Question about Saeco Starbucks Sirena Espresso Machine
My machine is brand new and when I plugged it in for the first time, the light comes on but the water won't heat up.
Push the coffee button
Posted on Nov 02, 2010
    President:
  • 1,618 Answers
Press the coffee button to fill the boiler, then run the hot water cycle for about 5 secs. If machine still does not heat then the thermostat needs to be reset.
Posted on Oct 05, 2009
Our brand new keurig mini plus wont heat or dispense water
I had the same problem with my Mini ! I also had this problem with my last Mini which was given to me and I tossed out. So I replaced with the new one which just went on the fritz. Called Keurig who were very helpful and told me to descale, but I explained the machine is almost new. So I prodded them for what else could cause the problem and its water that is too cold.
Turns out the problem is that I was using very cold water and the machine can sense the water is cold and will not heat. It does not heat so it wont damage the heating element. I was using 40 degree water from the fridge.
My symptoms were: I would fill it, that the blue light would flash, I would push the button, then the red light would flash and then nothing it would shut off after a while. Now with not so freezing water it works fine!
Hope this helps as I threw out a good machine because the water was too cold!
Jan 22, 2013 | Keurig Mini B31 Plus Red Coffee Maker
My brand new nescafe dolce gusto does not work. there is no water coming out.
If you're getting a "no water" error message then you need to "prime" the machine by either:
1. Fulling the tank with water and leave it in the machine for 2 hours at least.
2. Re-seat the water tank about 70-80 times to get the bubbles out and the water flowing.
Dec 30, 2011 | Coffee Makers & Espresso Machines
Won't heat up
Hi
Have you run water through the steam wand on the right. Make sure that you have water in the water tank and the pick up tube is in the water. Open the knob and then push the brew button.
Oct 21, 2009 | Saeco Starbucks Sirena Espresso Machine
Hi! I got a new Bunn VPR last week but did not run water through it because I was waiting for our maintenance guy to install a GTRI outlet for it. When he installed the outlet on Saturday he plugged in...
It sounds as though the thermal cutout has been put to the test and it didn't pass. I would advise you to try to get the company that the repairman works for to replace the entire machine, after all it is brand new and changing parts at this venue could void the warantee.
Sep 22, 2009 | Bunn VPR Coffee Maker
Can't Prime Water Circuit
Hi You need to switch Steam ON so it heats up and then turn Steam button OFF (no light) and then turn steamer knob counter clockwise you will hear the pump start up and then water will stream out. This is when it's primed. Turn steamer clock wise to close. You must do this everytime you use the steamer.
Dec 06, 2008 | Saeco VIA Venezia
3-Pot coffee Maker instructions
The first time you use the machine you need to make sure it is full of water - before you plug it in and turn it on. Put an empty coffee pot under the brew basket and fill another empty pot with clean cold water.
Pour the water into the coffee maker. If water comes out then you can plug it in and turn it on. The water heating tank holds about 2-1/2 pots of water so if your machine is empty you will need to keep adding water before you turn it on otherwise you may burn up the heating element.
After the green light comes on - indicating that the tank is hot you can brew a pot of coffee. This machine is meant to be left on all of the time so it is always ready to brew. If you choose to turn it off when not in use, you will need to give it about 10 minutes to fully heat up the water before you brew.
Jan 25, 2008 | Bloomfield 8571 Coffee Maker
Power light on, no warning light, doesn't heat up at all
Your resettable thermostat turned off the high power heater circuit and the red warning light. The heater got too hot when the boiler became empty of water. This is to keep the heater from burning out if the boiler becomes empty. To reset the thermostat, turn the micro casa a leva over. There is a yellow plug near the center of the bottom which is easy to pry out. Stick a screwdriver, pencil, toothpick, chopstick or whatever else is lying around into the hole and gently reset the thermostat button. You will hear a click when it resets. You are then ready to go.
Jan 04, 2008 | Elektra micro casa a leva S1CO Espresso...
Hot water won't flow into machine
You most likely need to prime the brew head. Follow the instructions in the owner's manual. To prime the brew head, you'll need to put run the machine without coffee until water starts flowing. One water flows, the brew head is primed and the machine is ready for normal use. You'll need to do this every time you run out of water. Regards, Denis
Oct 09, 2007 | Breville ESP8XL Espresso Machine
Saeco Starbucks Sirena Espresso Machine Logo
248 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
