Question about Amana RanARG7302 Gas Kitchen Range
Hello need help on my armani oven #arg7300LL oven and broiler do not go on?
Hello supertech007 replied to my question here is my post? can you please tell me how to check the oven sensor??it is connected to the thermsata control knob, does that mean that this whole unit is bad, as far as the oven door when it is closed and locked the self cleaning works fine only the broiler works, oven does not turn on, the stovetop works fine,all 4 burners light up fine, this a ignition unit stove, here is the my post :
I have a amana oven arg7300LL the oven and boiler do not go on, i replaced the oven ignitor and no help, when I turn on the unit for self clean the boiler goes on normally and starts to self clean this works normal,then I cancel , this unit has clock panel with self clean buttons on it , I am thinking it is the control oven switch knob thermostat? can you please help me out, changing the wrong parts gets expensive thanks Ron
super tech007 says Check the oven sensor it may be the problem. Also check the lock assembly. When in self clean does your bake come on too? It should come on with the broiler
how do I check the sensor?? anything else that it could be , please let me know thanks ron
  • ron calvo Dec 22, 2007
    thanks for replying, yes I replaced the oven ignitor with orginal same part,flat looking one same type as orginal,I have no voltage at ignitor,you guys have this part $120.oo shipped? I was going to buy one, but did not want to take chance? please let me know? the oven seems like a very simple system only a couple of parts? but you have to make sure, they are expensive!
  • 279 Answers
Still looking for that part?
I found it here:
I understand why they won't let Bgillespie sell you the part (conflict of interests) but this time it didn't turn out too well I guess. Anyway, the above site has it for $125.
Posted on Dec 24, 2007
  • 89 Answers
Ok yes, it may be the thermostat.(It is the control and the tube that runs down inside the oven.) Give a few minutes and I'll post back....
Posted on Dec 22, 2007
  • 1 more comment
  • Brian Gillespie
    Brian Gillespie Dec 22, 2007
    When you replaced the ignitor did you replace it with a "flat" shaped ignitor? Yes you can also check the thermostat control by turning it on and checking for voltage at the ignitor. No voltage means that thermostat is bad...
  • Brian Gillespie
    I just looked at your oven. If you turn the oven on and your not getting any voltage to the ignitor then thermostat has to be replaced.
    Part# 0316507 (cost around $120.00)
    Bad news is here in houston my parts store show that the part has to be ordered from the factory. It will probaly be a few weeks before you will be able to get the part.GOODLUCK and Mery Christmas!
  • Brian Gillespie
    Brian Gillespie Dec 23, 2007
    Glad I can Help. Under fixya rules I can not sell you the part.
I need a oven or broiler element but can't find where I can buy one. Can you help?
amazon, eBay, any home hardware store should carry this item
Mar 10, 2016 | Ovens
Had oven set at 500 degrees. Turned off all burners and oven, but the broiler remains on! What do I do?
Hello. It sounds like you have a shorted relay on the main board(if this oven has an electronic control board) keeping power on to the broiler element. I need the make/model number to help you further and accurately.
Sep 20, 2015 | Kitchen Ranges
My Frigidaire gas oven won't light but broiler does light
Hello friend, thank you for your post!
From what you are describing it sounds like a potential issue with your control or pressure regulator within your Frigidaire oven. I would recommend seeking assistance from a professional for further help regarding the oven not lighting due to the gas.
If you need assistance connecting with a professional technician you can visit the manufacture's website for further help. -Matt
Oct 04, 2014 | Ovens
Why will my broiler work but my bake will not?
Good Afternoon Friend,
I understand that the broil element is heating in your Frigidaire oven, but the bottom bake element will not heat. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. When you restore power you will need to set the clock. Preheat your oven using the bake option. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your oven status has changed successfully. Hope this is helpful.
-Best Regards-
May 30, 2014 | Frigidaire Ovens
Magtag ser#mer6755aaw Broiler element not working.Switched wires from another element to verify that broiler element was working and it heated up just fine. Tried to get the codes to display but only got...
Welcome to fixya
I have a solution for this
Press Ok, Accept or replay so we may get started
Your pre-solution is coming up shortly
My name is Bruce
Jan 15, 2011 | Maytag Ovens
Oven won't ignite,burners work broiler works. Is a wiring diagram and schematic available ? Amana Model ARG7300LL ;Mfg.P114332ONLL
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
May 18, 2010 | Kitchen Ranges
Broiler coil is on when bake is turned this normal?
On some kitchen ranges, the broiler comes on during the preheat cycle to speed up the process of warming up the oven and reduce the wait time. This is intended as an energy saving feature as well by reducing the amount gas used on a gas range and the amount of electricity with an electric range.
If the broiler comes on and STAYS on while you are baking, this is NOT normal and is probably an indicaiton that you have a problem with the Electronic Oven Control (EOC) board. This is your timer/clock assembly on the operator console. The EOC controls all the oven features.
If you have any questions, please post back and let me know. Please post your MODEL NUMBER when submitting questions, so I can determine how your range is configured. I hope this helps you.
Mar 10, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
My oven does not work but broiler does
Look at the ignitor. Should have 110 volts to it when on bake. Replace if not glowing. I cannot see your reply due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Nov 28, 2008 | Frigidaire 27 in. Electric Double...
Amana oven arg7300LL oven and boiler do not work?
If it is the same as my Amana, it has a small switch in front of the thermostat switch. It is only a $15 part to fix it. I am searching for the thermostat and your question came up. I am sorry it is so late in response to your question. I am sure you have fixed it by now.
Dec 22, 2007 | Amana RanARG7302 Gas Kitchen Range
Amana oven not working and boiler also
Check the oven sensor it may be the problem. Also check the lock assembly. When in self clean does your bake come on too? It should come on with the broiler.
Dec 21, 2007 | Amana RanARG7302 Gas Kitchen Range
Amana RanARG7302 Gas Kitchen Range Logo
251 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal De
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
