Question about White Sewing Mighty Mender WW100 Mechanical Sewing Machine
NO MANUAL WITH MACHINE, CAN NOT GET THE BOBBIN TO WORK
  • 108 Answers
I was able to find it at www.ifixmachines.com
Posted on Feb 15, 2010
What size bobbin do I need?
Consult your owner's manual. It should tell you which bobbins work in your machine. There are many, many bobbins on the market, so you need to be sure you have the right one for your machine.
You can probably also search the internet for:
Machine Manufacturer + Model + the word "bobbin"
and you might find a supplier of bobbins for your machine. You can also try visiting a local dealer for your machine. P.S.--you'll need to know the model of your machine.
Jan 05, 2016 | Sewing Machines
Husqvarna viking sewing machine bobbin
Could the part number be 4011770? I've found the Viking 7 bobbins here: http://www.mysewingmachineparts.com/top-quality-metal-sewing-machine-bobbins-4011770-husqvarna-viking/ . Another site with them is http://www.sewingpartsonline.com/bobbin-viking-4011770.aspx . This bobbin is compatible with the Husqvarna Viking 7, 49, 51, 52, 21 & 21E . It probably will work for other machines. Sears also has them listed as 11770: http://www.sears.com/generic-viking-sewing-machine-bobbins-sewing-machine/p-SPM6124767105?prdNo=1&blockNo=1&blockType=G1 .
I also found these bobbins: http://www.amazon.com/Viking-Metal-Bobbins-5-pkg/dp/B000YZ5QSC . The part number appears to be 1702.
I hope this helps.
(googling Husqvarna Viking metal bobbins found a number of hits.)
Mar 05, 2013 | Husqvarna Viking 1
Bobbin not winding tightly
BRAND new Janome 1420qdc. New needle, doesn’t need oil. Will NOT wind a bobbin. Used almost an entire spook of thread doing this. At my wits end. HELP!
Mar 28, 2012 | Janome Memorycraft 9700 Computerized...
I have a singer touch tronic sewing machine. I need to fill the bobbin and I cannot get it to work. where can I buy more bobbins that have already been filled to fit my machine
Has the bobbin winder worked in the past and now faulting. Or are you unsure on how to use it?
There is a manual for a Touchtronic 2000 here http://www.singerco.com/uploads/download/432_touchtronic.pdf there may be more than one model Touch Tronic so plse check the serial number plate on the side of your machine to establish the actual model number, usually near the power inlet plug. then search for the appropriate manual at http://www.singerco.com/accessories/instruction-manuals. This excerpt shows that you wind the bobbin insitu in the bobbin case.
I'm not a fan of prewound bobbins, far better to deal with the bobbin winder issue. Winding your own thread means you can get far better colour matching to the fabric, and ensure you've got quality thread on the machine, and same thread top and bottom. (I prefer a quality cotton wrapped polyester or a polyester thread, Guttermann, Molynecke or Sylko Supreme). All of these factors affect stitching quality and the finished appearance of a seam.
Did you know that you can buy a freestanding unit to wind bobbins? Link to this item is here. http://www.sewingpartsonline.com/universal-automatic-bobbin-winder.aspx You may well find that this is the better solution to winding bobbins for this machine as winding them inside the bobbin housing doesn't give you a lot of control over the way the thread feeds onto the bobbin.
Jun 27, 2011 | Sewing Machines
My machine will not thread my bobbin...And I'm scared that this might be the last time i use my sewing machine.....It's either that or that my thread will not grab the bobbin thread
I could not find any information on this model, but if it is a self-winding horizontal bobbin where the bobbin remains in the bobbin case as it is being wound - it could need repair.
Re-check your manual to make sure every step is working to set-up for winding.
If it still does not work, call a machine repair professional for an estimate. It could just be the timing needs adjusted.
Feb 23, 2010 | Kenmore Drop-In Bobbin 505S-21BH...
Need manual for Kenmore sewing machine, model 148-600.
hi! there, since there no model you can relay on this basic set up an old mechanical sewing machine,set your upper thread as shown65a8465.jpgfollow the red loop thread from sppol to needle,then lift needle cover plate take bobbins and follow bobbins thread directionec848a5.jpgthreads inside bobbin clockwise rotation when you pull outthe insert bobbin to shuttle race casas shown
hold bobbin like this 33ea7ef.jpginsert
this to shutttle race case as shown ignore arrow
ebd49c7.jpgthen
after inseting bobbins closed needle plate cover
manually rorate hand wheel to hook up lower thread bobbin by upper thread bobbin if two thread appear on plate needle adjust tension dial to # 3 to 4 and stich dial to # 12 this for straight stich try sew manually first to observe thread under bobbins if free rotate and no accumulation of thread loop you sew w/ foot pedal or push buttin..happy sewing and have a nice day thanks
Mar 31, 2009 | Sewing Machines
Tension problem on Brother ES 2000
I have a Brother CE 4000 Computer sewing machine. I had the same problem when I first used it. I worked with it several hours but to no avail so I decided to stop and wait until my head clear..
I went back a couple of days later. Reread the manual and started over. I discovered my problem was that I was threading the bobbin wrong. Once I threaded it precisely as the manual stated it worked fine.
So this might be your problem. Make sure that the thread on the bobbin is wind on properly. It should be wound evenly. The bobbin must be threaded precisely as the manual says.
Try rethreading the bobbin and the machine
and see if that help.
Feb 27, 2009 | Brother ES2000 Computerized Sewing Machine
Can't wind bobbin kenmore 16221 sewing machine, no manual
On the right side of the machine there is a large knob at the top. Pull that out and you can wind your bobbin. Don't forget to push it back in so you can sew :)
Dec 22, 2008 | Kenmore Drop-In Bobbin 16231 Mechanical...
Threading and putting the bobbin back in the machine
Most machines have a bobbin case, that removes to place the bobbin inside and then the case goes back into the machiens. However some bobbins just load the bobbin flat from the top. The best place to start is with your machine's manual. If you don't have the machine manual, contact your machine's manufacturer or google "sewing machine manuals" as there are several vendors who sell replacement manuals. One of them is SewUSA.com and they have free threading diagrams on the site,maybe that would help you get started.
Feb 12, 2008 | Brother XL-5130 Mechanical Sewing Machine
White Sewing Mighty Mender WW100 Mechanical Sewing Machine Logo
378 people viewed this question
Top White Sewing Sewing Machines Experts
Tally Girl
Tally Girl
tsalagi152
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
