Question about Kyocera Mita FS-1030D Laser Printer
Showing a black rim on right side - Kyocera Mita FS-1030D Laser Printer
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 167 Answers
On top of the drum unit sits a plastic cleaner (usualy green).Ensure that this is pushed fully to the right (Home Position)You may need to run this the full width of the drum unit several times to clean the corona wire) If this does not correct the fault then a new process unit may be required.
Posted on Oct 04, 2009
Raising the spare tire
Sometimes the wheel is shaped differently on one side than the other. It may have to be installed upside down or rightside up to fully crank up in position.
Your spare could show a dirty side and a clean side. Usually the dirty side is the side that is hanging down at the bottom.
The side of the wheel that shows on the outside is flush with the lug
nuts. The backside of the rim has a cavity for the brake assembly to fit in and this accounts for the difference between lifting the rim using the front or back side.
The lifting cable is only so long, so it makes a difference whether it lifts immediately or has to travel through the rim cavity.
Please rate my info.
Jan 21, 2013 | 2008 Dodge Grand Caravan
60" LED tv showing black on the right side
try to replaced the back-light LED driver to fix it..In LCD its called inverter board..
Feb 23, 2012 | Sharp Televison & Video
My black berry 8520 had stuck in alt mode, its showing "alt" right upper side of the screen, pls giv me a solution
Press the arrow then the alt button again, or just take your battery out, then put it back in. :) hope I helped.
Jun 23, 2011 | RIM BlackBerry Curve 8520 Smartphone
I HAVE A 2006 PONTIAC MONTANA. I HAVE A CLICKING NOISE COMING FROM RIGHT FRONT WHEEL. ALSO VERY SLIGHT PULL TO THE RIGHT. ALSO WITH THE VAN ON THE GROUND IF I PUSH THE TIRE BACK AND FORTH THERE IS SOME...
Do you happen to have plastic rim covers? An auto mechanic suggested that these can rub or oscillate in just the right way to make you think you have a permanent rock stuck in your tire treads. It drove me nuts! But sure enough, I removed the rim coves and there was no noise at all. I ended up putting the same ones back on again with double-sided tape (double layered) along the inside rim of the covers and this stopped the noise for some time. Alas, one winter later, I'm hearing noises again. I've pulled them off again this week, but with my black rims underneath, the van looks like some undercover cop car!
Jun 21, 2011 | 2006 Pontiac Montana SV6
Just got tires on 1998 honda prelude. I think the tire place put the stock factory rims on wrong. are the inside of the rims mark left and right? does it make a difference what side of the car the rims go...
Yes.. there are left and right side wheels.. I doubt it will affect performance or will damage anything but there is a direction of rotation for the style of the wheel.. it is mostly appearance.
Remember if the tires you bought are directional .. they will have to remount them. I would guess the wheels are marked somewhere..
The "spokes" should be oriented with the trailing edge pointed rearward. This picture is the Passenger side or Right Wheel.. Best of Luck..
Mar 25, 2011 | 1998 Honda Prelude
I have and OKI C3400. My printer is showing globs
yuo have a leaky black toner cartridge
take out the cartridge and look for damage
aslo check the fuser for damge or leaks
replace any damaged cartridge
Mar 22, 2010 | OKI C3400n Laser Printer
How do i do a quick name search with from the numeric pad on the black berry storm.
Press the call button and change the option to show contact list as initial view.
Then change the right side convenience key to show the virtual key board, screen/key options then change
The right side convenience key to show virtual key board, so when you press call button, it shows contact, then you press side convenience key and a few letters of the person you want to call
Jan 21, 2010 | RIM BlackBerry Storm 9530 Smartphone
During embroidery, the machine indicates that the thread has broken, but it hasn't. When I rethread both the thread and the bobbin, restart the machine, it does a few stiches and then shows the thread...
You didn't state what brand of machine you have.
If it is a Janome, the fix is very simple. Open the left side cover and on the right of the take-up lever path there is a kidney shaped hole with a black gasket inside the rim and a spring tip poking out of the center. Sometimes the black gasket makes the spring hang up and the machine thinks that the thread is not moving. Make sure that the spring's movement is not inhibited and it will work.
Dec 16, 2009 | Kitchen Appliances - Others
I show that I have a voicemail but there is not one. How do I get rid of the icon showing I have a voicemail?
Hold down the left alt key, the right shift key, and the delete key on the right side as well... simultaneously. This will restart your phone kind of like a computer reboot.
If this doesn't fix it, contact AT&T technical support at 866.700.2105 and have then reset your mwi (short for message waiting indicator). It should take less than five minutes.
Nov 04, 2009 | RIM BlackBerry Bold 9000 Smartphone
Blackberry RIM went Black!!!???!
I think the reset button is under the battery cover - You may need a paperclip to reset.
Before you do the hard reset have you tried a soft reset -
ALT+RIGHT SHIFT(CAP)+DELETE keys
Jan 26, 2009 | RIM BlackBerry 7250
Kyocera Mita FS-1030D Laser Printer Logo
229 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Henry Gertcher
Adorjani Laszlo
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
