Home | Honeywell | Power Humidifier: Furnace Humidifier/ Hum... | HOW DO I CONNECT TO 24 ...
Honeywell Power Humidifier: Furnace Humidifier/ Humidifier
Problem for Honeywell Power Humidifier: Furnace Humidifier/ Humidifier
HOW DO I CONNECT TO 24 VAC FOR THE HUMIDIFIER TO
By atclo1 on Oct 04, 2009
HOW DO I CONNECT TO THE 24 VAC --- FOR THE HUMIDIFIER TO COME ON ONLY WHEN THE BLOWER IS ON?
I FOUND THE 24V (A BLUE AND YELLOW WIRE) FROM THE TRANSFORMER, BUT CONNECTING TO THEM MAKES THE HUMIDIFIER REMAIN ON ALWAYS.
NEED TO FIND A WAY TO GET THE 24V ONLY WHEN THE HEAT IS ON.
UNIT IS A LENNOX (MODEL) G41UF-48C-110-02
Solution #1
posted on Oct 28, 2009
Not Rated)
knthms5
Rank: Wiz  Air Conditioners  Expert
Rating: 83%, 22 votes
if you have 1220v eac terminals you may use those but a current sensing relay is the right way
Was this helpful?
Yes
No
Solution #2
posted on Oct 04, 2009
Not Rated)
mac5932002
Rank: Guru  Honeywell Air Conditioners  Expert
Rating: 88%, 52 votes
you can hook it to R and W on the board but you should really use a current sensing realy on the blower so it wont come on until the fan is running and you should also have a humidistat
Was this helpful?
Yes
No
Popular Solutions for Honeywell Power Humidifier:
Questions and Unsolved Problems for Honeywell Power Humidifier:
Do you recommend Honeywell Power Humidifier: Furnace Humidifier/ Humidifier?
Answer
Answer
I have one humidistat honeywell H8908B which presently controlls honeywell humidifiers(HE440A ). I... (More)
Answer
I am getting six blinks on the call for service light after I push the reset button.What does that... (More)
Answer
Chronotherm III...Replace Battery notification blinking...replaced twice with the appropriate... (More)
Answer
"replace better" msg light came on; I replaced with 3 AAA Alkalines...3 days later, same... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Honeywell Power Humidifier:...:
Top Humidifier Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Humidifier Experts
Top Air Conditioner Repair
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
