Question about Sony Ericsson TM506 Cell Phone
I forgot my phone password how do i get it erased so i can access it again
Forgot password BLU dash jr. IMIE 353**********04 how do I recover it
You can't recover the password, not possible. In order to regain use of the phone again you must do a "factory reset" this will erase the password and also all of your stored data that you inputted into the phone like phone numbers and pictures.
Oct 31, 2016 | Blu Cell Phones
My child has put a password on my phone and now i cant get in ive been trying since last night and she cannot remember what the password was please help
On your phone there should be a backup option if you forgot your password, you can then follow the instructions and get access to your phone
Or you could reset your phone by following these steps (CAUTION: THIS METHOD WILL ERASE EVERYTHING ON YOUR PHONE)'
http://www.hardreset.info/devices/samsung/samsung-g920f-galaxy-s6/
Jul 08, 2016 | Samsung Galaxy S6 Edge
Wants password for apple id that is no longer an id and I have no idea what the password would have been
Do a Factory reset via a computer and iTunes which will bring the phone back to an empty operating system. Open a new Apple ID and go from there. Everything on the phone will be erased and you will no longer have access to the apps you had or any iTunes music.
Or you could try and get the old account back?
https://iforgot.apple.com/password/verify/appleid#!┬žion=password
There is additional information here
http://forums.imore.com/icloud/267398-forgot-apple-id-password.html
Jan 13, 2016 | Apple iPhone Cell Phones
How do i get passed the lock screen if i forgot my password without erasing data?
Recover Android Device in case of Forgot password/pattern ...
visihow.com/Recover...Forgot_password/pattern_unlock_an_Android_d...
Scroll using your "Volume up and down" button until you find the "Factory Data Reset" option. Tap the "Factory Data Reset" option. Tap "Reset phone". This will erase all of your data, but it will allow you to unlock your Android mobile device.
How To Reset Android Password or Pattern Without Losing ...
? 3:44
https://www.youtube.com/watch?v=-VXnNh7-4BA
Jan 22, 2015 - Uploaded by Intellect Digest
Forgot Password On Android Phone or Tablet- How To Reset ... or Pattern Without Losing Data When You ...
How to bypass Android's lock screen pattern, PIN or p
Dec 25, 2015 | Cell Phones
How do I reset my password
is this for your blackberry id ? if so then you will need access to the e-mail address you registered the id with. and you can click on the forgot password link in the blackberry app world under my world and if you dont have this access or cant remember the e-mail address you will have to phone blackberry and speak to a consultant.
or
you can do a security wipe under options and security settings and then device wipe (note this option will erase all your information from the phone)
Nov 30, 2014 | Research In Motion Blackberry Curve 9320 -...
Forgot mypattern to unlock phone its a concord zte768 I think can u help me
Try these steps:
ZTE Origin hard reset Master Clear/Reset Cricket Origin reset ZTE V768 ,
1. Make sure your phone has been powered off.
2. Hold down Volume up key and press Power key at same time until the screen lights up.
3. Press Home Key to access Android System Recovery screen.
4. Press Volume up\down key to locate wipe data/factory reset, then press Menu key to access factory data reset menu.
5. Select Yes-delete all user data, then press Menu key to confirm wiping data from the phone.
6. When finished, select reboot system now, then press Menu key to restart your phone.
Every data will be erased!
or You can reset your ZTE device's password: Turn off your phone, then turn it on. Select emergency dial. Input *983*987# in emergency dial-up pad. It will restore factory settings and your personal data will be erased.
or from the menu
Privacy: Reset to Factory Settings
1. Touch the Home Key > Apps icon > Settings > Privacy > Factory data reset > Reset phone.
2. Enter six zeros on the screen and touch Erase everything.
WARNING! All your personal information and downloaded applications on your phone will be erased after the factory reset. ZTE Origin V768 Phone Password A password can protect your phone and help prevent unauthorized use. When the phone is password protected, it will ask for the password every time the phone is turned on. Password protection is disabled by default, and the default password is 000000 (six zeros).
Jun 05, 2014 | Cell Phones
I forgot the password for my htc touch phone, i have tried my usual passwords also..but nothing helps. please suggest something to unlock it.
I am afraid the only way is to "hard reset". But note that this will erase all your data.
hold down the Send and End Call buttons down firmly and push the stylus up in the little hole near the usb port (Reset Button) and wait till the screen says that the phone is going to format and all data will be lost press the soft key to continue.
Mar 02, 2011 | Cell Phones
I forgot my iphone voicemail password, how can i just erase so i can make a new one.
  1. Call 611 or 800-331-0500.
  2. Press 1 to use existing number, or enter the wireless number starting with area code.
  3. Tap the 3 key to "get help with voicemail." (5 for enterprise customers)
  4. Tap the 3 key to reset your VM password.
  5. Enter the Billing Zip code for the account.
  6. A temporary password will be sent via SMS
  7. Access voicemail with this temporary password.
After performing the above steps, my voicemail was accessible once again, and I didn't appear to have lost any prior voice mail messages. AT&T's support page has several other options available as well, but I found the above to be the quickest and easiest to execute directly from my iPhone.
Jan 31, 2011 | Apple iPhone 3G
WHEN I RESET MY HTC DIAMOND TOUCH PHONEIT'S REQUIRE PASSWORD WHICH IS I FORGOT.
Perform a hard reset by holding the talk and answer buttons and then inserting the stylus in the reset switch hole. This will erase EVERYTHING on the phone, including the lock. Once again, the phone will be like brand new... EVERYTHING WILL BE ERASED.
~KenjiFox
Jan 07, 2011 | HTC Touch Cell Phone (Unlocked) - Soft...
Sony Ericsson TM506 Cell Phone Logo
75 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
