My canon printer has a error that says 6A00 - Office Equipment & Supplies
SOURCE: canon mp530 getting error message 6a00
HI Guys 6A00 error usually cant't be fixed according to the service centre, I was lucky and actually bought an extended warranty, the service centre said that the MP530 are a good printer and worth fixing as they don't see many at all compared to other models and other brands. There was a broken piece of hardware that something to do with the print carriage. cheers vailey
Posted on Apr 18, 2008
SOURCE: Canon ip5200 Service Error 6A00
This might have something to do with canon's absurd print cartridge limitation agreement.... where the print cartridge will only print for a certain limit and then locks
Posted on Jul 24, 2008
jonniewalker
  • 1031 Answers
SOURCE: Canon MP830 error code 6A00
The problem apparently is related to the purge unit located at the far right side on where the printhead moves back and forth.
there appears to be three common problems that causes the error, which is related to a paper jam error. 1) If its a new printer or even an older one, there are two sponges that collect ink and two plastic wipers located in purge unit may be loose or missing. Check to see if its it there. If not, it may actually be stuck somewhere.
2) there may some paper stuck somewhere around the printhead and or the purge unit or
3) there is a build up of gooey ink on the purge unit.
, I turned off the printer & unplugged it, move the printhead to the left and used long Qtips with Windex to clean up the ink around the purge unit including a little white plastic spring-loaded lever. also dampen the sponges with Windex. If you do this be careful not to dislodge the sponge or wipers. If you do, you can alway stick the pieces back in. After cleaning it, and checking the sponges and wipers are seated correctly, plug the unit back in and hopefully it will work fine. hope this helps.dont forget to rate as fixyaa
thanks and Godbless
Posted on Oct 12, 2008
jhaugan
SOURCE: getting error code 6A00-Canon PIXMA MX850 all-in-one printer
With our MX850 I managed to get it working by simply cleaning as much of the of the residue ink from the right hand side as possible. I simply used a tissue but a cloth would be better.
Posted on Dec 17, 2009
pineworks
  • 4041 Answers
SOURCE: service error 6A00 in my canon ip 5200 printer. what should i do
Hi
Error 6A00
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 10, 2010
6A00 error code
6A00 is a problem with the sheet feed unit. I would get in touch with Canon, to hopefully get it repaired. Not much you can do yourself sadly.
Nov 22, 2012 | Canon PIXMA MP830 All-In-One InkJet...
The copy shows a error code 6A00 I can't do anything with it the ink cradle does not light up
Solution Canon Pixma IP4300 Error 6A00, this reset tips is from someone in printer forum but the tutorial in picture. You can follow the instruction in the picture to solve error 6A00 in Canon iP4300. Some users say on the forum this reset method also work on Canon iP4200 and Canon MP800. Look the picture below to view the complete tutorial how to solve Error 6A00
Larger picture here
Jul 07, 2011 | Canon Office Equipment & Supplies
Canon pixma all in one mp500 error code 6A00
Manually move the print head left and right, and turn the printer on/off. I would also inspect the rollers for ANY debris... it can often be fixed by using "canned air" and blowing the interior out completely.
Apr 29, 2010 | Canon Pixma MP500 All-In-One InkJet...
Canon pixma mp800 error code 6A00
6A00 means you need a new purge assembly. That's the unit that cleans the printhead. Part number is QM2-3032-000 around $30.00 but a shop should install it.
Jul 24, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Will not turn on error 6A00
This is what I found from a service manual: AP position error [6A00] - Sheet feed unit (QM2-1220) - Logic board ***'y (QM2-1786)*1
What does it mean? This link should be useful: http://www.fixyourownprinter.com/forums/inkjet/37440
May 30, 2009 | Canon Pixma iP6000D InkJet Photo Printer
Check printer and 6A00 flashing
6A00 indicates that "an error occurred in the AP motor
during purging operation". This is a service call error and requires that the printer be brought into a canon authorized service facility for repair. The service facility would be able to fully diagnose the problem and properly repair it.
May 21, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Error code 6A00
Error Code 6A00 is a problem with the sheet feed unit. You cannot fix it by yourself because you do not have the tools to fix the printer.
You go to a Canons Support Page and ask for a replacement if it is still under warranty or you replace the printer with a new one.
Aug 16, 2008 | Canon MP830 All-In-One Printer
MP600
when i turn on my mp600 canon printer i get the same error code 6A00! i cannot do anything with the printer, please help!
Apr 08, 2008 | Canon PIXMA MP600 all-In-One InkJet...
k24674
jasbo
jasbo
