Question about Dryers
I have an electric ge dryer. when i turn the
I have an electric ge dryer. when i turn the start switch it will buzz for a few seconds and then drum starts turning do i need a new start switch
  • 464 Answers
Check the belt, it may not be tight enough around the drum and idler to engage the motor.
Posted on Oct 04, 2009
My dryer motor comes on (you can hear a humming noise) but the drum does not turn.
GE dryer won't start. Makes buzzing noise... - YouTube
? 0:39
www.youtube.com/watch?v=W_og12QJqm8
May 8, 2010 - Uploaded by maxicheong Anyone seen this before? When i tried to turn on the dryer, i get ahumming / buzzing sound and the drum ...
Oct 08, 2015 | GE WE12M22 Dryer
Start button starts dryer and dryer stops when button is released.
Ge dryers have a belt sensing switch inside that won't let the dryer run (just as you describe) when the belt breaks or comes off. My guess is you broke a belt. With door open---hold in button door switch and hit the start switch to get it too run a few seconds. Watch the drum and see if it turns. My guess it will not. Belt is a long skinny band that goes all around the drum outer area and then down around the motor.
Jul 09, 2015 | GE GTDP180GDWW Gas Dryers
My dryer initially makes a buzzing sound and will not begin the cycle until I give it a few turns manually...
you have a bad motor,if you open the door,hold the door switch in with one hand and spin the drum with the other and have someone else push the start button on and if by helping it to spin it starts usually the motor is bad but i did find on the maytag neptune style dryer that the belt cut into the belt pulley and was holding up the drum and the motor was buzzing like it was bad but like i say usually it's the motor.next time send the brand name and model number and i can help you out better.
Jan 25, 2014 | Whirlpool LER5636P Electric Dryer
Whirlpool dryer makes a buzzing sound whey start button is pushed. sometimes it will turn on for a few seconds but most of the time it just buzzes.
The buzzing is probably the relay trying to start the motor. See if the motor has a capacitor, have it checked. If the motor is all clogged with lint, the start/run switch can get blocked. Clean out all that lint with a vacuum cleaner.
Check the tub bearing, and make sure the drum spins freely.
Nov 29, 2013 | Whirlpool LER4634J Electric Dryer
When I press the start button on my GE DPSR610EG4WT profile dryer it only makes an electrical buzzing sound and will not turn on or start. What causes this?
The buzz is probably coming from the control switch drive motor. If it is not turning the switch, the dryer wont run.
murf427
Aug 02, 2012 | GE DPSR610EGWT Electric Dryer
My ge dryer model DRS483ED1WW won't turn on all it does is buzz when I try. I have changed starter switch that didn't work
does the drum and motor turn by hand freely. but i think its possibly the bushes in the motor. just have a look at motor and see if theres black carbon dust on it, you will get this on a motor anyway but not in excess
Jan 06, 2012 | GE DBSR453EBWW Electric Dryer
The dryer makes an electrical buzzing sound but the drum doesn't spin. I can spin the drum manually, which I never could before the problem started. Model GE DBVH512EFOWW
michael00256 (that's a great name by the way). several things could be going on. If you can gain access inside the cabinet, you'll need to do that.
http://www.do-it-yourself-washing-machine-and-dryer-repair-help.com/take-apart-GEelectricgasdryer.html here's some video help that should tell you what you need to know.
http://www.do-it-yourself-washing-machine-and-dryer-repair-help.com/GE-HP-dryer-is-not-tumbling.html here is also a link that should tell you exactly what you need to check.
The problem could be in the motor, with the belt, or a few more things.
If you get this far and still have not solve your problem, please contact me. My name is Mike, and I would be more than happy to help you out in solving this problem.
thanks,
mike
PS; if you're even slightly handy, this could be something that you can do yourself.
Jul 19, 2011 | GE DBVH512EFWW Dryer
Start button buzzes when pressed, dryer doesn't start.
I assume the buzzing quit when you release the start button. Open the dryer door and slowly rotate the dryer drum in a counterclockwise (CCW) direction. Rotate the drum 2-3 revolutions and then shut the door and see if it will start. If it continues to just hum and not start could indicate a voltage issue, motor issue or a friction issue. Open the door again and locate the door switch plunger in the upper or lower corner on the hinge side of the drum opening. Hold the plunger in while someone begins rotating the drum counterclockwise. While turning the drum counter clockwise and holding the door switch plunger inwards press the start button. If it starts, there is likely a friction problem or motor problem.
Apr 26, 2011 | GE DVL223EBWW Electric Dryer
GE Profile Harmony Dryer Drum will not turn
the inertia switch on the shaft of the drum motor has failed This will require removal of the drum motor
Jun 01, 2009 | GE Profile Harmony DPGT750EC Electric...
Dryers Logo
59 people viewed this question
Top Dryers Experts
