectify this fault is to change parts until it works correctly.I am sorry for the bad news but on this fault you might have to obtain the service of a technician.Unless there is a place you could send the motor controller and display board and get them checked out for faults.I am in Australia and there are a few places here that do this service but maybe you could ring your local Fisher and Paykel agent and see if they know of anybody that could help you in your area.Please reply for further help and to tell us how you got on.
Jul 06, 2010 | Fisher and Paykel GWL11 Top Load Washer
After washing heavy load mashine spin cycle not working
Hi just read your posting.Does your machine drain the water .When your machine stopped doing the spin cycle did it start to beep and show a series of lights as an error code?Or have you got the model with the LCD display and it showed an error code in letters?If you have the model with lights and your machine beeped the lights that did come on will be in a row of 8.Starting from left to right is it the 2nd and 5th lights on or the 4th and 8th lights---etc---- that are lit? Please reply and I can help you rectify this fault for you.
Jun 26, 2010 | Fisher and Paykel GWL11 Top Load Washer
RICOH 2015 error code sc 500
Main motor/ transport motor lock/ fusting motor error.
The only thing you can do is check for any obstructions in the machine.
That needs to be looked at by a service because the problem could be a motor, a pcb, or a power supply.
It can be a lot of troubleshooting to do.
Oct 18, 2008 | Ricoh Aficio 2015 Copier
Code 541
hi!!!!!
may be the was damaged
or
try to clean use dry tissue
or replaced the drum
Sep 21, 2008 | Ricoh Aficio 2018D All-In-One Laser...
696 people viewed this question
Top Gestetner Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
