Question about GE Profile PSI23NCR Side by Side Refrigerator
Ge profile side By side ice maker water leak
I have a ge proflier side by side refrigerator.There was water leaking out of water dispensor area.I pulled out ice maker tray & found water leaking pretty heavy out of ice maker.I can not see back in there-Any suggestions? Unit is approxx 9-10 years old Thank you
  • 1 more comment
  • Anonymous Mar 21, 2014
    Water leaks into tray
  • Anonymous Mar 25, 2014
    is there a water tray underneath the refrigerator it keeps leaking water
  • Anonymous Mar 26, 2014
    Side by side 10 year old GE Profile refrigerator. Fluttering sound is not constant and loud when I open the fridge door.
  • 833 Answers
This sounds like the float mechanism has gone bad. Remove it and have a look. It may be the float or the switch on it that is bad. There is also a solenoid valve. Parts kits are available. Shut off the water first!
Posted on Dec 22, 2007
Water is leaking down the side and back of the freezer from the ice maker. I have the GE CAN9 ice maker. Were is the ice maker water valve located ?
Bottom right in back of ref.<br /> Its what the water line from the wall attaches to.<br /> <br /> <br /> If this was helpful please rate me.<br />IMUFO2<br />Leo Ponder Appliance-Tyler,Texas<br /><a href=""></a> <br />
Aug 30, 2010 | GE Profile PSW26P Stainless Steel Side by...
GE Side By Side Ice Machine & Water dispenser not getting water
you may have a pin hole in your water line to your dispenser or you could be leaking at the water valve itself on the water dispenser side. you'll have to pull the refrigerator out from the wall and look where the main water line goes into the back of the refrigerator. you will probably have to take the back off to see. be sure you put the back of the refrigerator back when you are through.
Jun 05, 2010 | GE Profile PSW26P Stainless Steel Side by...
Icemaker leaking
Check two things.
1: see if you have ice buildup in the water inlet tube above ice maker, if you do chance are the water valve is bad, if not,
2: see if you have icicles hanging from bottom of ice maker, if you do you have a bad ice maker.
Either way, will need full model number and serial number both to get you the right part numbers for parts.
Oct 07, 2009 | GE Profile PSW26P Stainless Steel Side by...
Me GE Profile PSC23M Side by side ice maker quit making ice and water was on floor behind refrig. Is a water line frozen or clogged or do I have to replace ice maker?
It sounds like you just have a leak at the back. Try swapping the wires on the dual water inlet valve. Then try the water dispenser and watch on the back for where the water may be leaking before it gets up to the ice maker.
Oct 04, 2009 | GE Profile PSW26P Stainless Steel Side by...
I have a GE Profile ARtica side by side. Ice maker is acting up
The dispensor door not closing completely . Replace the flap solenoid and plunger behind the dispensor controls .
Aug 06, 2009 | GE Profile PSW26P Stainless Steel Side by...
GE Profile Artica - Water & ice dispensor not working.
This could be as simple as the door switch or as complex as the dispenser control board. I would try the door switch first. When the door is close it turns on the dispenser controls. If the contact is defective in the door/light switch then this happens. Unplug remove the door switch and mark wire locations. 1 Powers the lights and the other powers the dispenser. and one is the power itself. Sea Breeze
Jul 26, 2009 | GE Profile Arctica 25.4 Cubic Feet...
Ice maker tube freezing up
  • change the water valve on the back of the machine.
  •  the water valve is slowly leaking water up to the icemaker where it freezes and builds up ice, blocking the water flow.
Jun 09, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Refrigerator wate leak
Usually at the bottom outside of door (near hinge) is where the waterline will become loose or crack. Otherwise, I would have to look at it.
Apr 21, 2008 | GE Profile CustomStyle PSI23NGR Side by...
GE Profile PSI23NCR Side by Side Refrigerator Logo
855 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
